Question about Panasonic Electronics - Others
I plugged an XLR cable into My DVC-60 to get direct audio from the control room at a church, and the level meter flashed three times and after that I could not get any levels at all, neither from an external mic or the internal mic.
  • 3,741 Answers
Replace the xlr cable and check most probably the cable got shorted.due to which the unit flashed three times.
you can get new replacement cable at
www.bestbuy.com
--------to get it confirmed before buying the cable.you can get your unit checked at local electronics repair store,because they have this cables in spare so they will connect it and confirm the fault.
---------- thanks.please keep updated.please do rate the solution if helped.thank you for using fixya.
Posted on Sep 06, 2009
I just bought the GXL2200 CAD microphone without the cabels,(thought they would've came with), what kind of cable do i need?
As with most microphones, these mics use XLR cables. You can get them online or in a music store in many different lengths. What you need is XLR male to XLR female, though most of the consumer-level stores will probably just call them "mic cables." Note that the thing you're plugging into will need to have an XLR input, and will need to provide phantom power in order for that mic to work.
Nov 09, 2013 | CAD Microphones GXL2200 Professional...
We can't get the volume loud enough to hear when we record to a CD
This unit is a pro unit that makes use of XLR type inputs. These are typically at +4 dBm signal level not that of the -10 from RCA type mixing boards. So what you need to do is take the RCA outputs from your source and hook them to a IHF or unbalanced to Balanced converter and they are available from MCM Electronics. This device here should take care of the problem.
http://www.mcmelectronics.com/product/555-8485
Oct 06, 2012 | Tascam Cd-rw900sl Cd Recorder/player
How to connect the canon ma-200 to the canon xl1
You can mount the MA 200 shoulder pad to the XL1 and plug the RCA connector and the mini plug into the port located on the back of camcorder, first open the door. Next, on the side panel where the audio controls are select AUDIO 1. Now assemble a mic using an XLR Cable. Then plug it into the AUDIO 1 port located on the MA 200 Shoulder pad and conduct test. if your using just one mic test the right side, take notice of the gauges located under the handle. the levels should be jumping like crazy. Now remove the XLR cable from the right side and test the left side making your desired audio levels. Now that should work with out question. If not just email me and ill refer you to the YOUTUBE VIDEO. Email me at: dtspmedia@yahoo.com Peace, Enjoy your video sound.
May 27, 2012 | Canon MA-200 Microphone for XL1, XL1S
My spd s has a bussing soud...I have change the cable and still the same problem
I was using a 25 foot 1/4" to XLR cable from the back of the Roland directly into the Thump. As mentioned, I tried going from the Roland to a direct box with a 1/4 cable on both ends; then out from the direct box "thru"-1/4 fitting, to the XLR connection in the Mackie Thump, with a cable that had the 1/4 on one end and the XLR on the other. Still buzzing. So for grins, I hooked an XLR to XLR cable from the Direct Box Low-Z out, to the Mackie Thump, keeping the 1/4 plug going from the Roland to the Direct box and eliminating the "thru" connection from the direct box to the Thunp, (1/4 to xlr). NO BUZZ.
There is a definite loss of signal strength, ie: everything is coming through quieter, but I can raise the volume of the Thump to FULL, with no buzz, and I can raise the volume of the Roland Module to full, and still no buzz. But there is a definite loss of overall volume, I think because I am not using the direct box properly. Hmmmm. As I understand the Direct box, the IN and THRU are supposed to be used as I was, going from the Roland module to the IN, then from the THRU to the speaker. The Low-Z outs are supposed to carry a signal to a mixer, I suppose to use a FOH PA system, or for recording purposes. Still, I have no buzz. Now...........
In looking over the cords, I suddenly realized that the 25' 1/4" to XLR could be the problem. The 1/4" plug is STEREO! Not mono. Could this be the cause of my buzz? I'm thinking I have a stereo plug, so 2 wires are involved, yet I'm using it in a mono imput in the roland. Perhaps this is creating my ground loop?
After getting a 1/4" MONO to XLR adaptor, attach it to my XLR to XLR cord, go from the back of the Roland (1/4") to the speaker directly (XLR) and see if my buzz is still gone.
The problem now becomes going from the Direct box to the speaker, since it needs to be 1/4 mono from the box, and xlr male to the speaker. I cannot locate a cable like that! So, I guess the next best solution is to get an adaptor to convert one end of the xlr/xlr cable to a 1/4 mono plug. At that point I don't think the cable would still be considered a 'balanced' line though, since it goes from 3 wire at the xlr to 2 wire at the 1/4 ts plug, right? The only other solution is to continue running out of the direct box as I am, using the Low-z out xlr connection, so I can continue to use the xlr/xlr cable.
Also there was a button on the direct box, called a PAD, for -15dB, I assume that what was causing my signal attenuation. When I pushed it in and it released, I suddenly had my volume back.
May 08, 2012 | Roland Spd-S Sampling Percussion Pad...
We have a PMP4000 running multiple mics and instruments in a small church space. We are not getting very much volume and the sound is very fuzzy. Any recommendations?
You have NOT told us what speakers you are using or anything to help us help you. That mixer will produce about 250 watts a side into 8 ohm speakers. That should fill a 30 by 50 foot area. You will need at least 15 inch speakers. Proper mixer setup is important. Look at videos on the subject on YouTube for instructions. Many people use too much high frequency EQ setting. Set the EQ flat to start. Use minimum of reverb to start. Use good quality mics with XLR to XLR cables... none of this Radio Shack or Karaoke quality. Minimum mic cost iis around $90 for decent ones... or about $70 when bought in lots of three or more. For your speakers make sure they are elevated on speaker stands. Use the PFL to solo each channel and set the TRIM level for each as the first step.
Oct 29, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
How much price value
The Escort's integrated design allows for ease of transportation, while its user-friendly controls offer ease of operation, making it the perfect choice for schools, churches, civic organizations and small musical groups. The Escort features dual two-way speakers driven by a five-channel, 300 Watt stereo powered mixer, making it ideal for both vocal and musical applications. The system also includes a PV®i unidirectional (cardioid pattern) dynamic microphone, two folding speaker stands and all necessary connecting cables. Among many professional features, the mixer includes 60mm faders, a five-band graphic equalizer with FLS® (Feedback Locating System) and digital reverb. The carrying case provides storage for all the system componets with ample room for additional mics and cables. This clever design incorporates the speakers into the package, allowing the unit to be easily carried or pulled along on its luggage-style wheels.
Specification
  • Convenient package with luggage-style wheels
  • Two-way speaker system with 10" woofer and piezoelectric horn
  • Five-channel powered mixer
  • Four XLR mic inputs with 15 V phantom power
  • Two stereo line inputs
  • 60 mm faders
  • High quality digital reverb
  • 300 Watts output power (150 Watts per channel) with DDT™
  • Five-band graphic equalizer with FLS
  • Two folding speaker stands
  • One PV®i cardioid dynamic microphone with cable
  • Two 25' speaker cables
  • Storage compartments for microphones, cables and accessories
  • Weight Packed: 64.00 lb(29.029 kg)
  • Width Packed: 16.62 x Depth Packed: 39.75 x Height Packed: 17.62
£499.00.
$649.99
$649.99
May 05, 2011 | Peavey Escort 2000 Microphone
I have a stagg microphone. its a pgt - 60. At the bottom it has 3 prongs. I have a xlr adapter. I plugged it into my computer and it installed correctly, but when i tried to use it in audacity it didnt...
The Stagg is a condenser microphone... It needs whats known as "phantom power" in order for it to function... Phantom power is a 12-48 volt source that usually comes from an audio console or some sort of pre-amp... You will need either an audio console or pre-amp to hear anything from it...
Feb 05, 2011 | Stagg Audio Players & Recorders
Audio-Technica freeway 200 Series VHF Wireless System - I had problems connecting the wireless system with a quarter inch to a xlr. The sound system made a very loud disturbance sound. What cable do I use...
XLR connectors are a two-wire plus ground system. Using a 1/4 inch to XLR adapter may not connect the wires correctly to your sound system input.
The A-T Freeway 200 Series has a 1/4" output jack. This would indicate a line level. A cable to connect the tip of the 1/4" jack to pin 2 of the XLR and the sleeve of the 1/4" jack to pins 1 and 3 of the XLR should work. The XLR should be plugged into a device that accepts line level.
Ideally, you should plug the 1/4" into a 1/4" or RCA jack that is designed for line levels.
Dec 14, 2010 | Audio Technica ATM33A Fixed Charge...
Mixer and an EQ & amp ?
The order is mixer, equalizer and amp. The output of the mixer connects to the input of the equalizer and the output of the equalizer connects to the input of the amp. The equalizer has three types of input and output connections. They are XLR, 1/4 inch and screw terminals. The mixer will have one or two of the three. Choose XLR if possible on the mixer, choose line level output on the mixer if possible. A XLR male to female cable is needed for the connection. The equalizer has two channels, if the mixer has two output channels the two output channels of the mixer can connect directly to the two input channels of the equalizer. If the amp has two input channels, the two output channels of the equalizer can connect directly to the two input channels of the amp. If the mixer only has one output channel then only one channel of the equalizer can be used and one channel of the amp likewise. A XLR male to female connection cable can be used to connect the equalizer to the amp.
Jun 23, 2010 | DBX 1215V Home Equalizer
What are the flash metering modes?
The DiMAGE A1 employs three metering modes; ADI (Advanced Distance Integration) flash metering, Preflash-TTL metering and Manual. The ADI flash metering mode combines distance information from the autofocusing system with information from a pre-flash exposure. On the other hand, in Preflash -TTL metering mode, the exposure is calculated with a pre-flash only. Flash emission control is manually selectable in three levels from 1/1, 1/4, 1/8, 1/16. Pre-flash TTL metering must be used when a diffuser is attached to an external flash or a filter to the lens. Attachment of those accessories may cause error in distance information necessary for ADI (Advanced Distance Integration) metering due to reduced entering light. While manual output control is active, pre-flash will not burst.
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Electronics - Others Logo
Top Panasonic Electronics - Others Experts
 Grubhead
Grubhead
Are you a Panasonic Electronics - Other Expert? Answer questions, earn points and help others
