Question about HP Photosmart 7450 InkJet Printer
Paper Jam or rolls through HP Photosmart 7450
My printer will not print anything. The paper just just keeps rolling through with no print on it. I have replaced all ink cartridges but it still will not print! I kept getting alot of paper jams, now the paper just continuosly rolls through. I've opened it up and vacuum and blow air into it and still no solution.
My hp photosmart 8250 keep showing paper jam but there's no paper jam anywhere. How can I get it to function properly?
Make sure there is no paper stuck inside in the paper. may be there is small piece of paper stuck inside
Just unplug the power and open the cover and remove the toner or cartridges from the printer and manually try to roll the roller and remove the paper.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 17, 2010 | HP Hewlett Packard Photosmart 8250 InkJet...
Printer takes in paper then fails to print and reports a jam.
Hi
If it keep saying paper jam Then it maybe just that you may not see any paper in it but it only takes a very small bit of paper that stopping it or I would take a closer look inside, you may have had a paper jam before and it has left a small nit inside. All Best: Pineworks
Feb 01, 2010 | HP Photosmart 7450 InkJet Printer
Paper Jam? Print quality
If the toner wipes off the printed pages, then the fuser is the problem....not hot enough or enough pressure to heat the toner to the paper. I would try to reseat the fuser...make sure it is making good electrical contact. I have also seen the paper actually wrap around the fuser roll, which would cause the same symptoms...be careful removing the paper if that has happened...the fuser roll can be easily damaged !
Jan 22, 2009 | HP LaserJet 2840 All-In-One Printer
Documents are printing slanted on page
It sounds like need some technical maintenance and at that point you have two options.. take it to a service center, or buy another printer (or if whithin warranty talk to HP about your problem, your attempts to fix it and possibly get it replaced). sounds like a component inside your printer may be either not working properly or there's something inside keeping the rolling componentes from keeping the page straight as it goes through your printer.
It does not sound like a driver problem...
btw.. did you mean carriage jam or cartridge jam??
if it was carriage:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00054450&lc=en&dlc=en&cc=us&rule=8331&product=303753
if it is a cartridge error try check the following:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02180&lc=en&dlc=en&cc=us&rule=8331&product=303753
Nov 26, 2008 | HP Photosmart 2410 All-In-One InkJet...
Paper jam
This video explains how to resolve a recurring paper jam on your product. It sounds like the rollers on the rear access door may not be working properly and are making jamming the paper as it starts to feed up into the printer? Check the rollers on your rear access door and see if they have some give in them and roll freely.
Sep 27, 2008 | HP Photosmart C7180 All-In-One InkJet...
Cannot print anything. Paper goes in halfway and then says 'paper jam'. Checked back - no jammed paper. Keeps on doing this. Have been in to cancel print but keeps saying paper jam. Have tried a print test...
Dear Customer,
you ahve to use batter quility papers for prints,
cause when paper fixed up your printer says its jammed but as realesed its says printing but when ALL THINGS DOIN VERY FAST JAMMING & PRINTING ITS SEEMS LIKE PAPER JAMED ALSO SAW YOU AS PAPER JAMED,
so try to check your inner cartrige,ink & paper rolls,batter quility papers you ahve to use,
THNX
May 18, 2008 | HP Computers & Internet
Problem with HP 7450 and "Paper Jam"
hi, mezz
try this
There are 2 different types of flashing patterns with those two lights on the printer.
Resume light and power light BLINKING ALTERNATELY
Problem: Paper is jammed in the printer.
Resume blinking SIMULTANEOUSLY with power light
Problem:
The print cartridge carriage is stuck.
Solution:
1. Open the top of the printer.
2. Remove anything that is blocking the carriage path.
3. Turn the printer off.
4. Turn the printer on.
Problem:
There is something wrong with the printer. (I didn't write it, I am pulling this from actual HP tech documents, so don't blame me on this one) :)
Solution:
If the printer will not turn off, unplug the power cable from the electrical outlet or wall outlet.
Unplug the power cord from the back of the printer.
Wait about 30 seconds.
Plug the power cord back into the wall outlet.
Plug the power cord to the back of the printer.
oke, post in me back
tq
cropp
Jan 24, 2008 | HP Photosmart 7450 InkJet Printer
TRACTION PROBLEM
The cam that keep the pressure between the roller pick up and the lower feed is the solution
Oct 22, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart 7450 InkJet Printer Logo
183 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
