Question about Garden
Low engine oil how do u reset it on gx160 honda pressure washer
    President:
  • 583 Answers
How do you reset what?if the engine oil is low you top it up to the bottom of the filler plug hole, just so it tries to run over ,then tilt the motor back slightly and put the filler plug back in,
Posted on Sep 10, 2009
Honda gx160 5.5 hp getting too hot
On most of these engines since they are air cooled you need to have all of the metal shielding that came with the engine on it. These help direct the flow of air from the flywheel fins to cool the engine. You may have to remove the metal shields and clean the fins if you have an older motor that has been run in really dirty areas. If air can't flow between the fins it can't cool. I will mention oil level just because oil also helps cool the engine how ever most of these engines will not run if the oil is low due to an oil pressure switch that prevents it from running if the oil level is too low.
Dec 30, 2014 | 5.5 HP GX160 Engine
This is a honda gx160 driving a generator. Engine starts OK but when any load is put onto generator engine splutters then stops. Display says low engine power. Any ideas?
check oil level .low oil causes vacuum in the carb, causing fuel starving .
also check capasator has not blown in generator .
Jan 16, 2014 | 5.5 HP GX160 Engine
Why does my honda gx160 start and run for minute or two then cut off. Will restart
Hi, check the oil level. If low the oil guardian is cutting the spark. Regards Phil.
Aug 19, 2012 | 5.5 HP GX160 Engine
How to check oil on honda gx160
There is an oil dipstick on the side of the engine. Remove the dipstick and check the oil on the dipstick.
The oil should be about half way up the threads on this engine.
If you need to add oil you can use SAE 30 or a 10W30 Oil.
Mar 28, 2012 | Garden
Pressure washer with Honda GX160 5.5 HP OHV-Starts easily but...
what about the linkage between the governer and the carb. Is that working and not binding?
Dec 20, 2009 | Honda Pressure Washer PSI 3000
Gx160 Pressure Washer runs fine for 20 seconds Then shuts off
It could be several things...oil level, make sure its sitting on level ground...if not did you use StaBil when you laid her up for the season? If not, go to Advance Auto and buy "SeaFoam" and following directions run it for as long as it will run...make sure you have water running through the pump during tests!
Good Luck
Jun 14, 2009 | Honda Pressure Washer PSI 3000
Engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
May 28, 2009 | Karcher 2500 PSI Pressure Washer
Can't start the Honda GX160 5.5 HP Electric motor on my Chore Master 2400psi Pressure Washer. Got gas (checked through feed line), new spark plug, switch on, gas, choke ok, throttle a bit funky (about 12...
Is there an oil sensor unit if it is going bad it tells the engine the oil low and engine wont start. I had same problem with my pressure washer, i just unplugged the sensor unit and it started fine ever since
Apr 27, 2009 | Garden
Honda powered gx160 model pressure washer wont start
Buy a new plug, drain out all of the old gas and put in new gas, and take a look at the air cleaner. If the air cleaner is dirty replace it. There you now have a good spark, good fuel and good air. The engine should start. If it doesn't get some carberator cleaner spray and some starting fluid spray.
Apr 12, 2009 | Honda 8 HP Engine
Garden Logo
319 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
