Question about Samsung SyncMaster 2253BW LCD Monitor
Monitor not using all available space
I see a 15½ image on an 18½ monitor.
At start-up, a pop-up with the word "Analog" appears briefly.
  • 3,741 Answers
Do NOT use the VGA cable. Only use the digital DVI cable for video. Using the DVI cable connect one end to the DVI
connector on the monitor and the other end to the DVI connector on the video card. You should NEVER connect
cables to both connectors on the monitor. The only rare exception is if your monitor can support switching
between two video sources such as using one monitor alternately for two computers. I have only seen one
monitor support this.
The only other cable you need to connect is the power cable.
When your computer boots the monitor should check both analog VGA and digital DVI inputs for a signal from
the video card. It should automatically select the right one after a brief search. Most monitors should work
this way. Only on rare occasions should you have to set the input manually using the setup program built
into the monitor.
A lot of video cards now days have two connectors. They are either:
1) VGA connector and DVI-I connector, or
2) Two DVI-I connectors
The DVI-I connectors are special connectors that are normally used with DVI input of LCD monitors. They also
can be used with a VGA monitor input (either CRT or LCD) by using a DVI-I to VGA adapter. This adapter is
normally supplied with most video cards that have a DVI-I connector.
The following is a typical video card:
The VGA connector is on the left. The DVI-I connector is on the right.
With the two connectors on the video card you can use either one or two monitors at one time.
The left VGA connector can be used with a VGA cable only. You can use it to connect to either an analog VGA
monitor or a LCD monitor using its VGA input connector.
If you use a DVI cable with the DVI-I connector only the right 24 (3x8) pins on the right of the connector
are used. These contain digital-only data for a DVI connection on an LCD monitor.
If you use a DVI-I to VGA adapter with the DVI-I connector only the 4 pins on the left are used. These
contain analog-only data for a VGA monitor connection. With the adapter then you can use a standard VGA cable.
The following is typical LCD monitor video connections:
The left video connector is a DVI (aka DVD-D) connector. Note the absense of the 4 analog pins seen on the DVI-I
connector on the video card. These are not needed because this input is digital only.
The right video connector is a standard VGA monitor input.
Note 1: the DVI connector is sometimes missing on low end LCD monitors. You can only use analog VGA cables
with these monitors since they have a VGA connector.
Note 2: You must NEVER use both the VGA and DVI connectors on an LCD monitor at the same time.
Posted on Sep 06, 2009
Dell inspiron 1100 bought used reinstalled xp and monitor had only 6 inch image adjusted resolution, it grew almost perfect one more adjustment now quickly shuts. down image Windows logo with start up...
You may have set the resolution/refresh higher than is possible for the laptop to produce, Try booting into safe mode (F8 on power up)
if you can, you can now reduce the resolution to the monitors default resolution.
If you have not already, pop over to the dell support site and download the right driver for your display
Jul 19, 2010 | Dell Computers & Internet
Black patches start blinking on photos played back
You're seeing blown-out highlights. These are the portions of your pictures which have been overexposed so much that all detail has been lost. If printed, they will show up as pure white, without a hint of shading.
The "correct" fix is to reduce the exposure by using exposure compensation to bring back the details. Blocked-up shadows (the same thing at the other end of the brightness scale, where dark objects go pure black) is generally considered less harmful to the final image.
That was the long answer. The short answer is: Press up/down on the multiselector to cycle through the different views available.
May 28, 2010 | Nikon D80 Digital Camera with 18-135mm...
VX1935wm using analog input has image shifted ~3 in left
try to Google for service menu...then adjust from there,,
May 06, 2010 | ViewSonic VX1935wm LCD Monitor
Monitor shows image briefly than appears to go blank, is actually EXTREMELY dim instead.
Check for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 23, 2010 | Samsung 225BW LCD Monitor
The monitor turns on and the computer image comes on for about a second then screen goes black again. The image that does come on is perfect.
I'm having the exact problem. I just got the new monitor & I replaced my 18". When I plug it in it flickers, when it does come on it's clear & clean; but after a few minutes it goes black. I tried to switch it to Digital & Analog, but I don't know how to fix it. I know it works, it was just plugged into my brother's computer. Is something wrong with the settings on my computer? If so, how do I fix it? I have both monitors hooked up on my computer desk right now, it's a bit crowded! PLEASE HELP ME!!!
Oct 22, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Monitor boots ok, then "Analog" appears/monitor shuts off
Does it have a digital port being used? If you are using the DVI port, it is probably digital. Try using the menu to selct the port. If it doesn't work, not sure from here. What is the model number?
Aug 01, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
Low brightness on second monitor using Radeon X1300 video adapter
According to the X1300 specifications here it does support multiple displays. The option to configure the display is found in the Catalyst application. Do you have the latest version of that? You can get it from their website.
Jun 01, 2009 | ATI RADEON X1300 PRO, (256 MB) AGP Graphic...
I cant upload my pics to my computer
How To Transfer images To Your Windows XP/VISTA PC P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;} To transfer images from your camera to your Windows XP PC, follow these steps:
  1. Connect your camera to your PC using the USB cable.
  2. Turn your camera on, and then select the 'Computer' option on your camera.
  3. After you have selected the computer option, a pop-up appears on your PC informing you that Windows has found new hardware. Close the pop-up.
  4. Double click the 'My Computer' icon located on your desktop. The My Computer window appears.
  5. Double click the 'Removable Disk' icon in the My Computer window. The Removable Disk window appears.
    Note: The drive letter associated with the removable disk may be different depending on your system.
  6. Double click the folder names DCIM in the Removable Disk window.
  7. Find the folder named 101SSCAM. The images taken with your camera are in the folder.
    Note: Each folder in your camera contains up to 99 images. Once this limit is reached in an existing folder, your camera creates a new folder. The folders are labeled successively: 102SSCAM, 103SSCAM, etc.
  8. To copy the entire folder to your PC, right click the 101SSCAM folder. A menu appears.
  9. Highlight 'Send To' in the middle of the menu. A sub menu appears.
  10. Select 'My Documents'.
  11. Windows copies the folder into 'My Documents'. Depending on how many photos are int he folder, copying may take a few minutes.
  12. Double click the 101SSCAM folder in My Documents to access and view the pictures taken with your camera.
How To Transfer images to Your Mac PC P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;} To Transfer images from your camera to your Mac, follow these steps:
  1. Turn on your Mac, and then connect your camera to your Mac using the USB cable.
  2. Turn your camera on, and then select the Computer option on your camera's screen.
  3. An icon appears on your Mac desktop labeled Untitled.
  4. Shortly after, a pop-up appears on your Mac desktop. Click 'Download All' in the pop-up.
  5. After downloading is complete, another pop-up appears containing the pictures taken with your camera.
Dec 31, 2008 | Samsung L200 Digital Camera
Screen resolution problems
I just rang Samsung about this problem and they immediately said they would replace the monitor, no questions asked!
Oct 26, 2007 | Samsung SyncMaster 713BM 17" LCD Monitor
Samsung SyncMaster 2253BW LCD Monitor Logo
105 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
