Key re-assigning on a key board need help and quick!!
My keys have gone all random and now if i click for example the volume buttom it will go onto hotmail and i don t want that
    President:
  • 8,637 Answers
Normal 0 Go to Control Panel.
1. Click on Keyboard.
2. When the Keyboard Properties come up, CLICK on Key Settings.
3. Then set up the keys by selecting the Key to be changed.
Hope this will help some. Bud
Posted on Jan 20, 2009
I think my switch for turning on my wireless connection is broke fn f4 normally turns it on but it wont work hp pavilion v6000
Posted on Aug 25, 2009
Volume control
Yes,you can create a Master Volume Shortcut and also assign a Shortcut Key.
Right click on a empty area on desktop, and click on New and Shortcut.
Paste the following in to the location of the item area:-
%windir%\System32\SndVol.exe -f 49825268
Click Next button and give a name to the Shortcut and click Finish.
Now You right click on it and select Properties.
Click Shortcut tab.
Assign your desired shortcut key like F8 or F9 in the Shortcut Key area.
Click OK/Apply
Is There Keyboard Shortcut For Volume Control
Mar 13, 2015 | Computers & Internet
How do i change my volume and where is the fn key in this keyboard
    Is it possible to control the master volume with some keyboard shortcut? I would prefer it to be without a use of some additional software.But if it isn't possible then the software should be pretty light-weight and not consume a lot of CPU/RAM. Thank you for your help.
    PS: I DON'T intend to buy a multimedia keyboard for that.
    Click Shortcut tab.
    Click OK/Apply.
Mar 08, 2015 | ASUS KB73211 Wired USB Keyboard OEM
I want to assign a new shortcut
To assign any new function you would need a software for it. Is a lot better to just use functions already on system, like Fn+F8 (on my Acer). Is just a key more.
Mar 29, 2014 | Dell Inspiron 1501 Notebook
I was assigning new products to my m202 keyboard however I accidentally assigned a product to the PLU list key. Is there any way to remedy this
Create a shortcut
Open the folder or directory that contains the program you wish to create a shortcut for.
Right-click on the program and click Create Shortcut.
This will create a shortcut named "Shortcut to <your program> in the directory you are in. If you wish to rename this shortcut, right-click the file and click rename.
Once the above steps have been completed, you can copy or cut this shortcut and paste it anywhere to execute this program.
Assign shortcut key to that Windows shortcut
Once the shortcut has been created to assign a shortcut key to that Windows shortcut follow the below steps.
Right-click the shortcut and click Properties.
Click the Shortcut tab.
Click in the Shortcut key box and press a letter. For example, if you press "p" the shortcut key will automatically be made Ctrl + Alt + P. Which means if saved when pressing Ctrland Alt and "P" all at the same time will run that shortcut.
hope this helps
Jun 07, 2012 | Computers & Internet
Dv7-1023cl problems with quick touch buttons
You don't need to activate the drivers. if you reinstalled them then they are there and should be working.
There should be alternate methods to using the quick touch keys, such as using the conventional methods.
For example to change your volume, just click on the megaphone at the bottom right near the time and adjust the volume. Or click Start/Control Panel and look for Audio or Sound and adjust the volume. Also click Start/Programs/Accessories/Entertainment and see if there is a volume control there. Also normally you can adjust the volume by keystrokes. Normally you would Press and Hold the FN function key near the bottom left portion of the keyboard and press the volume keys (there should be 3 volume keys, volume up, volume down and volume mute).
As for the Wireless there is a switch on the side or in the front of the laptop that controls the wireless. Also there are keystrokes that can toggle it off or on once the wireless switch is on. Normally you would Press and Hold the FN function key then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the icon of a wireless signal )))) or it will have the icon of a tower with a wireless signal )))).
Apr 23, 2012 | HP Pavilion DV7-1023CL Notebook
You state to hold the fn, and hit the power button.....OK, whats the ( fn ) key ?
The Fn key is a key found usually on the keyboards of portable computers (laptops, netbooks etc) and sometimes on desktop type keyboards.
It is a key usually marked with a blue coloured "Fn" and is located somewhere on the bottom left row of keys.
The Fn key is used in combination with other keys that have (usually) blue letters or icons on them to activate the special functions (Fn) on these keys.
For example, on the laptop I'm writing this on; If I press F5 the computer would perform the action my software has normally assigned to F5. If however I press the Fn button and F5, the computers internal function for decreasing screen brightness is invoked.
Different computer makes have different assignment to their keyboard Fn so you can't generally say press Fn+F5 to decrease screen brightness, it might be assigned to something else, volume or sleep-mode or even nothing. The "blue" text or icon will give an indication of what it will do.
Hope this helps explain the Fn key ;)
Feb 01, 2011 | Dell Inspiron 6400 Notebook
I am the new user, Kindly support me with out charging users guides on how to use ms word easily with short cut keys
Open up Word, click on Help >> MS Office Word Help and a whole bunch of online solutions will appear on the right side. Have fun.
For example:
About shortcut keys
You can quickly accomplish tasks you perform frequently by using shortcut keys - one or more keys you press on the keyboard to complete a task.
For example, pressing CTRL+B changes the selected text to bold, just as clicking Bold on the Formatting toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, press ALT and then SHIFT+F10.) or selecting Bold in the Font dialog box (Format menu) changes the selected text to bold.
Printing a list of shortcut keys
If you frequently refer to the Help topics that list shortcut keys, you may find it helpful to keep a printed copy of those topics. In Help, locate the topic you want, and then click Print .
You can also run a macro (macro: An action or a set of actions that you can use to automate tasks. Macros are recorded in the Visual Basic for Applications programming language.) that creates a list of the current shortcut key assignments, and then print the list.
On the Tools menu, point to Macro, and then click Macros.
In the Macros in box, click Word commands.
In the Macro name box, click ListCommands.
Click Run.
In the List Commands dialog box, click Current menu and keyboard settings.
Click OK.
On the File menu, click Print.
Customizing shortcut keys
You can customize shortcut keys in Microsoft Word by assigning shortcut keys to commands that do not already have them or by removing shortcut keys you don't want. If you don't like the changes you make, you can return to the default shortcut key settings at any time.
Using shortcut keys with different keyboard layouts or Word as your e-mail editor
Shortcut keys mentioned in the Help topics, menus, and dialog boxes refer to the U.S. keyboard layout. Keys on other layouts may not correspond exactly to the keys on a U.S. keyboard. If the language of the keyboard layout you are using doesn't match the language you set for Microsoft Word or Word Help, you may have to make adjustments when using shortcut keys or change your keyboard layout.
If you are using Word as your e-mail editor, some of the shortcut keys listed may not be available or may produce different results.
Dec 31, 2010 | Audio Players & Recorders
My word 2003 shortcut keys are not responding ?
Try restoring shortcut keys to their original (default)settings.
Open Winword.
1.On the Tools menu, click Customize.
2.Click Keyboard.
3.In the Save changes in box, click the current document name or template (template: A file or files that contain the structure and tools for shaping such elements as the style and page layout of finished files. For example, Word templates can shape a single document, and FrontPage templates can shape an entire Web site.) that contains the shortcut key (shortcut key: A function key or key combination, such as F5 or CTRL+A, that you use to carry out a menu command. In contrast, an access key is a key combination, such as ALT+F, that moves the focus to a menu, command, or control.) assignments you want to restore.
4.Click Reset All.
Note:- Reset All removes your customized shortcut key assignments and restores the original Microsoft Word shortcut key assignments in the selected template or document.
Hope it will help.
Oct 29, 2010 | Microsoft Windows XP Professional
Program keys of G5(old version)
Try this Normal 0 Go to Control Panel.
Dec 22, 2007 | Computers & Internet
BCT996T Scaanner
Uniden's quick key for system toggles the associated system (or systems, as more than one system can be assigned the same quick key) in and out of the scan.
The systems which have no quick key associated with them will remain in the scan unless you go into the menu and set each of those systems to be disabled from within the menu.
To your description above I would add that if you pressed the quick again, for the system you want, that system would be included back into the scan - each press will alternately exclude it and include it.
So - if you want to be able to exclude the other two systems from the scan by using quick key then set both of those to share a quick key, that key will then toggle those two systems out of the scan leaving enabled the system that you want to scan.
For example - three systems... air , fire , road. Say you wanted to be able to exclude air and road from the scan when you heard some fire action going on... set air system and road system to have same quick key (say '1') and fire system to have no quick key or a different quick key (say '0'). Now '1' will toggle air and road out of and into the scan on each successive press. So now when all three systems are getting scanned and you you want to shut out air and road, press '1' once... and they're excluded. press '1' again and they're included again (that's why i say quick keys 'toggle' the scan inclusion/exclusion).
If you see a message 'Nothing to Scan' ( or somesuch ) it means that you have excluded all systems from the scan - so just re-include one or more systems and the message will clear and you'll be back to scanning stuff.
I hope this makes sense the way i've described it.
I have a Uniden BCT15 myself. My suggestion is based on the way that the BCT15 works.. from memory and without the manual and rig to hand at this time.
Hope this helps anyway.
Cheers,
BB (aka Tequila Sunrise)
Nov 25, 2007 | Uniden BCD996T Base Scanner
Computers & Internet Logo
807 people viewed this question
Alun Cox
David Payne
David Payne
