Question about Ricoh Aficio 450 Copier
Drum is black afico 450
Sir
AFICO 450 we have problem after some copy drum is black the i remove the toner after 20 copies drum clean when i fix the toner soo same problem drum is black please solve my problem thankx.
  • 162 Answers
Disassemble the cylinder of the image unit and review if the gears of the recycled of toner were not damaged, you accustom they are broken and they caused that the blade fails to be saturated of toner that section. If it is thus it also cleans with a vacuum cleaner the bushings of the spiral and the overturned trowel of until they are light.
Posted on Sep 10, 2009
    Scholar:
  • 78 Answers
Replace drum cleaning blade and drum cleaning unit, charge roller ect.
Posted on Sep 06, 2009
    President:
  • 3,085 Answers
You need a new drum CLEANING BLADE
Sir, I am getting black patch on right side of the paper when I take xerox. Please reply
is these black patch like the toner isnt baked and it peels of the paper?
If yes, you have problem in fixing section, probably fixing rollers bushing.
Also remove the drum unit and check drum for toner leftovers. If the drum is covered with toner after copieing replace drum unit.
Hope that helps!
Aug 03, 2010 | Canon imageRUNNER 400S Copier
After changing toner on my sharp, SF-2022 copy machine, the copies are coming out with black smudge marks across the paper? how/where should i clean?
This means the machine is over-toning ie using more toner than required caused by either improper toner or different brand of toner. The correct toner is sf 222T1. Replace developer and use the right toner and clean the drum and its blade. You may need to clean fuser rollers for cleaner copies.
Nov 13, 2009 | Sharp Office Equipment & Supplies
Drum is black
Hello sir; it is the time to replace developer.pull out developer unit ,right underneath drum unit, remove two snap clip open the ccover dump old developer clean out inside the unit with vaccunm cleaner. then fill in new devloper the simulation2801 & 2805.
Sep 06, 2009 | Ricoh Aficio 450 Copier
Afico 2015- i am getting lines on the copies... optic are clean
Cleaned optics means the three mirrors in the scanning section and the laser **** glass right? This can be done by removing the platen glass.
Aug 28, 2009 | Ricoh Aficio 2015 Copier
Just changed toner and copies are black
Hello sir; Your machine need to clean mirrow, replace drum and drum blade.
Jun 01, 2009 | Panasonic FP-7735 Black and White Copier
Developer....
When developer goes bad you use more toner for one thing, but the main sign is a gray background in your copy. The print should be black but appears to be gray. The ricoh 350/450 was always noted to leak toner and developer as it runs. Check your machine and see if you see any small piles of toner, which also has developer in it, in the machine. Ther are small seals made of felt that need to be replaced if you have this problem. These seals rub against the drum sides....Good luck.
Jul 20, 2008 | Ricoh Aficio 450 Copier
N 450 aficio
Have you replaced the opc drum lately?? The toner density is looked at on the drum with the ATDC sensor. It seems like your tring to adjust the toner density. That is just a band-aid. try to replace the developer and if needed the opc and clean the drum unit and the ATDC sensor. You shouldn't have to readjust in the service mode.
Jul 10, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
202 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
