Question about Sylvania L181 18.1" Flat Panel LCD Monitor
My monitor will not shut down - screen stays white
When I shutdown my computer my lcd monitor will say to check signal then the screen will stay white even though I push the on-off switch on the monitor other than this the monitor works fine it is a westinghouse lcm 22w2 any suggestions would be greatly appreciated.
  • 555 Answers
You got a short circuit in one transistor located at the inverter area. The transistor is acting like a conductor and not shutting down the power to the back light inverter. If you are a technician and want to fix it, look for short circuits in transistors.
Good luck.
Posted on Sep 06, 2009
Monitor shuts itself down, "no signal" message.
nope. the resolution has bumped up for some reason out of range for the monitor. Does it only happen in the game? that might be a clue.
Feb 17, 2014 | Envision 19" Lcd Monitor H1981
I had a power failure in my area. When power was restored my pc booted up ok but the monitor screen only stays visible as it should for about 3 seconds, then it goes black screen. I have powered...
Close windows down. Wait 15 - 20 mins, then power monitor up but NOT windows. Screeen should say "NO SIGNAL in centre. If t does not, wait five mins If still no display shut down and wait another 5 mins. Then start monitor un ANDt windows.. All should be OK now, If not shut EVERYTHING down and disconnect from mains ovrernight. (PC riouter/modem,,,, EVERYTHING . 12 hours later, re-connetc in THIS order - 1.) MONITOR 2.) PC 3) ROUTER/MODEM Should be OK now.
Aug 17, 2011 | Acer X193W LCD Monitor
I start my computer and the monitor says no signal and even after i shut down the computer the screen stays blue and says no signal. any solutions?
Can you try this monitor with another PC or this PC with another monitor? We need to find where you lose your signal at first before going further.
Failed TV and monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Aug 30, 2010 | Hyundai ImageQuest L70N 17" LCD Monitor
Lcd screen stays on when computer shut down
Put the old screen back on to see if it does the same, if it does not, the the new screen may not be the exact replacement. Is the new screen used or brand new? Please post back.
Apr 29, 2010 | Computers & Internet
When I power off my LCD monitor, the screen goes all white, but once I turn the monitor back on it goes right back to displaying whatever it should on the screen. Or when I shutdown the computer it also...
If this has happened to two monitors on the same computer, then i dont think the problem is with monitors, i think the problem is with the graphics on the computer, i suggest uninstalling the driver for the graphics card in device manager and then restart the pc to see if that makes any difference. The divice manager in in the properties of my computer icon, just right click and choose properties, then device manager.
Feb 06, 2010 | Sylvania L181 18.1" Flat Panel LCD Monitor
Dell monitor goes white when computer shuts down
does the monitor stay white after shut down or does it go back to a black screen?
Jun 26, 2009 | Acer Aspire One PC Notebook
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
NO SIGNAL. SCREEN IS LIT WHITE.
Try to check cable connector from main board to controller board, Check entire main board resolder voltage reg. ic, check MCU IC, Scalar IC, EEPROM IC and Crystal Capacitor.
Nov 13, 2008 | AOC LM 520A 15" LCD Monitor
Problem LCD screen stays white bright after switch button is OFF ??
Some capacitors need to be replaced,which would have burnt out due to power fluctuations
May 12, 2007 | Samsung SyncMaster 710N 17 in. Flat Panel...
Monitor goes to white at cpu shutdown
The problem is in the "soft switch" technology: On some of Sylvania's newer monitors they have incorporated what is called "soft switch" technology. This allows your ATX power supplied computer to turn your monitor on and off using it?s software controls. Therefore, your monitor?s light will always stay on blinking even when your computer is off. The monitor in normal operation consumes about 80W of power; in the "OFF" state it will be reduced below 8W. The "OFF" mode of the monitor can be controlled by the PC input signal or by pushing the soft-power button to disable the PC signal control for manually turning off the monitor screen. Thus, when the monitor is in soft-power "OFF" mode it still consumes a very small amount of power. For the purpose of making it noticeable to the user that the monitor is in soft-power "OFF" mode, we designed the power indicator to provide for a slow blinking signal (every 2 seconds). If you need to totally turn off the power, then the power cord would have to be unplugged. The same is true of the PC itself, but the PC does not provide for notification while in "OFF" mode. Your monitor looks like it may be in need of repair, contact info: PTI Technologies Inc. 7372 Doig Dr. Garden Grove, Ca 92841 Phone: 714-799-3899 Fax: 714-379-6290 Hours: Mon - Fri 8:00am to 6:00pm PST
Nov 19, 2005 | Sylvania L181 18.1" Flat Panel LCD Monitor
Sylvania L181 18.1" Flat Panel LCD Monitor Logo
345 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
