Question about Onkyo TX-SR606 Receiver
NO OSD with HDMI on Onkyo Tx-sr606
Over the past 9 months I've had my receiver it's gone from working great to working most of the time to working very little, now to none. Well the optical works for my cable(which I have hooked up over component directly to my tv, gotta use those hundred dollar monsters for something.) I have a PS3 and an Xbox 360 as well as a Wii(don't tell anybody.)
When I tried hooking the Wii up to the receiver, it didn't work at all. I'm sure there was something I didn't click correctly but I assure you I've tried every combination and devoted hours to this receiver. It's only hooked up through HDMI and I know about the upconversion and all that but honestly it's been so long I don't remember what I did with it nor do I care as this really isn't my problem(I'm being concise so that if someone has had the exact problem and knows a fix all or even any fixes that will help me learn this receiver better, or tell me that my receiver is hosed and to get her to the doctor.)
My true problem is from the XBox and it's rival PS3. I've had to use them as a team ever more frequently to trick the receiver into showing a signal on my tv (Samsung HLT5867s.) Originally I was playing games on my new PS3 and digging it a lot, plus the blu-ray was awesome, but while playing Fallout 3, a game running at 720p, I noticed a weird series of vertical lines running down my screen about 4 inches apart and an inch thick or so. I thought that maybe it was just a graphical issue in the game, as while playing Killzone 2, a game running at 1080i, (it's i, I double checked) I noticed no such lines. Then I got inFamous and the lines showed back up. Guess what it's rendered at. If you guessed 720p, you're following me.
I decided to investigate this further and even found a thread about the receiver in another AV forum discussing issues with the display. One guy posted on there about havig a similar problem with the vertical bars. I never saw an answer to his quandary in that thread, and if I recall it was closed by the time I'd found it. In that thread I did find out about resetting the receiver, and figured I could try that to get rid of the bars as having tried changing the HDMI settings in the reciever and the display methods on the PS3.
I also started to noticed that my OSD had disappeared. Usually the receiver would send a blue screen signal to the TV when the PS3 or XBox 360 was connected but not powered on. Now it was just my TV saying "checking for signal" and then eventually ending with "no signal." (When nothing is plugged in to an input on the TV it immediately tells you to "check signal cable" so the TV knows something's hooked up. It also shows anything plugged directly in through HDMI instantly so I know it's neither the devices nor the TV.) I figured it was time to reset the receiver. I did this and voila it worked, for a day.
My new problem is that it would take awhile to work with HDMI after being powered off for awhile(I figure enough time to cool down.) I would have to power it on, watch cable with the sound coming from the receiver(thus "warming it up") and then eventually switching to the XBox or PS3's input and it would work(still no blue screen always "checking for signal" and then it would pop on to the PS3 or Xbox home screen.) It stayed like this for awhile and I was ok with it as I'd just leave the receiver on.
Recently my Xbox got the dreaded red ring of death and I took it back and got a new one(God bless the old Best Buy product replacement plan, I even got a 50 dollar store credit.) When I hooked the new one up it worked fine but was at default non HD settings(still coming through HDMI mind you.) So I changed everything back to the old ones settings, network and video. I left them exactly the way I knew they had been from the previous XBox. And it worked until I powered off the XBox and then powered it on later. No display! So I turned on the PS3 to see if it worked and sure enough it did. So I fiddled around on it for 5 minutes and then decided I wanted to get to the bottom of the XBox issue since my frustration had given way to curiosity. The XBox display was working fine. That worked fine for awhile having to switch from the PS3 with it still powered on to the XBox after a minute.
I have now turned on my receiver and nothing is working aside from my optical from the cable box. I've performed a reset and still only the optical works. So while I sit here watching Shrek on HBO writing a tale of woe about my 9 month old $400 receiver from Amazon(new not a refurb,) my friends are busting caps in Call of Duty on XBox live.
I'm pretty sure the degradation of performance and intermittent issues point to a hardware fault but I could somehow be wrong and if anyone knows what's up, please let me know. I'm going to unhook my stuff for awhile and hope what that other poster recommended works as it seems we're all having the same problems. I hope we can all resolve this and get to use this great receiver at its best all the time and not when it wants to. Rock Band: The Beatles comes out soon and I need it to pump from my speakers!
Thanks so much and good luck to all.
-Nick
    Problem Solver:
  • 5 Answers
For the XBOX 360, you need to disable the Display Discovery setting.
Posted on Feb 12, 2010
I dont quite have a solution for you but im having the same problem and its only with my ps3. ive called onkyo support and of course they try to tell me its my ps3 and not their equipment. Just because i dont sit on the phone all day doing tech support doesnt mean im a moron. anyways you said youve had it for 16 months? I also bought mine new from amazon. anyway according to onkyo warranty info they warranty their receivers for 2 years so call their support line find out where the nearest service place is and call them and send it in. im gonna have to do the same im soory to say a reset is going to fix our problem it is a hardware issue our receivers are just slowly taking a ****. I used to buy nothing but pioneer products and i took a chance on onkyo cuz i heard how good they are (and they are when it works) but im a little disappointed. why couldnt the s-video ports take a ****? haha i hope this helps
Posted on Sep 09, 2009
I have an Onkyo TX-SR606 connected via hdmi to a Sony Bravia 52" lcd screen. My inputs are a Panasonic DMR-EX77 dvd Recorder and a PS3 via hdmi into the Onkyo. All worked well for a month but now it takes...
The problem is with the HDMI daughterboard in the AVR is bad. This is a well documented issue on this interweb! A general search in google can confirm. Here are some stuff cut and pasted frm their site and another forum. Onkyo USA Corporation (hereinafter referred to as Onkyo) hereby warrants all Onkyo products PURCHASED DIRECTLY FROM ONKYO OR AN ONKYO AUTHORIZED DEALER- WARRANTY PERIOD (from date of purchase) New Products: Receivers 2 years Parts & Labor-- You can go to the Onkyo webpage to find a n authorized service repairman.
*** I took mine to a service repair place today, the guy said that he had two that he just fixes yesterday. He said that this issue has given him a ton of work. Just make sure that you have your receipt from AN UNAUTHORIZED DEALER and that your still under warranty. Receivers 2 years Parts & Labor
Jul 02, 2010 | Onkyo TX-SR606 Receiver
Has trouble getting input signal
This unit has a defective hdmi board,this is a common problem with this model. The unit is to be taken to a onkyo service center for exchange of the hdmi board under warrenty, if out of warrentyit will cost you several hundards of dollars.
Apr 19, 2010 | Onkyo TX-SR606 Receiver
Onkyo ht-r960
I had the same problem at 1 year after purchase. I was upset. In addition to looking here, I also emailed the company. They took a month to get back to me, but their solution worked perfectly.
"Try resetting the unit by pressing VCR/DVR and the standby/on button at
the same time on the front of the unit while it is turned on. The unit
will display CLEAR and shut down. All settings will be erased. "
All my components connect without any problem now. Hope this helps.
Doug
Jan 20, 2010 | Onkyo TX-SR606 Receiver
No audio from pc connected using hdmi
Are you not getting audio to the television speakers and the onkyo reciever speakers when connected HDMI thru the reciever or just the television. If it is just thru the television then it is because the reciever is grabbing the HDMI audio signal and converting it so it does not reach the TV. If it is both then try changing the HDMI signal output from PCM to DOLBY DIGITAL on the computer. Your reciever may not be able to process the PCM signal of the computer. Does the reciever show a PCM or DOBLY DIGITAL display when HDMI is hooked up to it?
Oct 03, 2009 | Onkyo TX-SR606 Receiver
I am trying to get the volume bar on my tv screen.It works on everything else but not cbl/sat. Receiver is tx-sr606. Thanks
en order to help out here a few questions need to be asked? Is the CBL/SAT connection VIA HDMI? Some HDMI signals will not pass CC and or On-screen display (OSD) via certain video modes. If all is analog video, not a problem, if mixed with component and HDMI and analog, you may experience issues. Let me know your thoughts and the best of luck.
techhome100
Jun 16, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 getting no sound from HDMI sources on speakers. I have a motorola cable box and a panasonic DMP BD-35K blueray player both attached to the SR606 via HDMI cables (HDMI3 and 1 respectively)...
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Feb 20, 2009 | Onkyo TX-SR606 Receiver
No OSD on TV connected thru composite video (Monitor Out)
hello you need the s-video/sound usually four pins in each end connect to s-video not composite video..saludos
Nov 22, 2008 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 Receiver Logo
3,156 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
