Hooked up my Dell laptop to my Memorex MLT1912 TV Monitor. The display comes on, shows what is on my laptop screens but continually flickers on and off
  • markscat Sep 07, 2009
    Rip-off. Originally, I took the $19.99 option to chat with an "expert" to fix my problem. This guy had no clue. I think I had more PC knowledge than he did. I'll go back to JustAsk.com
  • 43 Answers
SOURCE: Toshiba satellite A100 Monitor problem
LCD issue it needs repair..call tosh if your laptop is still in warranty
Posted on Feb 02, 2008
YourTech
  • 63 Answers
SOURCE: Data Shows up only on External Monitor, not on Laptop Screen
If your system won't display anything w/o the external monitor. there's something wrong with the LCD's backlight. you may have to contact your laptop's manufacturer and check if this laptop is still under warranty. you may have to get the lcd replaced.
thanks.
Posted on Aug 26, 2008
SOURCE: monitor flickering and rolling
Thanks for the git back: #1 I hooked up a second monitor (depressed fn+f5) and was able to view everything fine. No problem in any area. Ran Some security checks (malwarebytes,checked windows updates,Secunia PSI,and a virus scan. #2 I opened up the monitor and checked for possible loose connections. #3 brought up the graphics display and checked that 60 hrz was set and correct. #4 ran a backup of all my data from my other monitor,and I made the assumption that it was a bad monitor and I might save some money if I just bought a new laptop.Would like to here your comments. Sincerely : dandee4u3
Posted on Mar 25, 2009
  • 3940 Answers
SOURCE: Dell monitor attached to Inspiron 1520 runs landscape (sideways)
try CNTL+ALT+Up arrow/Down Arrow
Posted on Apr 14, 2009
  • 400 Answers
SOURCE: Monitor light flickers on orange never goes to green.
Sir,
You are suggested to check if you serial cable is in fine condition and it properly pluged into the Monitor and VGA. and do also try changing the serial cable .
Posted on Aug 30, 2009
Laptop monitor bad color and flickers continuely, but when attached to external monitor, works fine
I'm going to take an educated guess here, because it sounds like the monitor's interface controller is bad. I forgot the name of the thing, but it's a small circuit board that's normally located at the bottom of the panel frame, between the flat ribbon cables and the round hinge cables.
"Inverter Board"
Mar 19, 2013 | Dell LATITUDE Computers & Internet
Memorex MLT1912: Signal only coming through on two channels
Did you try setting and finding the other missing channels manually?
Jan 03, 2008 | Televison & Video
Comcast remote code for memorex mlt1912
Logitec should be able to help with this
Apr 02, 2012 | Memorex MLT1912 19 in. LCD TV
Memorex mlt1912 connect to pc problem
I asume you are useing a laptop?
If so, press the F-5 Key along with the Fn key located on the bottom left of your key board.
Nov 20, 2011 | Memorex MLT1912 19 in. LCD TV
Universal remotes don't work on my tv memorex 19" #mlt1912 lcd
The Memorex mtl1912 is a TV that you cannot find a universal remote for. I looked for months and came out empty.
Sep 28, 2011 | Memorex MLT1912 19 in. LCD TV
I need remote control for an memorex model MLT1912
oscaramilcar,
Try one of the links below:
http://www.newremotecontrol.com/Mfrs/Memorex/Memorex/HS-Y3719-BLK-320.htm
http://www.remotes.com/store/memorex/mlt1912.html
-Chris
Aug 24, 2010 | Memorex MLT1912 19 in. LCD TV
Black screen- laptop only works with external monitor
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
If your Dell has a S-video output it could connect to a TV or a video device, which allows for a TV option.
Jul 24, 2009 | Dell Computers & Internet
Monitor flickering and rolling
Mar 22, 2009 | Acer Aspire 3690-2196 Notebook
Dell monitor is flickering
If you have another computer, try hooking to it and see if it flickers on it too.
If you hit Ctl-Alt-Delete and choose Task Manager, does the box flicker there?.
Adjust the monitor ratio in the Display Settings/Display/ Display Adapter Properties, Monitor Tab, see drop down (increase screen refresh ratio to higher number).
Nov 10, 2017 | Dell E207WFP LCD Monitor
Dell Latitude cpx
Symptoms of a Bad Video Driver
Monitor Resolution issues:
screen flickers, screen is cloudy, screen shows horizontal lines, screen goes black, goes blank, goes into sleep mode, goes into power mode, size magnifies or reduces, video is jittery, fonts change, screensaver will not appear, cannot extend display on dual monitors.
Download it from here
VIDEO DRIVER FOR LATITUDE
May 28, 2008 | Dell Latitude CPX Notebook
k24674
jasbo
jasbo
