Question about Ricoh Aficio 450 Copier
Drum is black
Sir
we have problem after some copy drum is black the i remove the toner after 20 copies drum clean when i fix the toner soo same problem drum is black please solve my problem thankx.
  • 162 Answers
Disassemble the cylinder of the image unit and review if the gears of the recycled of toner were not damaged, you accustom they are broken and they caused that the blade fails to be saturated of toner that section. If it is thus it also cleans with a vacuum cleaner the bushings of the spiral and the overturned trowel of until they are light. This does that all the values of feeding of toner behave of irregular way until saturating the developer.
Posted on Sep 10, 2009
    President:
  • Ricoh Master
  • 990 Answers
Hello sir; it is the time to replace developer.pull out developer unit ,right underneath drum unit, remove two snap clip open the ccover dump old developer clean out inside the unit with vaccunm cleaner. then fill in new devloper the simulation2801 & 2805.
Posted on Sep 06, 2009
2 Suggested Answers
SOURCE: drum is black afico 450
Sir, I am getting black patch on right side of the paper when I take xerox. Please reply
is these black patch like the toner isnt baked and it peels of the paper?
If yes, you have problem in fixing section, probably fixing rollers bushing.
Also remove the drum unit and check drum for toner leftovers. If the drum is covered with toner after copieing replace drum unit.
Hope that helps!
Aug 03, 2010 | Canon imageRUNNER 400S Copier
SEVERAL BLACK HORIZONTAL LINES ON COPIES
You need to locate the source of strikes.
1) remove toner crg., if it has black lines or dirts on drum replace drum.
2) check/clean copy glass
3) use flash light to check fixing section ( Left sideway of copier small doors ) if damadged replace fixing assy.
Jun 30, 2010 | Canon imageCLASS D320 Digital Copier
THERE ARE LARGE STREAKS OF INK ON ALL COPIES AND
The green roller is the drum which has a cleaning blade to remove excess toner, when the drum gets older it becomes clogged and will dump toner back out onto the drum. Just some info on it. Best fix is replace the drum, you could take it apart and attempt to dump and clean it but it's rarely worth doing that.
Jan 04, 2010 | Brother IntelliFAX 4100 Laser Fax
Copy light
Hi
When you were replacing the drum did you tuch the drum surface?Best would be that you take some toner on piece of cloth, and polish the drum, while turning it in good direction, that the cleaning blade can clean it.After you must let it copy about 50 copies.
You can try to replace the whole drum unit cexv14, or clean the laser unit.
Also could it be that the toner unit, or toner cleaning blade are not properly distibutes the toner accross the developing/toner cylinder.
Nov 26, 2009 | Canon iR 2020i Laser Printer
After changing toner on my sharp, SF-2022 copy machine, the copies are coming out with black smudge marks across the paper? how/where should i clean?
This means the machine is over-toning ie using more toner than required caused by either improper toner or different brand of toner. The correct toner is sf 222T1. Replace developer and use the right toner and clean the drum and its blade. You may need to clean fuser rollers for cleaner copies.
Nov 13, 2009 | Sharp Office Equipment & Supplies
Drum is black afico 450
You need a new drum CLEANING BLADE
Sep 06, 2009 | Ricoh Aficio 450 Copier
Just changed toner and copies are black
Hello sir; Your machine need to clean mirrow, replace drum and drum blade.
Jun 01, 2009 | Panasonic FP-7735 Black and White Copier
Poor copy quality - lines on paper
Hello sir; The problem is caused by drum cleaning blade, you need to replace drum cartridge or drum blade if you can.
Jan 23, 2009 | Canon NP 6551 Black and White Copier
No copy quality in my ir400
to improove copy quality
1: clan the cd unit & use fresh toner
2: clean the primary & transfer charging rollors
Nov 25, 2008 | Canon MF8180C Color Laser MFC Printer
Ricoh Aficio 450 Copier Logo
76 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
