Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
HDMI Input problem
My HMDI input will go all out, but you can still hear the station just can not see it. I have replaced the HDMI cable and the HD Converter box from my local cable company. No other inputs do this.
    Genius:
  • 1,153 Answers
Initialize settings by pressing "menu, 1, 2, 3, enter" after settings have been initialized press the system reset button on the front once the LED stops blinking, reprogram the tuner settings
Posted on Dec 08, 2007
How do i hook a bluray player up only with hmdi cable to a older tv without hmdi hookup?
Just buy an HDMI to AV converter box. It will converter the HDMI to Composite video. If your TV have Component video input then its better to buy HDMI to Component video cable. component video quality is better than composite. Its have resolution up to 1080i.
Electronics Equipment Repair Center
Oct 06, 2014 | Sanyo Televison & Video
How do I connect my laptop to my led tv?
Is there a HMDI output on your Laptop or a VGA output. Some TV's have a DSUB input source that allows VGA depends on your laptop it could be HDMI if so TV should have an extraz HDMI input on the back and you change the source input on the TV to the HDMI 2 or HDMI 3 source depending on where you plugged in the P.C. . If HDMI you need to buy a HDMI cable.
Sep 08, 2014 | Toshiba Satellite Computers & Internet
How do you hook hmdi cable up to Mitsubishi hdtv wd62528?
Must select correct input, on your model the input used is not "labeled" HDMI, look in your user manual.
Feb 16, 2012 | Mitsubishi Televison & Video
How do I connect my samsung tv to a kenwood av 6000 using a HMDI cable
To do that you would connect one end of a HDMI cable to one of the HDMI inputs on the TV and the other end of the HDMI cable to the HDMI OUT on the Kenwood. Of course there are other considerations to make the whole process work successfully such as making audio adjustments on the Kenwood and selecting the proper input on the TV. Also having a source (video/audio) input on the Kenwood.
Apr 01, 2011 | Televison & Video
Samsung tv 32:inch no LE32R74BDZ WILL NOT WORK WHEN CONECTED WITH HMDI CABLE ,SCREEN GOES GREEN. SO I USE COMPOSITE CABLES .I HAVE A FOXSAT HD SKY BOX. BUT I WANT HD PICTCURES. AS I HAVE AN HD BOX . IS IT...
We need to narrow things down . If you have a dvd player that has an HDMI output plug that into the HDMI input of the tv with a diffent cable than the one for the sky box. If color is still green then the main board on the tv is bad. If the picture is good then Either the cable used for the sky box is bad or the sky box is bad.
Mar 25, 2010 | Televison & Video
Hooked up ps3 using hmdi cable worked not working now using the
mpc heesman1 might be right...
However. I´m inclined to think that you did change the input on your TV. So your problem is another, this is what you have to to to reset:
1. Unplug the HDMI cable from both the TV and PS3.
2. Plug in the AV MULTI OUT cable (the red, white, yellow one provided along with the system) to both your PS3 and TV.
3. Set the TV input to the correct one and turn it on.
4. turn on the PS3 with the front button but DON´T release it, keep your finger on it, until you hear a second beep, thats when you release the button, the PS3 will start to identify what it´s connected to and will display it on your TV.
Hope it helps.
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
When i plug my camera into the HD tv via HMDI port nothing shows up on the tv. what am i doing wrong?
On my HD Tv, I have to press the "Input" button on the remote - and that displays a list on the screen.... Aux, TV, PC, Game, HDMI. Find the equvalent button on your TV Remote and select the HDMI port as the "Input" and you should be good to go.
Jan 11, 2010 | Sanyo VPC-HD1010 Camcorder
I would like to know if I can connect a HDMI cable from My tv model WS-65315 to a Direct TV HD receiver?
NO> If your TV supports and have HDMI connections and your HD receiver has an HDMI output then you should have no problem displaying Video. Just make sure you change the input signal of your television to HDMI input. After looking at the spec's of this model these are the following inputs you have. your best picture quaity would be to use componet cables instead, which can show full screen 1080i format, your television does not show at 1080p whis is what HDMI is known for.
Connectors
Rear Input Connectors S-Video x 2 - Component x 3 - Composite x 2 - DVI x 1 - RF x 2 - 1 x RS-232C - Audio (RCA) x 6
Front Input Connectors S-Video x 1 - Composite x 1 - Audio (RCA) x 1
Rear Output Connectors Composite x 1 - Audio (RCA) x 1 - RF x 1
Another good option is use to use a DVI to HMDI connector and hook it up this way. But note: you will have to use audio cables for the DVI input.
Sep 28, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Sony Wega Trinitron HDTV Blue Screen with Sound
Had similar problems with HD cable on dvd. swapping with another cable solved the problem.
Aug 11, 2009 | Televison & Video
Motorola DSR505 HDMI problem
Check to see if input 5 has a audio in source via RCA jacks. Many times manufactures will give you multi HDMI inputs but only one that has RCA jacks in case you are running a DVI/HDMI cable. If input 5 does not have those RCA jacks you will not have sound. I know this unit has multiple HDMI inputs. Look to see if any of the other HDMI inputs also have RCA jacks.
I hope this helps,
Skyassoc
Jun 22, 2009 | Televison & Video
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
93 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
