Question about Garden
The pump shuts off for awhile and then turns on again by itself
  • 4 Answers
It's overheating most likely it needs a new motor. But check hair and lint pot first.
Posted on Sep 12, 2009
Testimonial: "Thank you for the reply. You are probably correct, but I simply cleaned it and re-adjusted its place in the water feature and now it costantly works."
Fuel question
Put line anti freeze.Could be crankshaft sensor.
Apr 28, 2013 | 2008 Dodge Ram 3500
P0301 code on vw beetle
may need fuel pump replaced. have a pressure test done on fuel system to see if that is the problem. In alot of cases a weak fuel pump that has not gone out completly will fun fine at first then after awhile will shut off. In some cases it will run fine and just shut down. Usually after awhile of setting it will start again and do it all over again. hope this helps and good luck
Aug 13, 2012 | Volkswagen New Beetle Cars & Trucks
The car shut down while making a sharp right turn but fired right back up and ran albiet roughly with the check engine light flashing for about 3 miles then shut down again going up a short gradual...
Flashing for awhile?
Don't you always start will check light issues first,
& resolve them?
There are codes sometimes even without check lights
You need a professional scanner or PC Scan Software
The fuel pump may be seizing up mechanically or have an
elcetrical issue,such as worn out. Again an Oscilloscope would
be nice there also
Jul 11, 2011 | 1997 Oldsmobile 88
The tv shuts off by itself. I will turn it on..and after awhile, it just turns off by itself, and then after about a minute I can turn it on again and watch tv for awhile, and then it will do it again.
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The faulty component(s) are heating up, tripping the fault control, and shutting down, it cools down again,and will restart, then the process repeats, it will eventually fail fully.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Mar 04, 2010 | Televison & Video
Nothing inn the canister after using,suctione working,bottom roller working,no air leaks from hoses.Also when running awhile it shuts off by itself,have to wait awhile to use again
I'm not sure what vacuum you have, but that sounds like a blockage to me. Thermal shut off kicks in, shutting the motor down, to prevent damage from overheating. After waiting like 1 hour it probably comes back on. Make sure hose, filters, bag (if any) is clean. All "airways" of vacuums need to be clear of any blockages, since airflow is what makes vacuums work.
Apr 18, 2009 | Vacuums
Turns off randomly
mine does also does yours click at random times and the screen goes out in small places for a split second?
Apr 02, 2008 | JVC AV-32020 32" TV
RCAD52W19BYX1 model #
1 can you clear that you see white lines along with green light? 2is your set is totally dead?
Sep 14, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Garden Logo
418 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
