Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Sony Grand Wega 60 inch LCD Projection TV goes dark and then back on every few minutes. The power light remains solid green the entire time. Is this the lamps going bad? It is about 3 years old with original lamps. Thank you!
  • 556 Answers
Most likely, buy you a lamp and install it yourself, the owners manual tells you how to do this.
Posted on Sep 11, 2009
55 inch Sony Wega rear projection tv...only stays powered on for a few minutes then goes blank, green light steadily burns and the picture is dark. Is it overheating? What do I need to do to fix this?
If its the model indicated here or one similar(kdf-55xs955) you may be seeing a lamp that is about to fail.
A lot of these just before lamp failure will get very dark and if bad enough the set will even shut off.
Mar 17, 2012 | Sony Grand WEGA KDF-55XS955 55" Rear...
Grand wega shuts off on its own
my 60 inch sony wega tv will shut off on its own after the tv has been on for like 30 min then the screen goes dark but the tv light is still on so what can i do?
Jan 28, 2010 | Sony Televison & Video
Sony Grand WEGA LCD TV goes off on standby every few minutes then comes back on
It sounds like you may have a failing power supply. It could also be that a connecting cable from one of the PCBs is coming loose. You can try reseating all the connectors to see if that helps. As for the power supply, you may have difficulty troubleshooting an intermittent problem, and should probably refer a problem of that nature to a professional technician.
Good luck.
Nov 28, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
My Sony 60in Wega Rear Projection is going dark every few minutes and the sound goes out. Can't find the owner's manual. What do I do?
Your suspect is the lamp. You will need part number A-1085-447-A....If the lamp fails to light or goes out, so will the sound.
Nov 11, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Turns off and on its own every minute or so.
hi..
This problem will be there in ur tv until you put in a new Lamp. Working fine since then.I Got it through Amazon from www.vanns.com..
thank u
rate me
Aug 23, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Ticking noise from TV - Sony 50' rear projection 1080p LCD
The problem is ht leakage . remove the ultar cap of the tube and clean both the tube and cap with wd 40. then reinstall cap using some silicon glue.
this will correct your fault.
Jul 11, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
1,270 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
