Question about Homelite Mighty Lite Lawn Trimmer
Trimmer wont stay running
Have to run on choke to run at all.mixture is correct;spark plug is good;cleaned filter and still the same thing;took it apart and need to know hom fuel lines go on carb.
  • sideyardmech May 11, 2010
    if the carb only has 2 lines the top line from the gas tank goes to the nipple at the front of the carb and the bottom line goes to the back nipple
    Problem Solver:
  • 5 Answers
The top line from the gas tank goes to the front nipple on the carb, the lower line from the gas tank goes to the back nipple on the carb
Posted on Sep 07, 2009
Weed wackier gas trimmer
didnt specify the make and model so generic answer ---check fuel mixture is correct --check the filter in tank is not plugging up--look for damaged / crack in fuel feed lines-look at spark plug --carb may need cleaning --exhaust port may need cleaning
Jul 04, 2016 | Garden
Will fire,wont stay running.wants to be full choked,open choke,it dies
Jerry, First thing to get is a new plug gaped correctly and try. Could need carb. adjustment, fuel filter replaced, bad fuel line(cracked/pinched), Dirt/faulty diaphragm in carb. plugged spark arrester in muffler,etc.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://answers.yahoo.com/question/index?qid=20090528073906AA0y882
Chainsaw will only run with choke
Stihl Chainsaw starts but won run
http://tekindoor.com/miscellaneous/stihl-chainsaw-troubleshooting
May 28, 2016 | Garden
Will not stay running
How dose it run with choke on Half? I would try adjusting adjusting air fuel mixture, but make sure you have clean air filter in it before any thing else.
Mar 29, 2014 | Ryobi 22 in. 26 cc Gas Hedge Trimmer...
Weed eater wont stay running
Here are a few things to check, that are solutions for your symptoms. Check, then clean or replace:
  • Fuel Filter - located in the fuel tank
  • Spark Arrestor - at muffler
  • Spark Plug
  • Carburetor - may need rebuild kit?
Look here...
And...
Sep 02, 2012 | Garden
Why wont my mcculloch tm210 strimmer run unless its on choke,once you turn the choke off it stalls
Because your carburetor is out of adjustment and/or needs to be replaced.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Jun 18, 2012 | McCulloch Garden
My gas trimmer starts but wont stay running
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, !!
Feb 20, 2012 | Troy Bilt Tb70ss Gas Trimmer
For awhile would only run on middle choke setting, then would start but wouldn't stay running, now won't start at all. has new plug, fresh fuel, clean air filter, seems to have spark. do these units have...
Yes they do have a carb,very small,normally buried near the fuel tank,the diaphram may need replacing on ebay try smallplantsalesuk they will have a carb kit quite cheaply,very helpful,have you got your fuel mixture correct,rgds
Sep 26, 2010 | Craftsman 25cc Gas Line Trimmer
Weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Redmax weed wacker wont stay running
Have these unit been stored with fuel in them or sitting around for a long period of time? If so the carbs may need to be overhauled. Also check for a clogged fuel filter and vacuum test the fuel lines for cracks.
Apr 12, 2009 | Garden
Homelite Mighty Lite Lawn Trimmer  Logo
189 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
