Cant get online or pick up a wireless network?
I installed a wireless router on the computer in the hose now im trying to get my HP pavilion slimline s7712npc online in the garage but its not working.
    New Friend:
  • 33 Answers
If your computer is not able to connect through wireless network firstly you just switched off the wireless button. There is a key button above the number key which looks like a Tower. If you have tried all the thing then try to reset the router, reinstalling the router, if then also it was not connected then check your network network port. Assurance Wireless
Posted on Mar 02, 2015
  • 556 Answers
A couple of issues and questions
First generally a wireless router in installed onto a network either to the ISP's modem or to another router that is connected to an ISP's modem it is not connected on the wan side to a computer (unless that computer is acting as a firewall or proxy server to the internet). Computers are generally connected with a wire to the (optional) switch portion of a wireless router or wireless connection.
Have you tried testing with a computer wired to the router to assure internet access is possible without worrying about wireless issues?
If you are considering encrypting the wireless router did you test it unencrypted first to assure the unencrypted radio transmissions work?
Is the wireless communication encrypted for other computers you own and possibly not for the HP you are now trying to connect?
Are you sure the distance between the wireless router and the garage is not an issue. Perhaps you could test and configure the connection in the room with the router and when it is working move it to the garage.
According to the product specs for the HP Pavilion it has built in wireless B & G you did not include the router manufacturer and model does it operate on the either wireless B or G?
Posted on Dec 08, 2007
HP Pavilion Slimline s3700y Desktop lan
What's the problem with your computer?
Are you looking for the lan drivers if so try below.
Get onlineand got to www.google.com In the google search box type: "HPSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Network drivers.
May 11, 2012 | HP Pavilion Slimline s3700y Desktop,...
I have a hp pavilion a1140n and i cant set up wireless internet in my house what do i do
To have wireless internet you would need a (cable or DSL modem depending upon your ISP. A wireless router (doesn't matter which brand) Also for a desktop computer you will need to buy and install a wireless NIC (network interface card) as desktops almost never come with one, only a hardwired NIC (cabled)
Dec 16, 2011 | HP Pavilion a1140n (PX774AA) PC Desktop
Im trying to connect my laptop to the router,(the laptop is an hp pavilion running on windows 7, and the router is a 2wire) but I cant connect to the router and theres no option 2 put in the WEP key. (And...
Your class geek is not much of a geek. The computer can loose the wireless settings quite commonly. Open the wireless connection window as below:
right-click the network you are trying to connect to and click properties and then the security tab. You should get this window:
Change the encryption type to WEP and enter your router's WEP key. Click OK and you should be able to connect. OK?
Dec 05, 2010 | HP Pavilion dv6000z Notebook
Can the HP Pavilion 763n PC Desktop use a wireless router?
Your computer has a "built-in" 10/100BT network connection integrated on the motherboard but to go wireless you'll have to add either a PCI (internal) or USB (external) wireless network adapter to transmit/receive the signal from your wireless router. Think "walkie-talkie" here with the wireless router installed AFTER the modem (phone line outlet needed) located in a central area of your home and transmitting/receiving to the individual wireless network adapters that must be separately installed in each computer.
Oct 19, 2010 | HP Pavilion 763n PC Desktop
I am trying to make my wireless network secure by adding a password and every time I do so, the network name doesn't come up as an option to be chosen to connect to when I turn on my computer. It's only...
Choose a compatible encryption method for both the router and the PC or laptop connecting to the router.. You may choose WPA on your router and you should SET WPA also in your laptop. Just try to check this compatibility.
Jun 04, 2010 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
HP slimline s3300f computer - network adaptor problem
Try a different method of encryption. Some just do not work with some machines.
Oct 29, 2009 | HP Hewlett Packard Pavilion Slimline...
Cant connect old comp to new router
go to > control panel >network connections > in left hand pane.under Network Tasks..click..Create A New Connection... that will start a wizard and will guide you thru the process. you will also need to install the drivers as well for his computer to be able to use the modem/router.
i hope this has helped
Sep 09, 2009 | HP Pavilion a330n (Refurbished)...
Can't find wireless Signal
Make sure her router is configured to broadcast the SSID as that can either be disabled or enabled. Once thats enabled and you still cant see it try and set it to different wireless channels and change the wireless network mode to 'mix"
Jan 03, 2009 | HP Pavilion dv6000z Notebook
Can't connect my ps2 slimline wireless to play online
can not do wirless
can only be wired cause i was asked that not to long ago sorry just buy a multi ethenet cable conneter and another ethenet cable to hook it up to your ps2 that's all i can think of
Feb 10, 2008 | Sony PlayStation 2 Slimline Console
Computers & Internet Logo
302 people viewed this question
David Payne
David Payne
