Question about Denon DRA-397
Desbloquear panel denon dra 39
Por favor, cómo puedo desbloquear el panel de mi amplificador denon dra 397. Hasta ahora he pulsado el botón OFF y simultáneamente los botones de los altavoces A y B, pero no obtengo resultado.
SOURCE: Stereo receiver is in a Panel Lock On mode and will not stay on
Hi, Press the B and the Mode buttons and then hit the power button.  This should unlock the panel....it worked for me.
Posted on Dec 30, 2008
  • 163 Answers
SOURCE: Standby light stays red and will not turn unit on.
Try to reset the macroprocessor. Unplug the unit from AC, hold both buttons SPEAKER A and SPEAKER B and plug the cord in outlet. After display flashes several times release the buttons. No result? - repair shop.
Posted on Apr 09, 2009
SOURCE: Denon DRA 397 Won't Turn On
me too did you ever get it fixed
Posted on Jan 06, 2010
  • 137 Answers
SOURCE: Denon DRA-397 - the stand by button light is
You may want to check your output transistors,They are the ones mounted to the big heat sink.With a ohm meter measure across one of the legs to another there should be no shorts.If you see anything burnt that channel will be bad causing the unit to stay in protect mode to prevent futher damages
Posted on Apr 22, 2010
dunnbiker
  • 8546 Answers
SOURCE: denon dra 397 shuts done
Let's understand this - you have an external volume control wired in series with each front speaker set?
Can you elaborate on their electrical characteristics?
http://www.retrevo.com/support/Denon-DRA-397-Receivers-manual/id/696dj087/t/2/
Page 24.
A + B 8 - 16 ohms
Posted on Jan 22, 2011
Nesecito codigo para desbloquear Garmin G60
por favor ayudemme quisiera que me mandaran un nuevo codigo de mi cel modelo garmanifone 01000846 ya que solo me pide el codigo y no lo puedo desbloquear antes podia escuchar musica pero ahora no por que no puedo accesar al sistema y si hay otra forma de que me lo reconosca por medio de cable usb por que ni eso me hace solo me reconose como cargador o sera por el mismo problema de que esta blokeado
Jul 12, 2011 | Garmin nuvifone Smartphone
Mi iphone en la pantalla solo le aparece una mansana con un circulo de espera ya lleva 1 dia
Si iPhone no encendera, ni las congelaciones de presentacion ni respondera 1. Apriete y tenga el bot?n de Hogar para por lo menos diez segundos, hasta que la aplicaci?n que usted utilizara deja. 2. Si eso no trabaja, iPhone de vuelta lejos y lo enciende otra vez. Apriete y tenga el bot?n de Sue?o/Estela encima de iPhone por 10 segundos hasta que un cursor rojo parezca, y entonces deslice el cursor. Entonces apriete y tenga el bot?n de Sue?o/Estela hasta que el logo de Manzana parezca. 3. Si eso no trabaja, reponga iPhone. Apriete y tenga el bot?n de Sue?o/Estela y el bot?n de Hogar al mismo tiempo para por lo menos diez segundos, hasta que el logo de Manzana parezca
M?s repone: Trate Esto: 1. Quite Sim Tarjeta 2. Contenga "en casa" bot?n de bot?n y En/Lejos juntos hasta que logo de Manzana parezca 3.
Reemplace Tarjeta de Sim 4. Contenga "en casa" bot?n de bot?n y En/Lejos juntos hasta que pantalla normal de tel?fono parezca.
Tambi?n, Trate esto: 1.) Cierre el iPhone 3G. 2.) Empiece iTunes 3.) Sujete EN CASA bot?n en el iPhone 3G 4.) Al mantener el bot?n de HOGAR deprimi?, el tap?n en el
cable de Sincronizaci?n 5.) Un mensaje pinchar? para preguntar arriba si quiere reponer. 6.) S?lo clic SI y el repuso proceso debe comenzar.
Apr 01, 2011 | Computers & Internet
Tengo un receiver denon avr1609 y quiero restaurar los valores de fabrica como puedo resetear
uno de los tres por debajo de las soluciones de trabajo para que el receptor
1. Para reiniciar el sistema, a su vez el receptor apagado por el peque?o bot?n on / off, no el bot?n de espera grande. Mientras que fuera de noche y pulse el bot?n directo puro, a la vez y sigue tomando con su mano derecha mientras presiona el peque?o bot?n on / off con la izquierda. Ver? el flash men? del receptor. Cuando lo ves flash dejar ir de la noche y botones de acceso directo puro y el receptor se reiniciar? si mismo a la estaci?n de radio 87.50.
2. Pulse el bot?n "Power" al mismo tiempo presionando el bot?n "Standard " y "Simulaci?n DSP" en el panel frontal de su receptor Denon. Estos botones tambi?n pueden estar ocultos debajo de un panel tir?n en funci?n del dise?o y el modelo de Denon que se utiliza. Algunos modelos de Denon requieren diferentes combinaciones de bot?n que se pulsa simult?neamente mientras se presiona el bot?n "Power", como el "Modo Surround" botones. Algunos modelos de receptor Denon no proporcionar? las instrucciones de restablecimiento en el manual del usuario, para encontrar las combinaciones de bot?n derecho debe ponerse en contacto Denon.
3. Pulse el bot?n "Power" para apagar el AVR-
Pulse el bot?n "Power" al mismo tiempo la tecla "altavoz A "y "Speaker B" botones. Espere a que el AVR-788 a la pantalla comenzar? a parpadear a una velocidad de alrededor de una vez por segundo.
Suelte los botones despu?s de la pantalla comienza a parpadear. El AVR-788 es ahora restablecer la configuraci?n predeterminada de f?brica.
Mar 15, 2011 | Denon AVR-1609 Receiver
Sele pone el codigo E 74
Con la consola apagada, presione y mantenga presionado el botón de sincronizar (la blanca pequeña)
Mientras sostiene el botón de sincronización de prensa el botón de encendido para encender la consola
Siga pulsando el botón de sincronización hasta que la consola ha arrancado por completo.
Durante el proceso de arranque de la consola debe borrar todas las actualizaciones no, lo que le permite utilizarlo normalmente.
esto debería ayudar si no la envía a Microsoft y por favor que sea rentable para mi ayuda gracias disculpas por mi español malo soy Inglés
Jan 16, 2011 | Microsoft Xbox 360 Console
Como puedo programar mi control de dish en la segunda tv la tv es panasonic
Hola mi nombre es Mayra Diaz con DISH Network. La manera m?s f?cil para programar el control de DIsh a su tele Panasonic es siguiendo estos siguientes pasos. Presione el bot?n de blanco de TV hasta que las cuatro luces se han prendido luego presione 700,734,673, siguiendo con el bot?n # localizado abajo del 9. Ahora intente subir su volumen para verificar si funciona. Los tres c?digos se tienen q tratar individualmente siguiendo los mismos pasos. Si tiene alguna otra pregunt? por favor escribanos.
Dec 13, 2010 | DISH Network IR Remote Control
Como puedo programar mi control de dish para mi apex tv
Hola mi nombre es Mayra Diaz con DISH Network. Con mucho gusto le puedo asistir programando su control a su televisor APEX. Lo primero que vamos a verificar es que su control tenga bater?as nuevas. Vamos a presionar el bot?n de TV es color blanco o cristalino, lo va a presionar hasta que las cuatro luces se prendan. Suelta el bot?n de tv y presiona 745, 743, 020, 731 siguiendo por el signo de numero localizado de abajo del n?mero nueve. Finalmente, trate su volumen. Recuerde presionar su bot?n de SAT para poder seguir usando las funciones de su sat?lite
Nov 28, 2010 | DISH Network IR Remote Control
MARCA ERROR 0xc18a0506 TRAE TINTAS NUEVAS :s
: Realice por favor el debajo de pasos: : 2. Apriete y suelte el bot?n de flecha hacia la derecha hasta que la presentaci?n diga "Men? de Configuraci?n de Sistema". 3. Apriete y suelte el bot?n "bueno". 4. La presentaci?n debe decir "estatus de fracaso de Hardware". Si no all? ya, Llave de Flecha sobre a "estatus de fracaso de Hardware
: 5. Apriete y suelte el bot?n "bueno" : 6. La presentaci?n debe decir "estatus de fracaso de Hardware: Vac?e. Apriete bueno vaciar". 7. Apriete y suelte el Bot?n "bueno". El mensaje cambia a "estatus de fracaso de Hardware Vaci?. Prensa Cancela para continuar". 8. Apriete y suelte el "CANCELA" bot?n como muchos veces como sea necesario, para que, o el "bienvenido a Photosmart Exprese" pantalla parece, o, el "Fracaso de Sistema de Tinta" pantalla parece. POR FAVOR no TRATE de IMPRIMIR EN ESTA ETAPA. 9. Utilizar el Bot?n del Poder, apaga la unidad y desenchufa el cable de energ?a el?ctrica de la espalda de la salida de impresora y pared.
HPRepDude: As?gurese de que realiza pasos de 2-9 y permiti? que sepa el resultado. El cliente: Visto bueno. Todo fue como si los pasos dijeron y ahora son apagado y es desenchufado. HPRepDude: 10. Espere 30 segundos para el poder de ser descargados y entonces tapan el cable de energ?a el?ctrica en la salida de pared primero y entonces en la espalda de la impresora 11. Encienda la unidad. La impresora puede demostrar mensaje "BOTON de PODER de USO Al CIERRE LA IMPRESORA" seguido por "visto bueno de PRENSA para CONTINUAR". Apriete bueno. 12. Si la impresora ya ha inicializado, entonces va al pr?ximo paso. Si no, la impresora comenzar? el "UN PROCESO de INICIALIZACION de TINTA de TIEMPO". Permita este proceso para completar y no interrumpir. Una vez que el proceso de inicializaci?n es completo, la impresora imprimir?
una P?gina Diagn?stica. 13. Para verificar impresora funcionalidad imprime una AUTO PAGINA de PRUEBA. : Realice por favor todos los pasos antes mencionados de 10 a 13.
Nov 24, 2010 | HP Photosmart C6280 Printer
No puedo activar mi router pongo el 192.168.1.1 y no lo acepta mi coputadora
Realice los siguientes pasos para restablecer y volver a configurar el router WNR1000:
RESET:
En la parte trasera del router se encuentra un pequeño agujero pequeño (que tiene un pequeño botón en su interior). Pulse el botón con la ayuda de un clip. y manténgalo pulsado durante 30 segundos. Después de 30 segundos, por favor, thebutton liberación y apague el dispositivo durante 5 segundos.
CONEXIONES:
1. Conecte un cable Ethernet desde el módem a la portof WAN del router (puerto aislado).
2. Conectar el ordenador al router mediante cualquiera de los puertos 4available. Por favor, asegúrese de que NO HAY CONEXIóN DIRECTA BETWEENTHE MODEM y los ordenadores (ya sea utilizando un cable Ethernet o cable USB).
3. Apague el módem y el router después de hacer theconnections.
4. Encienda el módem y espere a que las luces, y luego poder enel router.
Reconfigure:
1. Abra el navegador (Internet Explorer o Mozilla Firefox).
2. Acceder al router, por lo general con http://192.168.1.1 ultraperiféricashttp: / / www.routerlogin.com.
3. Entrar al router con el usuario como "admin" y contraseña "password" (por favor, tenga en cuenta que theusername y la contraseña distingue entre mayúsculas y minúsculas).
4. Haga clic en "Configuración básica" en el menú de la izquierda y select'Use ordenadores MAC Address 'de la sección' router de direcciones MAC.
5. Haga clic en Aplicar.
6. Una vez que se actualiza la configuración luego apague el router yla módem. Encienda el módem y espere a que las luces, el poder en therouter.
Espero que esto le permite ir en línea a través de la WNR2000 router.
Recuerdos
Anand
Mar 22, 2010 | NetGear WNR1000 Router
Mi ricoh aficio 1013 sale error SC 552, quisiera saber a que se debe eso....!
así usted tiene un problema con la unidad de fusión, antes de llamar a un técnico que usted podría tratar de restablecer el código al entrar en el modo de servicio y restablecer el código de allí. Siga los siguientes pasos y usted podrá fácil de hacerlo:
1. pulse el botón (amarillo [C] cancelar)
2. a continuación, pulse el número en este
orden 1-0-7
3. a continuación, pulse el botón (rojo [C] parada) y por algún tiempo, hasta que en la pantalla LCD no aparece el menú de servicio.
4. cuando vas a ver el menú de servicio en la pantalla, oprima el número 1 sobre la almohadilla de número de la tecla y presione (OK) y luego con el cursor de flecha derecha al lado del botón (OK) Pulse hasta que vea en la pantalla el número [5.Mode ], cuando este está en la pantalla pulse el botón [OK] y luego otra vez con la flecha del cursor al lado de la [OK] pulse hasta que en la pantalla aparecerá el número de [810. Perdí mi código SC] cuando este aparece, pulse el número 1 en el número de teclado (confirmar que en la pantalla que está escrito el número 1 y presione juntos la tecla [OK] y la tecla para seleccionar el tipo original (esta clave se encuentraen el marco del [Aceptar]) Ahora que usted ha reinicia la máquina por la que se escuchará el sonido como empieza cuando se enciende por el tiempo que los abetos también si usted no presiona la tecla junto obtendrá un [error] en la pantalla LCD si esto suceda, inténtelo de nuevo, si después de algunos momentos de tratar de que no son capaces de reiniciar la máquina llame a un técnico.
Jan 14, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
Como puedo apagar la tv y aumentar el volumen de la tv con el mismo control de dish network
Presione el botón de TV en la cumbre del remoto y sosténgalo hasta que todas las luces a través de la cumbre se enciendan y liberen. Ahora presione el pequeño botón de tv rojo th y la liberación. Ahora presione la flecha llave hasta que el tv apage. Ahora presione la flecha abajo llave una vez y luego la flecha llave. El juego debería encender. Ahora presione el signo de libra en el derecho de fondo del remoto. El botón de tv dirigirá tres veces. Usted ahora será capaz de controlar el volumen y girar tv lejos. Si la TV no lo apaga no es apoyado por el plato remoto.gracias por la utilización Fix Ya.
May 16, 2009 | DISH Network IR Remote Control
Denon DRA-397 Logo
133 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
