Question about Dell Dimension 2350 PC Desktop
Dell dimension 2350
Im trying to replace the power switch but im not sure where it goes plugged into the mobo its a blue 9 pin connection n please help if u can thanks
    Sergeant:
    Champion:
  • 362 Answers
If you use a flash light and a magnifying glass all the conection pins will be labeled ;like AUX in, for auxillary in which is usually for usb ports and plug and play items, then there will be a power reset set of pins for the reset button, and LED pins, and then your power should be labeled like wise. some times it wont be but you can look at the connector see if it has 3 or 4 wires and find the plug in that matches that has a u shaped metal place by it. its usually the power connection but if you are not sure take it to a professional so you dont cause damage.
Posted on Dec 08, 2007
  • james kilgore
    james kilgore Dec 08, 2007
    dell computers are bad for the power sw to fail.
  • james kilgore
    your 9 pin conection on the mother board should be easy to locate with the labeling and the size of the connector use a magnifying glass dont trust your eyes.
My Dell Dimension 2350 will start-up and show the Window XP start then goes to a blue gray screen. What could be the problem?
Please restart >prees F8>seclect last known good configaration by your up and down arrow key
and hit
hope it will help you
Nov 26, 2010 | Dell Dimension 2350 PC Desktop
Control panel connector pinout for Dell Dimension 1100
Well the official Dell manual can be found on their website here. I don't know if this helps or not, but I hope it does! :)
Feb 17, 2010 | Dell Computers & Internet
How to install a sd card reader on a Dell Dimension 8200 PC Desktop? no 4 pin usb on motherboard?
I managed to install a card reader on my Dell Dimension 8200.
The main problem is that the Dell motherboard does not have the correct USB pin. This is a 9-pin MoBo USB header.
The quick answer is I installed a USB card with an internal port.
http://www.amazon.co.uk/Unbranded-USB-2-0-PCI-Card/dp/B00066LPA2/ref=sr_1_6?ie=UTF8&s=electronics&qid=1264968643&sr=1-6
Secondly I reverse mounted a powered 4-port USB hub in the spare 3.5" bay.
http://www.cablecity.co.uk/product_info.php?products_id=1149&ref=6
Third, I purchased 2 USB 5 pin male to usb leads...
http://www.amazon.co.uk/v2-0-Male-Motherboard-Header-Connector/dp/B000QC7NKM/ref=cm_cr_pr_pb_t
You cannot buy a USB card with 2 internals and do away with the 4 port powered USB hub because the card reader does need to be connected to a powered USB port.
for more info see this...
http://www.mods-n-clocks.co.uk/?p=181
Jan 23, 2010 | Dell Dimension 8200 PC Desktop
No power -- Dell Dimension 3000
There's a few things you can check, check your wall socket, make sure it is giving out good consisten electricity, not flickery. Make sure you have a surge protected plug box or ext. cord. You just can't buy any pwr supply because Dell has an extra pwr supply lead that goes to the mobo on many models. Standard supplies have one bundle that has a double row of wires on the connector that goes to the motherboard, and all the rest go to hard drive;CDrom drive;floppy;maybe a procesor fan. Check your connections, make sure they are proper, if that doesn't work, it could be something damaged on your motherboard and you might have to change it. Depending on how your power supply failed, it can actually do some damage on the other parts but check everything first before considering that.
Oct 14, 2009 | Dell Dimension 3000 PC Desktop
Front panel connector J16 dell dimension 2350
Visit http://support.dell.com select your product and download user manual and maintenance manual. It may solve your problem.
Jul 15, 2009 | Computers & Internet
I need to put the start up power and leds on and i dont know how they r put ion the board l dimension 2350
first you need to go to the dell website and find a manual or guide to where to plug the wires into.usually you plug the cable into a strip of pins.they are usually at the front of the board.if you got
any more ques19153aa.jpgtions
just email me at gamecrazy944@yahoo.com
Jun 29, 2009 | Dell Dimension 2350 PC Desktop
Power pin etc. wiring connection
Visit http://support.dell.com and find the user manual in suport or download section for both device. (ehteshamhusain@gmail.com)
Apr 24, 2009 | Computers & Internet
Model name BLUFORD. E139765 motherboard. I need J16 pin layout for the power switch, reset switch, etc. Dell is not very helpful with this paticular board for some reason. Thank You for any info. DW
This is what I found after extensive searching,
......................O
.PWR LED- O O
.HDD LED- O O HDD LED+
.................... O O
.................... O O PWR LED+
...PWR SW O O PWR SW
.CON CNT O O CON CNT
Looks pretty lame, huh? I found this on Dell's Community Forum.
I gather, this motherboard was used in the Dell Dimension 2350.
http://support.dell.com/support/edocs/systems/dim2350/techov.htm#1101565
Looking, at what Dell has for the layout of the Dimension 2350 motherboard, there are 20 pins in the J16 header, just like he has crudely shown above. I don't see one missing in the corner, though. Of course, the link above is a crude example from Dell.
This person stated it was for the J24 header on the motherboard. Also stated that it was the Front Panel I/O header. (At least that's what was stated) I believe he was confused with the Control Panel header J24. Hopefully it is for the J16 Front Panel I/O header, as it has the Power On switch, HDD activity LED, Power LED, and so on.
Indications are that the O's represent the pins. There was a statement of taking -> Note, that there is a missing pin in the upper corner, and this orients the connector view, Orients, how you are looking at the connector. Only you will know for sure. I don't have this motherboard in front of me. Dell ISN'T giving ANY info out.
This person had the Bluford E139765 motherboard, in a Dell Dimension 2350.
The statement was also made, that there is a Brown jumper wire that connects the two CON CNT pins together, but didn't know if this jumper is required, as this person is putting this motherboard, into an aftermarket computer case. (?)
Solution?
What I would do.
I would have the power supply plugged in. I would use an LED lamp, with two wire leads attached to it. Leads of about two inches long, or more. (Borrow one out of the Front Panel, or from another parts computer?)
Twist the ends of the lead wires tightly. I would then touch the leads to two pins. Should they be power Out pins, (HDD activity lamp pins. Power LED pins, and so on), the light will light up, and not short out the two pins touched.
(If the LED light doesn't light up, no biggie. It just means the wires need to be reversed. Bear this in mind, when you go to hook the LED's up)
When the two pins for the Power On is found, the computer will turn on.
Judging by the crude diagram the missing pin is on the upper right.
Only you will know for sure, as the J16 header should have a flat place in one corner, where a pin would go. NO pin.
If so, this is what I see.
Processor to the left, PCI slots to the right, J16 header on the right, above the PCI slots. The header goes along the edge of the motherboard, lengthwise.
I'll number the pins like this.
Starting at the Top Left, and going down the Left side.
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19.
Starting at the Top Right, and going down the Right side.
NO pin, (Would have been Pin 2),
Pins 4, 6, 8, 10, 12, 14, 16, 18, and 20
Pins 3 and 4 are for the Power LED. (Confusion here)
Pins 5 and 6 are for the harddrive activity LED. PIn 6 is for the + wire/
NO connection to Pins 7, 8, 9, and 10
Pins 11 and 12 are for the Power LED.
(Which ones to use? Pins 11 and 12, or Pins 3 and 4? I leave it up to you to test as the computer is on, and see)
NO connection to Pins 13 and 14
Pins 15 and 16 are for the Power On switch.
NO connection to Pins 17 and 18.
Pins 19 and 20 are for that jumper wire he mentioned. I would try it without it. If the computer doesn't come on, or something doesn't work, like the harddrive for example, I would unplug the computer from power, then attach this jumper. Plug in, and see if everything works.
Apr 19, 2009 | Computers & Internet
My Dell Dimension 2350 no longer powers on. Yesterday it powered on ok and powered off ok. My guess is the power supply is bad. Checked the power cord (with a voltage meter) and 117 VAC is at the end...
Dell has this great tool where you can troubleshoot an issue in a methodical way, step-by-step.
Here is the link to troubleshoot No Power, No POST, No Video [Dell Dimension 2350 Desktops] Just follow the steps and choose the option and continue. Remember not to skip any step since each of them has a purpose.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&journalid=6445B6E320AC44A4E040AE0AB8E12519&treeid=4F62A0ECE60449EE8150A94E91B6BD27&Query=bm8rcG93ZXI=&SystemID=DIM_PNT_CEL_2350&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=true&dl=
Below is also a link to the Dimension 2350’s user manual.
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 04, 2009 | Dell Dimension 2350 PC Desktop
CPU fan not detected.....
The cpu fan has a three wire connector that connects to the mother board. Usually located to the right & up from the cpu. If yours is connected currently the wires may be miss aligned. From left to right the pins are: first pin ground/Black; middle pin 12v./Red & last pin rotation/Blue. There may be a bios update that address this issue. Dell does not give up information easly.
Jan 13, 2008 | Dell Dimension 2350 PC Desktop
Dell Dimension 2350 PC Desktop Logo
89 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
