Question about Sewing Machines
Have an old F&R sewing machine and the thread take up wire has broken where can I get a replacement please. I live in Spain
No haven't solved it, but as the machine is not mine I do not want to subscribe to anything. Only doing my friend a favour
Posted on Sep 09, 2009
Where are the oiling points and what would make the threads constantly break
Depends on your make & model machine. Newer computerized machines require little or no oiling. Consult your owner's manual AND use only good quality sewing machine oil.
Thread breakage:
#1--Avoid bargain bin variety and old thread!
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Is My Thread Breaking How to Avoid Thread Breakage at Your Sewing...
Apr 07, 2017 | Sewing Machines
After threading the machine, start to sew and the thread breaks it seems that it gets caught in step 4 in Threading The Machine in the manual.
Not knowing the make & model of the machine limits out ability to help. What is Step 4? When threading the top thread, ALWAYS RAISE the presser foot. Verify that the thread path is correct--mis-threading is a frequent cause of broken thread.
Mar 16, 2017 | Sewing Machines
Have a Singer 11910000A and the bobber thread bunches up and makes a mess in the feet when sewing
Is it really the bobbin thread that is globbing? Check closely. Usually it is the upper thread accumulating under the fabric.
If it is in fact the bobbin thread, then the bobbin case is not threaded correctly, the bobbin case tension needs adjustment, or it is broken and needs replacement. There are web sites and YouTube videos that show how to adjust the bobbin case tension.
QUICK FIXES: Remove all the thread from the machine. Clean the area around the feed dogs and bobbin area. Oil as instructed in the owner's manual using ONLY fresh, good quality sewing machine oil (only 1-2 drops each spot). Install a brand new needle insuring it is installed correctly. Avoid using fuzzy, old, or bargain bin thread. Rethread: Be sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk--and check to make sure you are threading the machine correctly. Check that the upper tension is set properly (the factory standard is usually the halfway point between the high & low number on the selection). Test on a scrap of the fabric you wish to sew. Adjust the upper tension--either tighten to pull the upper thread toward the top of the fabric, or loosen to pull more upper thread down.
Here are some web sites that may help.
Sewing Machine Thread Bunching Up Here Why
sewing machine birdnesting
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
8 Tips to Fix Birdnesting in Embroidery
Birds nest under the fabric big loops of thread top side looks good...
http://www.marthastewart.com/1085057/common-sewing-machine-repair-tips
and here's another Hint that may be helpful:
https://www.youtube.com/watch?v=KDERq4I7l-Q
Dec 29, 2015 | Singer Sewing Machines
My bobbin thread continues to bunch up on the back of the fabric.. How can I fix this?
3 Common Sewing Machine Problems and How to Fix Them
Dec 29, 2015 | Sewing Machines
Service center new delhi
Not sure where you can take it. Check your thread tension and bobbin tension. Make sure they are not too tight. Also, how old is your thread? Many times, old thread will break easily. Check your needles for burrs. If there is a burr, the thread will break constantly when the needle moves up and down as it catches on the plate.
Feb 05, 2018 | Brother Sewing Machines
The wire for threading the needle has broken how to replace it
a sewing machine shop can replace it easy for you.
or try the sewingpartsonline.com & see if they have the part
May 21, 2012 | Brother Sewing Machines
Singer curvy beeps 4 times and stops sewing
when you thread the machine make sure to use every thread guide
check to see if the bobbin is in correctly
try changing the needle--normally flat side goes to the back
the needle that your sewing with is it the right one for the thread & fabric
clean under the needle plate & bobbin area for lint or loose threads
Mar 31, 2012 | Singer Curvy 8770 Electronic Sewing...
GC 500/550 not pulling bobbin thread. My wife has used the machine several times without issue, the last time she broke a needle sewing some denim, we found most of the needle but could not find it all,...
some sewing machines can not sew denim good,
here are some suggestions
since a needle was broken & replaced--if the needle has a flat side it goes to the back of the machine
make sure the needle is inserted correctly & pushed up inside of the needle holder & the needle screw tightened correctly
is the correct needle being used for the thread & fabric being sewed?
when sewing denim, a denim needle is needed, I usually purchase mine at walmart, I have 2 necchi sewing machines & the denim needles work just fine on my machines.
if none of the above suggestions help then the machine could be out of time, just because of a broken needle. only a repair shop has the correct tool to fix this problem
Sep 09, 2011 | Singer CG754 Mechanical Sewing Machine
Say the thread is broken but it isnt
Make sure your software is up to date. "Live Update" under "Help" submenu.
If software is updated make sure the upper thread is inside the thread sensor area. Check Machine Tutorial for proper threading.
Dec 01, 2009 | Singer CE-200 Quantum Futura Computerized...
LS 2125i haveing problems getting the top thread
I don't know about now, but in the old days you had to pull out about three inches of thread through the eye of the needle & hold it with plenty of slack while turning the wheel on the end of the machine slowly. Once the needle disappeared below the plate & then reappeared you could stop turning the wheel & slowly pull on the end of the thread you are holding to pull the thread from the bobbin up. Of course there must be thread on the bobbin spool & it must be some extra hanging out. (not broken off flush with the spool)
Jun 30, 2009 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
