Question about Saws
Ihave a combination saw but do not have the instructions How do i change the blade
  • drallim May 11, 2010
    Need description of 'combination saw".
  • efs_perpends
    efs_perpends May 11, 2010
    need to know which saw you're referring to. make and model # please
    Problem Solver:
  • 5 Answers
Hi
On the body of the Bosch saw there is a gray L shaped piece of metal. Push the metal in towards the saw. Rotate the blade by hand and you will feel it lock. Keep the metal depressed and turn the nut counterclockwise and remove the blade. Make sure power is disconnected. You can use a crescent or opened end wrench. Also the blade needs to be set at the maximum depth to easily remove the blade.
Posted on Sep 08, 2009
How to change blade
You can download manual on bandsawmanuals.com or try to search on google , make sure to key in the model number of your bandsaw. You can also follow instructions from this article. How Do You Change Band Saw Blade
Jul 10, 2014 | Delta Woodworking Delta Rockwell 14 Inch...
Milwaukee magnum miter saw blade change
See page 9 of this manual: http://documents.milwaukeetool.com/58-14-6955d3.pdf.
The manual is for a 12 inch saw, but the instructions will be similar. UNPLUG THE SAW FIRST!
May 10, 2014 | Milwaukee Tool 10" Magnum Compound Miter...
How do i change blades on a mastercraft band saw?
Here's an easy step by step instructions on how to change band saw blade. How Do You Change Band Saw Blade
May 08, 2014 | Saws
How do you change the blade in a Ryobi 2000 watt mitre saw?
Ihave the same saw and i like it a lot. There is awrench that clips in near the handle that fits the bolt also there is a lockon the front of the saw under the trigger that needs to be press in this will lock the shaft . The bolt is left handed so you have to turn it clock wise to loosen its the oppisite a normal thread so it dosn't loosen whale you are opperating it. Pull back the blade gaurd loosen the bolt remove note the way the washers come off theres only way they fit so look at them as your removeing them . Put the new blade on the outer washer push the shaft lock bottem tighten and its ready to use.
Jan 08, 2011 | Ryobi 10 In Miter Saw With Laser
How do I change the blade on a Black & Decker JS500 jig saw?
Go to Dewaltservicenet.com and type in your model number and you can download the instruction manual for this tool with detailed instructions on how to change the blade. It is 8 pages long.
Oct 03, 2009 | Black & Decker Scroll Jig Saw Blade
How do you change the blades on an exact saw, i
try putting a nail or screw driver through the vent holes in the blade or clamp the blade
Sep 30, 2009 | Saws
Change the blade on my porter cable 347
Here is the owners manual for your saw. It details the procedure for removing and installing a blade.
Please rate this positive if it helps!
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Porter-Cable/En900003.pdf
Jul 03, 2009 | Porter Cable Cable 7 1/4" Quik - Change...
My husband has a BLACK & DECKER JS515 VARIABLE SPEED JIG SAW WITH QUICK CLAMP 3.5 AMP which i accidently broke the blade on...i cant figure out how to change the blade..any help would be greatly...
Here is a link to the instruction manual, and just under the place where it says Save These Instructions it tells you how to change the blade.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90520882,JS515.pdf
Fitting the saw blade (figure A)
- Hold the saw blade (9) as shown, with teeth facing forward.
- Push the lever (3) downwards.
- Insert the shank of the saw blade into the blade holder (10) as far as it will go.
- Release the lever.
There is a little lever where the base of the blade fits into the holder that you depress to release the blade...You can see a picture of it in the manual.
I hope this answers your question...if so, please take a aec to rate this post...thanks.
Mar 23, 2009 | Black & Decker Single Speed Jig Saw
RYOBI TS254 change saw blade???
should have blade lock button remove blade with proper size wrench reinstall new blade in reverse remember some of these the loosening of the blade will be clockwise so if nut dont come loose try clockwise to loosen good luck
Apr 22, 2008 | Irwin Miter Saw Laser Guide Attachment...
Saws Logo
63 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
