Question about Briggs & Stratton Garden
Troy Bilt pressure washer model 020209 will not build pressure-have checked all screens and intake in pressure hose and garden hose from house to pump. water leaks at gun handle- took it apart and oiled piston- was ''grabby'' but now snappy but still leaks. Engine starts fine and runs fine. Please help.
  • 174 Answers
A leaking gun will kill all the pressure. You may need to repair or replace the gun
Posted on Sep 17, 2009
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
020488 USER MANUAL
Contact Troy-Bilt...
http://troybilt.custhelp.com/
They have a page for Pressure Washers explaining thet tehy do not build their own pressure washers...
http://troybilt.custhelp.com/app/answers/detail/a_id/430
Jul 14, 2014 | Troy-Bilt XP 2800 PSI 2.5 GPM Gas Pressure...
Troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Sep 04, 2009 | Karcher 2500 PSI Pressure Washer
Troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Jul 09, 2009 | Garden
Troy Bilt pressure washer model 020209 has very low spraying pressure. How do I repair the pump?
you are going to need a pump seal kit or they may call it a rebuild kit but this sort of thing happens often and you should not have any trouble getting the parts you need with the kit should come a exploded view diagram but request one just to make sure be careful when putting it back together if gyou damage any of the brass or neoprene parts you will be putting it together for nothing lay out your parts on a clean towel keep all dirt and grime away and clean your pump housing really good before you put the new parts in and i mean clean enough to eat off of if you do all of these things your rebuild will probably last longer the the original good luck and get back with me if you need help with the rebuild
Jun 29, 2009 | Garden
You need to replace parts 37 thru 41 on the pump breakdown.
Click this link for the breakdown.
Mar 17, 2009 | Garden
Garden Logo
1,063 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
