Question about Jacuzzi LUMINOSA WHIRLPOOL SINGLE SPEED MOTOR WITH RIGHT SIDE PUMP AND CHRO
Moter does not turn ON
The moter has power but does not turn on
    Scholar:
  • 80 Answers
If the tub has an push in off/on button, the problem is the air switch which is attached at the back of the motor in a black box. If the control panel has touch buttons, the problem lies in the control box that controls the pump or the pump itself which might be seized. If you can unplug the pump from the control box, it can be plugged into an outlet to see if the pump works. Unless you are mechanically inclined it would be best to leave this to a pro.
Posted on Sep 06, 2009
Testimonial: "thank you, i well look at it to see if i could do it or not. thank you for the advice"
Moter turns over but wont start. and windos stops working after moter start.
02 ford/?
wont start, then starts. im confused.
check all fuses. first.
Dec 18, 2013 | 2002 Ford Explorer - XLT - Speed Grille
Auto 4 wheel drive will not engage. Just a clicking sound in right front panel
it sounds like u are getting power [the clicking is the relay]ur next step would be to go under the truck and find the moter on the transfer case .have someone engage the 4x4 and listen for the moter working.if not uplug the harness and see if u have power there when ingage or disen gage the 4x4 .if u do then it is most likely the moter or the spline on the moter witch then u have to remove,to check
Jan 22, 2011 | 1994 Ford Bronco
My 4wd stopped working ...any ideas....when i hit the button for either auto 4wheel or 4wheel hi the lights on the buttons just blink and it never goes into 4wd just eventually the light goes back to 2...
check the fuse for transfer case shift moter if thats ok
check the connections at the moter then have someone push the button while use a test light or
meter to check for power if you have power at the
moter and it makes no sound odds are bad moter
Jan 11, 2010 | 1999 Chevrolet Blazer
My old GE potscrubber 700 dishwasher stopped working
moter has probably locked up TAKE FRONT LOWER PANEL OFF AND YOU CAN ROTATE ROTOR/ if itis not free and rotates easly then the motor has failed / mm
Dec 07, 2009 | Dishwashers
Will fill up with water but will not spin and just makes a buzzing noise?
there are two possible problems one the lid switch might be broken there is a small tab front right corner of lid that goes down into a hole to operate the switch which i beleive is still good because you can hear the moter hum there is a drive coupling between the moter and transmission if you lean the machine back you will find black rubber debries in the middle toward the front of machine before taking apart unplug from power the pump has two clips that hold it on top of moter there are two screws in two clips that hold the moter to a metal plate next to transmission the wiring harness plugs in to side of moter the drive coupling can be worked off gently with a wide screw driver from moter and transmission each plastic piece has three
pins that line up and fit into a hard black
rubber center the trick is lining it back up and clipping the metal supports back on moter i normally clip the top one back on first gravity assist with correct placement of moter to reinstal bottom clip reattach wiring harness two screws in moter clips reinstall pump will probably have to turn moter shaft to align with pump reinstall pump clips
Dec 07, 2009 | Roper RAS6233KQ Top Load Washer
My washer is not spinning or draining properly, the timer is working, it will continue until it is in the off position but once it is my clothes are sopping wet. Is there a part I need or anyway I can fix...
if it is a top loader the moter controls the pump and spin u need to check power to the moter and clutch i.e if the moter runs but no spin the clutch has gone if its not geting the water out i can be the moter the best way to check is take the waste pipe out and put it in to a bucket and turn on the water should jet out if not the pump may be blocked try these first
Jul 29, 2009 | Kenmore 24032\24036 Top Load Washer
I have a Hotpoint WDM73 washer dryer, during a spin cycle the power cut out and it won't turn on again. Can you help please?
on a hotpoint the moter is three faze so if it is turning the power off this means that the moter could be damged between the windings u can get the moters off ebay from about 55 pounds
Jun 28, 2009 | Dryers
I need to replace brushes on a hotpoint aquarius wm32
pull machine out and make sure u remover the plug completley it is still live with the plug in and switched off throught the netural feed
at the back take off the botom white pannel made of plastic look in side pull the belt off the moter
there should be 2 10mm bolts remove these and tap the moter and it should slide out
remove the earth wire and the moter harness plug and pull the moter out it will go you might have to turn it this way and that once out there is two screws holding each brush remove and put in the new breushes replace the moter
to put the belt on there is two screws on the lid one each side behind a oval blanking cover these are hex head screws
once off put the belt on the moter pully first then on the drum pully and gide it on by hand turn the drum and the belt will spring on open the door and spin the drum by hand to make sure the belt is on correctley replace lid and back turn on power an try if this does not work the moter has gone try ebay i did for my hotpoint cheaper than trade on there
Jun 28, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Jacuzzi LUMINOSA WHIRLPOOL SINGLE SPEED MOTOR WITH RIGHT SIDE PUMP AND CHRO Logo
199 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
