Question about Whirlpool GEW9250 Electric Dryer
DUET Dryer M# GEW9200LQ0 - Not cuttinh on
My dryer suddenly stopped...used all day. Now when I placed a new load in, controled on and pressed start, the "sensing" light comes on, and that's it. The dryer will not proceded further. Please help!
  • 3 more comments
  • Anonymous Dec 12, 2007
    I have the exact same problem. Sensing light is illuminated and the dryer will do nothing. I push the "more time less time" 3 times in 5 seconds to access service mode, open the door and a code 3E displays in the time remaining display. From what I can find on-line, a 3E indicates a user control interface needs to be replaced. The lowest cost I could find for that part is at pcappliancerepair.com @ $177.61, about half of what whirlpool wants. I'm waiting for the part to arrive to see if this fixes it.
  • Anonymous Dec 17, 2007
    I have the same problem. We cleaned all of the vents. Nothing is helping!
  • coasty Dec 21, 2007
    Bob from LI - THX for the assistance, although not successful you did help me realize to start small B4 I jump to a repair call or more/ I guess I'm getting a circuit board! THX again and Merry Christmas.
    coasty
  • wrb111 Apr 28, 2008
    I am having the same problem. Dryed clothes all day. the machine shut off and then when you try to restart the sensing light comes on and it goes no further. Is it a sensor or sircuit board or what????
    Ross
  • Anonymous Aug 22, 2008
    whirlpool dryer shut off and "sensing" light is on.
My Duet did not start. Then it did start. I thought it was over heated. I cleaned then vents, and dryer inside and out. It worked a few loads and then did not work.
I found out that the Duet has two latches, one at the top and one at the bottom on my dryer. The have to both be engaged for the dryer to work. It started right up.
Maybe coincidence? But give it a try my friends.
Posted on May 14, 2008
  • 833 Answers
Coasty...I'm a believer in starting small and going bigger. First, turn off power at the breakers and then back on. You must do this on both sides of the line. If this resets everything, you're good. If not, check the rest of the wiring. Still no, then you're going to need that circuit board.
Posted on Dec 18, 2007
  • Robert Hirst Dec 21, 2007
    Enjoy yours as well. Thanks.
Have Duet front load dryer. When pressing Hold/start button, hear 3 fast beeps from the back of the unit, display flashes and dryer will not start. Any suggestions?
This is a common problem with the Duet and the solution is to replace the Motor Control Board (MCU). The control board has a short and the new control boards are revised to address this issue. Here is a link to the new control board.
Here is a copy of my service manual to help you replace the control board.
Good luck and keep me posted.Richard Roth
Oct 18, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Dryer won't start, been using all day no problems. Go to load another load in, it lights up when I press start all I hear is a 'click' sound and then nothing. All lights stay on just like it's ready to...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 03, 2011 | Whirlpool GGW9250PL Gas Dryer
Machine is stuck in control lock
This feature allows you to lock your settings to prevent unintended use of the dryer.You can also use the Control Locked feature to prevent unintended cycle or option changes during dryer operation.
To enable the Control Locked feature when dryer is running:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
The control is locked when a single beep is heard and the Control
Locked status light is on.When the dryer is off,it is not necessary
to press the Control On button before activating the Control Locked
feature.
To unlock:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds to turn this feature off.
NOTE:
When the dryer is running and Control Locked is on, the dryer can be
stopped by pressing the Pause/Cancel button,but can't be restarted
until the control is unlocked.
Apr 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have Whirlpool Duet dryer,model GEW9200LQ0. At first, it would stop drying when I set it on a particular drying mode (permanent press,delicate, etc.)but it would stop before the clothes were dry. Then,...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 17, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GEW9200LQ0 Dryer
can oyu oppen the door nad physically push in on the door switch( little grey switch atop the door opening). do you hear it clicking on/off??? if not you have a bad door switch.
Mar 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Starting dryer
you need to replace the motor
Dec 17, 2007 | Dryers
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEW9250 Electric Dryer Logo
278 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
