Question about LG CHOCOLATE VX8500 Cellular Phone
My phone tells me to set the bluetooth in discoverable mode don't know how to do that. lost the instructions for bluetooth
How can I enable the Bluetooth in my handa forza 2007 motorcycle?
follow this instruction. God bless you
To turn on Bluetooth discoverability, first key on the motorcycle. Leave the kickstand down and the kill switch off to keep the motorcycle disarmed. Toggle the Mode switch back and forth between Eco and Sport modes at least 12 times. Once the motorcycle is discoverable, the green "Armed" light will flash for a few seconds (except on FX and XU models. With the FX and XU models, the red warning light will blink slightly faster). It may take up to 10 seconds for the motorcycle to become visible to your Bluetooth device.
Once discoverability is enabled, the motorcycle will remain discoverable until paired with a phone, or until the motorcycle is switched off. Once you have paired your phone with the motorcycle, you will not need to repeat the discoverability process to connect to it.
Jul 20, 2013 | Computers & Internet
Blutooth not searching any device
Make sure the device is in discoverable mode.....should have instructions with blue tooth device to tell you how to make it discoverable. Most will have to hold the answer/hang up button until a light on the bluetooth flashes. Then it should be ready to be discovered.
Jan 02, 2013 | Samsung star II duos GT-C6712
I cannot pair my verizon IPhone 4 with my 2008 Acura MDX bluetooth. The car cannot find my phone...
You need to make your phone "discoverable" to your bluetooth. Go to settings menu on phone , then wireless and networks. Click on bluetooth settings and click " discoverable mode". The car will never find your phone if your phone is not discoverable. Hope it helps.
Jun 20, 2011 | 2008 Acura Mdx
Cannot pair my iphone 4 with jabra sps5050
The reason is you need a four digit code in order to pair your Bluetooth to your phone. Also, your phone has to be 'Able to be found', ie, set your Bluetooth settings on your phone, so that the phone is in 'Discoverable Mode' and ensure the Bluetooth setting itself is also turned on.
Once your phone is Bluetooth discoverable, try and pair the devices again. Your phone will find your headset and ask if you would like to pair the two devices. Obviously, select Yes/Pair and it will then require a 4 digit code for authentication. With Jabra the code is always "0000" (4 zero's). Once you enter the 4 zero's, the two units will then pair successfully.
Let me know if you require further assistance.
Feb 18, 2011 | Jabra SP5050 Bluetooth Headset
How do I set up pairing mode with my bluetooth headset? I lost the instructions over a year ago.
Press and hold the power-on button for 10 seconds or until the LED starts blinking. This places the headset in Discoverable (pairing) mode, and you can then search for it from your phone.
If this helps, please be sure to hit the "thumbs-up" for me!
Jan 24, 2010 | GE Bluetooth In-ear Headset Wireless...
How do I know if my bluetooth is in pairing mode
The Explorer 220 is not in discoverable mode until the light is flashing alternating between blue and red. This is done by holding the button as long as it takes.
So, the steps to pairing the phone should be as follows:
1 - Power on bluetooth on your phone. With most phones this is done by finding "Bluetooth" in the settings and tools menu and choosing the option for "on"
2 - Put the headseat in discoverable mode by holding the button for at least 30 seconds to a minute. The light should be flashing and alternately turning blue then red
3 - Then you may have to tell your phone to search for any discoverable bluetooth devices (warning if you have a computer or netbook with bluetooth capability your phone may find that too) be sure to wait until the phone shows "Plantronics" or "Headset" as an option
4 - Choose that option and click ok. Your phone will try to "auto pair". If that is unsuccessful it will ask for a code. That will typically be four zeroes (0000) for this particular headset.
The phone will tell you when pairing is successful.
Nov 01, 2009 | Plantronics Explorer 220 Bluetooth Headset...
How do i set my blueant supertooth in discoverable mode? Lost the book and got a new verizon phone. Thanks!
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etc
Sep 24, 2009 | Blueant Blue Ant 091022 X3 Micro Bluetooth...
Installing bluetooth
You need to power on the bluetooth headset, make sure that it has a solid LED light on it. Power on the phone and go to the bluetooth settings, search on the headset, it will ask you to enter a pass code, just enter 0000 that is the default code for that.
Jul 07, 2009 | Cell Phones
Maual for Motorola H350 bluetooth headset
To pair your bluetooth with your new phone...
Step one: make sure bluetooth is fully charged. While off, press down and hold the mulitifunction key on the bluetooth until light remains on.
Step two: put your phone in discoverable mode and click on add new device to search.
The phone will then find the bluetooth.
Jan 17, 2009 | Motorola Mobility H350 Wireless Headset
Trying to pair omnitech 2.0 bluetooth headset without manual
before attempting to pair your headset with another device, be sure that the bluetooth headset is in the off position
  • press and hold MFB until indicator light flashes blue and red. The headset will also beep twice
  • to pair your device to the bluetooth headset use the bluetooth pairing instructions from you device's instrucition manual.
  • input ID code 0000 when requested by the device
  • the headset and device are paired correctly when the blue and red indicator light flashes blue only.
Any questions email: shyrosi@yahoo.com Subject: omnitech bluetooth
Dec 29, 2008 | Motorola Mobility RAZR V3
LG CHOCOLATE VX8500 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
