Question about Samsung RS2630SH Side by Side Refrigerator
Defrost lights for both frig and freezer flash for approx 90 mins twice a day and both defrost this is after being repaired  (2 electric components) It flashed all the time before.Is this normal?
  • 833 Answers
Could be. Is the unit working right otherwise? Sometimes replacement units (field service components) do different things than factory. Flashing all the time seems wrong, though.
Posted on Dec 19, 2007
Maytag side by side msd264rheb freezer works frig isn't cold. We found ice on bottom freezer side and did melt it with a hair dryer. Frig vent is letting in, now a little cool air, but not a lot.
If you found ice in the freezer then there is usually a lot more behind the back plate. If you let it defrost completely it should work good for a couple days until the ice builds up again. you more than likely have a deefrost issue. There are usually nthree components in a typical defrost circiut. The heater, defrost thermostat and a defrost timer or control. one or those is bad.
Jul 28, 2014 | Maytag Refrigerators
Have extra older Frig in th garage Mod 596.72232200
Sounds like a intermittent problem with the defrost timer. Sometimes they get stuck. Check continuity of the defrost heater and defrost thermostat. If both are good then replace the defrost timer, that should solve the problem.
May 30, 2014 | Refrigerators
We have a kitchenaid side-by-side. It stopped cooling. We just received and embraco invrt box, and replaced it. The frig worked fine for 2 days (we checked temp) and it was good in frig and freezer. Then...
If the fridge was off and then worked (it defrosted) so it could be the defrost element, is not working. When that freezes up, it won't circulate the air to cool it.
Oct 21, 2017 | KitchenAid KSBS25FK Side by Side...
Frig cools works great all day then trips the gfci
Hi Sturkle;
Does this happen say- every 6-8hrs? If so you may find the defrost element has a short, or defrost timer is faulty. Defrost element is located in the freezer compartment, Time located an back of fridge.. Use a qualified person when playing with electrics...Cheers
Mar 29, 2010 | Whirlpool ET8GHMXLQ / ET8GHMXLT Top...
Neither freezer or frig is working each has its own compressor.
No Colin,
It has two evaporators with one compressor. Your thinking, or was told by the Sales Staff "Its like a Sub Zero" Right?
Sorry for the confussion Brother! I get that alot.
Your problem and symtoms sound like a auto defrost malfunction if you can hear the compressor running.
OR if Compressor is not running and you hear a periodic "Hum followed by a CLICK" at the compressor. Replace the PTC Start Relay on the side of the compressor.
You tempertures have increased to the point that the electronic display is giving you the "ME DEAD" ME CLOSE MY EYES NOW!
If you unplug the frig or shut down power to the frig. The PCB will return with "Set Temp" then show current temp!
Compressor should start in 5 min. If so wait to see if the reading start to come down to normal. FZ=0 RF=37
Problem maybe Main PCB
If after several hours and NO reduction in readings, UNPLUG the Frig
to totally defrost itself for several days ( what's a couple more days)
YES A COUPLE OF DAYS, THE EVAPORATORS ARE INCASED IN STYROFOAM a well know insulator> Watch for icewater draining into the "Non-Removable" Drip pan under the compressor in the back. Remove the rear cover to expose and suction water out with a baster or wet vac on occasion. If you get a full pan of water> YEP Defrost Malfunction.
You can plug the frig back in after water stops dripping. Watch your display it will almost immediately start dropping in readings.
The Frig will work again for how long it takes to ice over again. I say 1 -2 weeks depending on humidity and how it takes you to make up your mind on what you want to eat?
Since the resolution and repair is so difficult I RECOMMED CALLING:
1-800-SAMSUNG and schedule a visit.
Why you say?
Well if the Compressor went bad and is less than 5 years old,>IT"S UNDER WARRANTY.
IF the Ref Side Evaporator Heater is Shorted It's a Evaporator Replacement (Heater not available seperate) > WARRANTY AGAIN.
So, Looking at the post date, You must of had it repaired by now?
What was it?
Hope this helps!
Seen It B4
Your Welcome
Dec 04, 2009 | Samsung RS2578BB Side by Side Refrigerator
Fresh food compartment is not cold
Good day,
Not as much info as I would like, but here's a good list to get started with.
Note: Assuming the freezer is at or near normal.
1. Lights do not go out when door is closed. Can be tested by checking just before door closes completely.
2. Air circulation fan motor in freezer compartment, not running.
Can be heard when opening freezer door when machine is running.
Remove rear panel in freezer compartment, and repair or replace as necessary.
3. Most common. Defrost system failed.
The Auto defrost system is made up of three components.
1. Main heater, located behind the rear panel in the freezer compartment. 2. The defrost thermostat (often called a terminator) located on top of the evaporator coil which is located in the same area as in #1. 3. Defrost timer (either mechanical) or electronic) located in the fresh food compartment. This device initiates the defrost cycle once to twice a day.
Go to.... with the complete model number of your machine to identify the location and style of your components.
Nov 17, 2009 | Kenmore Refrigerators
My Kitchen Aid KSCS25INSS will defrost the freezer up to 57 degrees sometimes twice a day. I cannot use the ice maker because I end up with a large block of ice after one or two days.
57 degrees is pretty hot. If it occurs on a regular basis day to day, it sounds like a defrost cycle malfunction.
There is a calrod heater imbedded in the evaporator coil behind the panel in the freezer compartment. It comes on approx. 2 times a day. The compressor is shut off and the calrod (which looks a lot like the bake element in an electric range) is turned on. It gets quite hot, but a thermostat mounted on top of the evaporator coil, shuts the heater down when the coil reaches approx 50 degrees. If this thermostat ( often called a limiter ) fails to open in time, the temperature in the freezer coil box can easily reach 100 degrees or more. If so, this could be your problem. Remove the rear panel in the freezer compartment aand locate this small disc thermostat and replace with new.
Oct 28, 2009 | KitchenAid Superba Architect KSCS25INSS...
We have a 1999 Whirlpool side by side refrigerator and Freezer. Model number ED25EQXFW02. Last night the Refrigerator and Freezer stopped cooling and freezing. After taking everything out of the freezer,...
Usually when the freezer is still giving cold but the frig is not receiving cold you have an ice build-up on the cold (evaporator) coil that is hidden behind the rear panel of the freezer compartment. If you push on this panel, you usually will hear a cruntch sound (this tells you there is ice/frost on the coil). There are 3 components that affect this problem: defrost timer, defrost stat, defrost heat coil. In other words, something is not working to remove the frost from the coil and it is building-up day after day (takes about 5-7 days to become full (blocked). When this happens, no air can move over the coil to take the cold away and blow it throughout the frig or freezer compartments.
To access the defrost coil or stat, you have to ren move the back panel (in the freezer) and remove all the ice with a hair dryer only or let the door open all day and allow it to melt. DO NOT PUSH OR PRY OR CHOP WITH ANY TOOL OR YOU WILL BE GARRANTEED TO PUNCTURE A HOLE IN THE COIL AND YOU ARE REALLY SCREWED. The time is either: under the front of the whole refrigerator, or in the frig compartment (towards the back or attached to the ceiling of frig compartment). If you have some experience with electrical parts, you can test to see which part is at fault. Good Luck. Macgivor
Oct 11, 2009 | Whirlpool Refrigerators
Samsung frig stopped cooling-
most new fridges have a self defrost mode once or twice a day because the coils ice up if it collects alot of moisture. it shuts the compressor down and turns on a heat coil to defrost (which can take up to a half an hour). usually on a timer that is adjustable.
Jul 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
also check defrost timer,defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 01, 2009 | Frigidaire FRS26R4A Side by Side...
Samsung RS2630SH Side by Side Refrigerator Logo
78 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
