Question about Vehicle Parts & Accessories
Immobiliser problem with ford mondeo
My ford Mondeo R plate will not start. I have had two auto-electricians looking at it and they cannot find the problem, however both say that something is draining the battery overnight. Under the car there are wires that look like the imobiliser has been tripped. when you turn the key, there is no life in the engine for around 10-15 seconds and then it tries to start. with the right acceleration I can get it to start but its very unreliable, can you help me?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 13 Answers
Be shure all wires and wireing assembly are intact and check the left hand drivers door lock mecanism by removing it from the door and dismantle it. Specially the small red silicone rings in the micro switches Can be hard and won't slip the contact.
Try loosen them with WD40 but it won't last.
Posted on Jul 11, 2017
SOURCE: ford mondeo alarm activates by it self.
have you managed to sort it? mine is the same. have you any advice on the issue ?
Posted on Jan 11, 2010
  • 184 Answers
SOURCE: battery taken out of mondeo ford hb 1996 model, need radio code
ARE U ABLE TO TAKE RADIO OUT IF U CAN I AM LOOKING FOR SERIAL NO. ON THE SIDE IT WILL START WITH M THEN 6 FIGURE NO. IF U CAN DO THAT FOR ME I WILL BE ABLE TO GET UR CODE NO. THANX
Posted on Jan 04, 2009
TLRogue
  • 99 Answers
SOURCE: 52 tdci mondeo, keyfob needs programming
I am afraid on this model has to go to dealer to be reprogrammed.
TL
Posted on Feb 04, 2009
TLRogue
  • 99 Answers
SOURCE: ford mondeo bonnet lock
This is a very common fault on the fords, if i get one in, i generally soak it in WD40 then keep working it back and forward untill the mechanism releases.
If the lock is completely gone then ive had to go as far as breaking the grille off and opening it manually with a scrrewdriver, but this is last resort.
Good luck
TL
SOURCE: how to change headlight bulb on ford mondeo
Very easy, 2 or 3 minutes.
Remove radiator grille. 2 plastic fittings on top, quarter turn and lift out grille.
Remove complete headlight. Simply lift out 2 L shape retaining pins. Disconnect lead. Ease out complete headlamp unit.
Remove back of headlamp unit to access bulbs. Disconnect lead from bulb while bulb still held by clip. Then release clip to remove bulb.
Reverse process to fit.
Posted on Feb 22, 2009
Immobiliser bypass mondeo
Sorry it is off to the dealer on this one.
Apr 21, 2016 | 1999 Ford Mondeo
Ford mondeo is not chargeing the battery
remove the alternator and have it bench tested by an accredited auto electrician. There may be a rectifier or regulator faults.
check that the drive belt is tight and in good condition.
Feb 14, 2015 | 2003 Ford Mondeo
What should I do if immobiliser active light comes on? car won't start
You need the dealer to use a special tester to scan the system and see what is causing this issue.
Jul 13, 2014 | 2008 Ford Mondeo 2.0
Disconnect immobiliser
have to take it to ford usually an ecu problem
Mar 20, 2014 | 1999 Ford Mondeo
Lost my only set of remote car keys that immobilises my car,how can i get new keys?
go to the dealership with your ID and VIN #. (license plate number too)
Tell them what happened.
Most often, they need the vehicle there to program the new stuff and to make sure you aren't stealing someones car.
Jan 29, 2013 | Ford Cars & Trucks
Dials on ford mondeo not working
The color color code for the Ford Mondeo is on the VIN plate which is located usually on the front panel. Take this code to a motor paint factors and they will provide you with a few color chips varying slightly in color.-------------------------------------------------------------------------------------------
maxidas 708
Nov 18, 2012 | Cars & Trucks
Need to change fuse for cigar lighter in 2003 ford mondeo zetec?
On this website you find fuse box diagram and description for Ford Mondeo (2000 - 2007)
Ford Mondeo mk3 2000 2007 fuse box diagram Auto Genius
Nov 06, 2012 | 2003 Ford Mondeo
Mondeo wont start
Have the battery charged and checked for cca's. Make sure connections to battery are clean.. Last it could be a bad starter
Jan 28, 2010 | 2001 Ford Focus
Hard starting my 04 mondeo (1.8 zetec )
Hi ,
first you need to have the car diagnostic codes read to see if there is anything obvious the ht leads do break down and the crank sensors are known for failing,is it worse hot or cold?,it could even be you beating the immobiliser,if you next time wait for the red immobiliser light to go out before trying to start the car and the problem does`nt happen you have a failing Transceiver problem .
May 11, 2009 | 2005 Jaguar X-Type
Vehicle Parts & Accessories Logo
941 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
