I have a Sony KDS R50XBR1 WEGA 50 inch tv. The other day it shut itself off while I was watching it. Now I can't get it to turn on and stay on. The stand-by light will blink green 17 times and then the TV turns on for 1/2 a second then the stand-by light will blink red 4 times pause and then blink red 4 times pause etc. When it turns on for the half second I do get an image on the TV. Any idea what it could be? Oh and it did this a few months ago as well but that time I unplugged the TV for an hour and then it worked fine. This time that is not working.
  • ckabeth Sep 07, 2009
    Thank you for your reply. I took the back off and checked both fans. I didn't see anything preventing them from moving and the connections were securely fastened. I suppose the next step would be to replace the fan. Is there a way to tell which fan it would be or should I just replace them both? Are these parts that I will be able to find in an electronic store?
  • ckabeth Oct 27, 2009
    changed the fan and works like new now! thank you
  • 10,594 Answers
4 times LED blink error code shows that one of Fan is stopped as fans running is monitored by system control in TV.
Need to take off back cover of TV to inspect fans.
Please check fans connectors are attached securely or fan caught any wire in its blades that can stop it.
Fan can be stop if it does not get power volts.
Thanks.
Posted on Sep 06, 2009
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Sep 07, 2009
    electronic store?
    Fan rotation is observed and of course system control will give enough time to fan to spin (approx 3 seconds)
    You can observe what fan is not running by that way, Unplug from AC supply for couple of minutes, replug back in and turn ON TV while observing fans.
    Supply volts also need to be checked on fans connectors as if volts are missing fan wont be spin.
    If volts are available to fans, yet not spinning then need to be replaced.
    I do not think all fans can down at same time.
    Thanks.
    Once you located defective fan, let me know its location to provide you part number info and yes, Sony TV fans are available in parts shop.
    Shahid Electronics Oct 27, 2009
    Great!
I have a sony kds-r50xbr1 and the problem is that it takes about 1 min to turn on and the screen appears for a bout 1-2 sec and then shuts off to a black screen where the power/standby blinks continuously...
Its time to replace lamp in this tv because existing lamp has reached to end of its working life span and causing problem. If lamp got broken, you will see lamp light lit on tv front but weaker lamp cause above symptoms.
Lamp replacement procedure is easy and written in user manual.
Buy Sony original lamp for good and bright picture in tv.
Thanks.
Jul 23, 2010 | Sony KDS-R50XBR1 50" HDTV
Tv keeps self restarting after about 30 - 45
When lamp in TV become weak in result and consume more current then its rating , TV gets that symptom, on for few seconds/ minutes, shuts down and turns on itself.
Please replace lamp in TV as procedure is written in user manual of TV and its easy.
Let me know if you have further question.
Thanks.
Dec 13, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-R50XBR1 50 in. HDTV picture cycles on and off
It is clear symptoms of weak lamp in TV, replace lamp to correct that problem.
Lamp replacement is easy and written in user manual of TV.
Please buy Sony original lamp for TV safety.
Thanks.
Nov 17, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony kds-r50xbr1 turns itself off and then green light blinks 52 times
Just replace its Lamp and procedure is written in user manual of KDS-R50XBR1
F93087600 XL-5100 LAMP BLOCK
Lamp is available in Sony Accessories and price is $250
Always buy Sony original lamp for good picture in TV and avoid aftermarket / cheap lamps that can cause damage of TV circuits.
Click Sony Support to download Instruction Manual copy, if you want it.
Apr 22, 2009 | Sony Video Cameras
Sony 60" wega kdsr50xbr1 blinks red 4 times
Please check Fans are running in your DLP Sony TV as 4 times blinks shows that any one of four fans is stopped or not running.
Feb 10, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-R50XBR1 9 red blinks
Isn't that the idicator telling you that its time to change the dlp lamp?
Jun 28, 2008 | Sony KDS-R50XBR1 50" HDTV
Televison & Video Logo
Top Televison & Video Experts
