Hello,I Have a GE 106575,and to make a long story short,I need the "Bearing Assembly" for the brush roller 61445-1. The roller brush is in perfect condition except for one of the "Bearing Assembly's". It is not practical or wise to replace the whole roller brush because of 1 removable part that went bad. That would be like throwing good money down the drain. I can assume the "Bearing Assembly's" on this roller brush will need replacing every so often.
So I need to know where I can purchase the "Bearing Assembly" for the brush roller 61445-1.
Probably should just go to a repair shop and they should be able to order one for you, that is if they are available by themselfs. Or if you have a store where you live that sells vacuum parts, you could go there.
The plastic connection area of the pole where it connects to the handle split at the seam. I need a...
(More)
The plastic connection area of the pole where it connects to the handle split at the seam. I need a new pole. Where can I purchase one for GE #169072?
New bag just put in, filters are clean. There is no suction what-so-ever. The hose is not clogged....
(More)
New bag just put in, filters are clean. There is no suction what-so-ever. The hose is not clogged. When disconnect the beater bar assembly from the hose, the motor does not run. The motor only runs when the assembly is attached, but then, there is no suction.
