Question about Car Audio & Video
How do i unlock my 2000 ponitac sunfire stereo
  • 4,966 Answers
The stereo will have to be removed from the car dashboard
.Then please quote the MAKE + MODEL of your stereo plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Please note>..not all stereos can be decoded using the Serial Number
Posted on Sep 06, 2009
How do I fix the clock display on my 1999 Pontiac Sunfire?
It appears to be that the radio clock display has malfunctioned, and is due for a replacement radio, which could be an aftermarket or oem radio, maybe found at a junk yard.
Tools required for oem replacement radio, torx keys set.
Before working on the radio or other electronics, disconnect the battery cables with 8mm wrench.
Replacing the oem radio is much easier, if you obtain oem radio, compared to aftermarket radio, due to being direct fit.
The radio is same for 1995 to 1999 Pontiac Sunfire and the Chevy Cavalier, regardless of sub models, such as SE,GT, VL,VLX,Z24. etc.
Parts needed for the the aftermarket radio install :Stereo assembly, stereo wiring harness adapter, radio antenna adapter, and dash install kit.wiring diagram for the wire colors / functions, along with tools, such as torx key set, screwdrivers,wire crimper, wire stripper, double ended wiring connectors, hair dryer.
The oem stereo removal video is for the 2000 to 2005 Sunfire / Cavalier, but are the same or very similar procedures.
Link to oem stereo removal procedures.
Pontiac Sunfire Radio Repair and Removal 2000 2005
Link to aftermarket stereo install / connect procedures. ( Sunfire Video )
HOW TO INSTALL AFTERMARKET STEREO PONTIAC SUNFIRE
Link to aftermarket stereo install / connect procedures. ( General Video )
How To Install Car Stereo Single Double DIN Car Audio 101
Have a nice day.
May 12, 2015 | 1999 Pontiac Sunfire
How do I unlock the Am/FM Radio/CD player in my 2000 Ponitac Montana van?
you were suppose to have the radio unlock code .if you don't have it a GM dealer will unlock it for you and tell you a code for it
this is all for antitheft system
hope it helps
Oct 02, 2014 | 2000 Pontiac Montana
I have a 2000 Ponitac Montana van and lately when you go to put the van in reverse it won't back up, what could be the problem?
Transmission is slipping, Will have to be taken to a transmission shop to be check out,End plan to have a big bill for it,
Nov 08, 2012 | 2000 Pontiac Montana
Hi, I have a 1996 Ponitac Sunfire and I was driving On the interstate and I put on the gas to pass a car and I heard a loud pop noise under the car and my red engine light can on. What do you think it...
No one could even guess
How would someone on the internet
without the car & more specific info,
of at least something you looked over,answer
that?
Jun 28, 2011 | 1996 Pontiac Sunfire
My back window defroster won't work on my 99 Ponitac sunfire
On this year vehicle the flapper should be vacuum controlled. You may want to look at the vacuum lines going to and from the vacuum canister in the engine compartment. If it will change from floor to dash but not defrost then you may have a failed vacuum line or diaphragm in the dash from the selector.
Jan 21, 2011 | 1997 Pontiac Sunfire
I need a wiring diiagram for a 2001 Pontiac Sunfire Monsoon radio
this 2001 is the same as the 2000 sunfire
2000 Pontiac Sunfire Stereo Wiring Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Front Front Speakers 4" x 6" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Oct 16, 2010 | Car Audio & Video
How do I unlock my stereo on my 1997 pontiac sunfire? I replaced the alternator and battery, now the stereo is locked.
Remove the radio from the dashboard
Then post the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on any LABELS, BARCODES or STAMPED IN THE METAL CASING
May 26, 2010 | 1997 Pontiac Sunfire
I just installed a different radio into a 2000 Ponitac Sunfire.
hi this might now be of no use, some makes or radio's have a 3 chance code enter system, where as if the code has been entered wrong 4 times, it will lock out the radio and there is no way to recover it, there is a special chip that disables the radio and makes it useless to say thieves if the steal it, but i have a decoder that may be able to help, i will need the serial from the unit and the model ie phillips,sony that sort of thing..if you email me these i will see what i can do, if it does not work then its a new system..
steve_e_morris@hotmail.com
Feb 21, 2010 | 2000 Pontiac Sunfire
Where are the spark plugs located on my 97 ponitac sunfire
there should be coil packs on top of your engine you will have to remove those and your plugs will be under them
Jul 17, 2009 | 1997 Pontiac Sunfire
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
