Question about Honda 8 HP Engine
Low on oil quit running filled with oil will not start back is
Is ther a reset to start it back need to reset the oil safty on engine thanks for your help
    Problem Solver:
  • 7 Answers
Is it electric start? if so take the battery cables off the battery and hold them together for a few seconds.
Posted on Sep 12, 2009
1994bayou 300 4x4 changed oil filled back to fill line n started it up while running oil check glass looks like theres no oil in it when shut off eventually comes back to full is this normal
that would be normal
when the engine is running the oil is put into the oil galleys and head and takes time to run back to the reservoir or sump so it will appear low on oil
Dec 16, 2015 | Motorcycles
I have a 97 yamaha beuin and the oil cooler line ruptured causing the oil to dump out and the bike died as if you cut the gas off. Its firing and has compression. What else could caus
When this happened, did it run for a while with no oil and then quit or did it quit right away? Hopefully you did not damage the engine. Is there some type of low oil pressure safety switch on this unit that could have shut the engine down? Fix the oil leak. Fill it back up with oil and then try to start it. Now you need to check for spark and fuel to pin the problem down. I hope this helps. Rod
Aug 08, 2015 | Yamaha Motorcycles
How to change the oil on my lawn tractor, model 917288561
Your model number sounds like a sears craftsmen model and it is equipped with a push and twist drain plug it is black with a yellow cap near the bottom of the engine just above the frame always start ther draining the oil out then remove the filter if applicable and replace. Then fill with oil to the full mark start engine run for about 20 seconds then shut off and recheck oil and fill as needed
May 12, 2014 | Garden
I have a 1999 Legacy. Died while I was driving. Oil didn't register on dip stick. Won't start now. It turns over fine. Has power, compression, oil & fuel pressure is good. Plugs are dry(Not saturated)....
Could have overheated because low on oil, the engine may not start until the computer is reset, a safty feature which keeps the engine from damage in such cases., Take it to a mechanic to reset the computer if you think the oil being low was the main issue.
Nov 01, 2013 | Subaru Impreza Cars & Trucks
Car shut off and was low on oil. I added oil but it still won't start.
If you ran your engine out of oil and it quit running before you could add more oil you just might have seized your engine. Always keep your engine filled to the proper capacity with oil.
Regards, Tony
Apr 15, 2011 | 2003 Nissan Altima
Car wont start
there is a safty switch on your car to prevent run dry just add oil and car should start the oil pressure well reset the switch no need to worry simple fix good luck CJ
May 12, 2010 | 2005 Mazda 6
Mtd pro snow blower runs then die
it sounds to me like either the oil pressure switch is being plugged after startup and causint the engine to quit then the plug settles until you start it again and it plugs again easiest way to test is to take the swith and remove the wire to it and see if the engine starts and keeps running, if so then replace the old pressure switch. If this does not solve the problem then the only other thing I can think of is the needle valve is partially pluged, at startup the fuel bowl is full and the engine startsbut after starting the fuel bowl runs low on fuel as it is not filling fast enough and the engine stalls. By the time you try starting it again the fuel bowl is filled again and the whole thing starts all over. Hope This Helps Don
Dec 08, 2009 | Garden
Subaru impreza sti.....
not sure here ,really need to have a drive and a play ,but from the sound of it ,turbo ?? rubber hoses split?? in fact anything associated with the turbo i would look at ,including air flow sensors
Aug 22, 2009 | 1995 Subaru Impreza
Reset my engine oil low in 2007 chevy impala
it will say in your owners manual but i believe you turn your ignition key to the run position not the start. and pump the gas pedal 3 times with in 5 seconds
Apr 14, 2009 | Chevrolet Impala Cars & Trucks
Honda 8 HP Engine Logo
146 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
