Question about Frigidaire Refrigerators
Water leaking from underneath fridge
water is leaking from underneath fridge
  • 612 Answers
If you have a ice maker inside your freezer, check where the water connects to the back. I think you will find a leaking connection. Tighten connection to fix the leak.
Please rate this solution
Posted on Sep 06, 2009
Water leaking under fridge
a contant runing of water is most likely a leak in the ice maker supply hose , an intermitant drip of water is a drip pan thats full in bottom of fridge (closest to floor ) this water comes from the auto defrost cycle most times this water evaporates away , but as fridge gets older it makes more frost that needs melted hence more water ,sometimes it over comes the pan and runs to floor , a good flashlight and getting down to look underneath usually tells you source of leak
Feb 20, 2015 | Refrigerators
Condensation water build up inside refrigerator
The tray underneath your fridge is probably clogged, and overflowing. There is an evap tray underneath, and if it does not get adequate airflow, it will overflow, and leak out.
Clean the bottom front vents, and underneath the fridge to ensure adequate airflow.
Mar 31, 2014 | Sub-Zero Refrigerators
Leaking under neath front of refrigerator
Usually any defrost water sits in a plastic pan and evaporates away in normal operation. If the pan becomes brittle it cracks and leaks water. Pull the fridge out and look on top of the black pot (compressor) Is there a plastic drain pan sat on top of it?
Sometimes if the fridge is working hard a lump of ice can form on the pipework going back to the compressor which melts causing some water at the front of the fridge.
Lastly, the insulation under the fridge may have broken down, allowing condensation to form and drip. If the drain was blocked, the water would be inside the fridge, not underneath.
Apr 20, 2012 | Kenmore Refrigerators
My Samsung RS253BAWW has been collecting water underneath the bottom drawer for some time now. It eventually winds up in the drip tray underneath and then runs out onto the floor. I've replaced the...
Depends if there is plastic tubing running inside fridge compartment. Shut off water to fridge. If that stops it you will have to look inside to see if there is visible plastic water tubing or if you can get to it from inside the fridge. Maybe the water line has a defect or got pinched and somehow split. Then turn on water, find leak and splice in a replacement section.
Jan 28, 2011 | Samsung RS2534 Side by Side Refrigerator
Water line for ice maker/cold water leaking underneath
Check your connection at the bottom of the freezer door, behind the kick plate. Also pull out your crisper drawers and check the cold water reservior. If this only leaks when the water dispenser is pressed I would try to track the line from the bottom of the freezer door back to where it goes into the refrigerator (behind the crispers) to the cold water reservior.
If you absolutely have to lay this fridge down lay it on it's BACK only. Also be sure to let it stand upright for at least a half an hour before you start it back up.
Good luck with this!!
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking from underneath. Not currently
This could be a blocked drain.Behind the fridge is a hose/pipe running from the inside of the fridge down to the compressor where the water will then evaporate.If this pipe is blocked,the water will push up back into the fridge.Try to blow the hose clean from inside the fridge.This should solve your problem.
Regards
Andre Nagel
Mar 13, 2010 | Freezers
Water setteling on bottom of freezer side and freezing also leaking. 2 fridges both doing the same thing . leaking on the inside and freezing and underneath water is leaking.
Clean out the defrost drain. There is a drain in the freezer that lets all the defrost water run under the fridge. If that gets clogged then all the water runs into the freezer and can even leak onto the floor
Sep 13, 2009 | Refrigerators
Fridge constantly dripping wet
water inside, too much condensation from humid air entering fridge from bad seals. replace the seals. could also be that the condensate drain is clogged. if it's leaking from the bottom of the fridge, make sure the tubing is still inside the condensate pan underneath the fridge.
Aug 24, 2009 | Whirlpool Freezers
Water comes from under drawers on fridge side, leaks onto floor
If leak continued then you must have a faulty cut off valve. Check and tighten valve. Also, check the hose that runs underneath the fridge for cuts or holes.
Jul 12, 2009 | GE Profile PFS22 33" Artica French Door...
Water leaking from bottom of refriderator
dear ricurtsmith..
your fridge has a water trap pan underneath it to catch the water from the drain line when your fridge automatic defrost.
either the pan is not in place proper or the pan may not be underneath, period. or pan could be stopped up/need cleaning. or if pan is made of plastic, it could be cracked.
it is located at the bottom of fridge where you see something loos like a grilled vent. remove that bottom piece to get to the drain pan.(it just slides out!!) good luck & hope i was helpful.
brbharo....
Dec 05, 2007 | Kenmore 52642 / 52644 / 52649 Side by Side...
Refrigerators Logo
301 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
