Question about Dell Televison & Video
The sound is off and will not come back on. Mute comes on when button is clicked, but when you de-mute the tv, still no sound.
  • 3,741 Answers
This happens in two possibilities
1)the tv is got stuck up in stand by mode.so sound is not coming.this needs reset.to reset unplug the tv from wall outlet and remove all the external device from the tv connected at its back.then wait for 10 minutes.then only connect tv to main power outlet.and turn the tv ON and check out.if still no sound.keep pressed the mute button for two minutes without leaving it.then check out.if still the same problem.then its internal problem.
2)there is tuner in the tv due to which you get sound in the tv.if the tuner card/circuit fails it has to be replaced so you can get the proper sound again.
if you are familiar with soldering and using multimeter you can try doing this.other wise getting it replaced by technician is advisable .
this will help.
thanks.please keep updated.please do rate the solution if helped.thank you for using fixya.
Posted on Sep 06, 2009
Philips HTS3440/37
Please elobrate further your problem.. i'm a bit confuse " If I press mute button it goes to mute,press mute again sound will come back on" This is normal.i.e. that is the function of mute button.
Sep 07, 2007 | Philips HTS3440/37 System
No sound on tv but volume is up
If you have an older style television and you have cable-then you have 2 remotes-somehow,the tv part went on mute but when you check your sound with the cable remote-it shows high level of bars which makes for confusion!Get out the old tv remote &select your menu then sound &take it off mute----You'll probably see see--sound off! Turn sound on and adjust your sound bars with same tv remote till just a bit more than 1/2 way up.That way you will not have to use cable remote to make it louder-much.In case,you forgot where you put your tv remote& only have cable one--think you can still get it off mute--byshutting down the cable part(which you have probably done several Xs by accident)---and then with cable light not coming on-right- only the tv light =try & adjust with cable remote by pressing mute button-should see MUTE go off!Then bring your cable button back into play and should be all set to go.If that does'nt work and your tv is still a tube tv might need a new part.But hope it was the simple problem.& that I managed to help you.Bye.
Aug 17, 2012 | Televison & Video
I have a 50 inch panasonic 720 plasma tv and while watching it last night a large black box with white writing came on in the top right corner of the screen with mute in it and the sound went off. I...
Unplug the TV. Replug in the TV. If it's still there, you probably have a bad panel. Try changing inputs. These panels are non-repairable.
Jun 16, 2011 | Televison & Video
We have a DVR hooked up to our 1989-99 Mitsubishi TV (floor model) still in amazing working condition. The remote control for that TV never allowed us to put the TV on mute. If the mute botton was...
Well, without knowing the exact model of tv and remote, I can just give my best guess.
Try using the volume up/down on the TV and / or the remote.
On the TV, try pressing both the volume up and down at the same time.
Stick the remote right in the face of the TV (direct in front of the remote sensor) and hit the mute button.
Try tapping the mute button in very short single bursts rather than pressing it for a half second like you would any other button.
If any of those work, please come back and reply with the model of the TV and remote, because someone somewhere probably has the same issue and would love to have it solved!
Feb 24, 2011 | Mitsubishi Televison & Video
How do i turn off the sound
You can use the function button in your keyboard + Mute sound button in the top keyboard rows to mute and unmute the sounds.
(fn key + Mute symbol key)
I hope this is helpful to you.
Thanks
Apr 26, 2010 | Dell Inspiron 2200 Notebook
Mute is on when I turn my vizio on. How do I
The OSD consists of several menu options: Picture Adjust, Audio Adjust, TV Tuner Setup, Parental Controls,PIP Set Up, or Special Features. When in the TV menu, select the Audio Adjust and make sure the mute is off. It may be worth checking the manual which is avialble from: http://www.vizio.com/downloads.aspx
Aug 20, 2009 | Vizio L32 32 in. LCD HDTV
Toshiba Regza 32C3000A tv sound keeps droping out, the mute button when pressed on and then off brings it back on. seems as if the tv is auto muting itself?
Could be a contact piece of the MUTE button from your remote that is causing it.
Go out and Big Lots or Radio Shack to get a cheap universal remote control(big lots would be between $5-$10) Pick up the code for it,and when the tv happens again,your the OLD remote MUTE button to turn it back on and then put away this remote control and use the new universal remote control.
However,if the problem is coming from the manual MUTE button on the TV,you need a repair tech, to fix it!
solutiondoct
Nov 10, 2008 | Toshiba Televison & Video
Televison & Video Logo
60 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
