Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My three phase car ramp goes up but only comes down if i open switch box and operate switch from inside
2 Suggested Answers
  • 3197 Answers
SOURCE: craftsman opener is not responding to limit switch
On the side of the motor unit you will find the 'down limit' control. Turn this in the opposite direction of the arrow printed on the cover. It would be a good idea to take the cover off and watch the limit assembly while you are doing this to make sure it contacts before the door hits the floor.
Posted on Sep 07, 2009
How can I buy a replacement door for a 302 dishlex ?
I was looking for the same thing myself for our Dishlex 300 a few months back. Our problem was 1/ the handle wasn\'t releasing the door catch,
also 2/ the micro switch in the catch wasn\'t getting pressed down properly to tell the machine the door was closed, so the dishwasher wouldn\'t start. Both problems were related to the plastic ramp inside the door being worn where the tongue of the catch goes in.
We couldn\'t find one in NZ, so I made a tapered flat piece of wood to push the catch down between the main body and the door whenever we want to open it.
For the switch problem it was a bit harder - I opened up the plastic box at the top front of the machine (with the power off of course) and built up the plastic ramp that triggers the switch, using glue and then a file to shape it after the glue hardened.
I hope this is helpful.
Cheers.
May 26, 2014 | Dishwashers
Essick air compressor wiring diagram
telepathy do not work that hot as in hollywood movies...
you need to provide a model or at least if this is three phase or single phase...
single phase is easy, you have cord with three wires, earth, active and neutral.
you need to open connection box on your compressor and you will find three wires there terminating in junction box, earth connect to earth (usually green or green with yellow stripes), then you have your neutral (usually brown or black) and active (usually blue or red), connect them, do not put cover on yet, plug cable into the power point and switch on/off power. check if motor is rotating in correct direction, if fuses are not blown... if motor is rotating in wrong direction - switch power wire with neutral wire, it just meant that you wired it in reverse...
do not need diagram for that...
do not forget to give some points...
Dec 30, 2013 | Park Tool Inf1 - Shop Inflator For Use...
Ramp goes down, will not come back up
what a handicap ramp? most have a 6 pole switch that can burn out easily if its not heavy enough.. contact the ramp manufacterer for details...
Jan 17, 2013 | 2007 Toyota Sienna
The power windows and roof light will not come on in my 2000 foot explore. I have switched out the fuse on the panel with no success. Any suggestions? Thank you
Make sure and check all the fuses even the fuse box under the hood as well as the inside fuse box, There are more control modules in these newer cars and trucks. there could be two to three fuses controlling two or three power units to operate windows or inside lighting , this is why i say to check all your fuses.
Dec 22, 2012 | Cars & Trucks
In a mobile which wire is hot the white or the black
Usually the black is Hot.
Test each wire to bare ground wire, and tester lights up on Hot wire.
What are you wiring?
What is a mobile?
What terminals are you connecting to? What color is each screw terminal?
What voltage are you using? Only 120volt single-phase has 1 hot wire.
If you have split-phase 230V from UK or 240Volt in US, then both wires can be hot.
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Sep 27, 2012 | Electrical Supplies
3 phase 20amp 414v
3-phase 240V-414V is Australian.
This is evidently a balanced Wye that tests 414V across each hot and tests 240V between each hot and the ground-or-neutral.
Open following link and scroll down to find the plug that resembles yours.
Then test across each opening on outlet to confirm voltage.
http://waterheatertimer.org/How-to-wire-3-phase-electric.html
Sep 07, 2012 | Electrical Supplies
I need a diagram for a westhouse breaker box so i can see where the white red black and green wire goes
I'm not sure what you mean about 4 wires coming into your trailer.
4 wires is typical of 3-phase service, but typical trailer usually has single-phase residential service.
Copy following link to see main breaker box and component parts for single-phase residential wiring.
Aug 12, 2012 | Hardware & Accessories
I have an aircompressor that I'm need to connect to a power supply. I'm in Iraq and not sure of the wiring. The motor is 380volts, and it has three leads going into the motor. I just need to know if I need...
If motor is 380 v three phase, then all three wires will be connected. Usually, three phase motors do not have capacitors. If motor turns the wrong direction, just switch any two leads. If the motor has capacitors then do more research on wiring requirements. There may be more connections inside of motor and only three exit the connector box.
Mar 08, 2011 | Air Tools & Compressors
Hboart am14 free standing
manual and parts for this dishwasher?
Jul 28, 2008 | Hobart AM14-253 Free-standing Dishwasher
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
70 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
