Question about Sanyo SC-WP110 Bagless Stick Cyclonic Vacuum
Where can I buy a replacement filter for this cleaner?
  • 430 Answers
Not a common brand. Try a vac specialty shop.
Posted on Sep 06, 2009
Tip
Fed up having to buy new filters for your vacuum?
Over the years I've lost count of how many companies stop selling replacement filters for their long deceased production vacuum models or that filter replacements are becoming increasingly difficult to source. There are usually universal "microfilter" replacements which are easy enough to find and cut to size, but if you can't be bothered to do that, there are ways around to renew your existing filter even if the manufacturer or the user manual states that the filter cannot be washed.
You see, any filter can actually be washed - if it is a single cloth filter - as opposed to a micro pleated section of many layers sewn together. If you have such a filter, a single cloth filter which the user manual says cannot be washed, this is a blatant lie. Remove the motor filter as normal (usually found at the bottom where the paper bag goes) if it is embedded with dirt and wash under a hot tap of water with either household washing up liquid or soap. Once the filter has been completely cleaned, place the filter into a pillow case and chuck into an electric dryer on a low heat. Instead of waiting 24 hours normally for a filter to dry to room temperature, you'll cut your waiting time by a day simply by allowing the gentle heat from the electric dryer to circulate around the pillow case which holds your vacuum cleaner filter. Once the filter is completely dry to the touch and does not feel damp in any way, install back into the vacuum cleaner.
I have also done this with HEPA paper filters which apparently are not washable according to the manual, and to stop the plastic cartridges from bouncing off the walls of your electric clothing dryer/tumble dryer put an extra towel or cloth into the pillow case to minimise damage. What is then revealed is a new, dry and clean filter which can be used again instead of spending lots of money trying to source a new one.
At the same time, if your vacuum cleaner has a soft bag, take it off and put it into the washing machine to give it a clean lease of life - but you won't need to put it into a pillow case to dry in the electric dryer - simply chuck the bag in to ensure it gets dried properly before putting it back onto your vacuum cleaner.
on Nov 16, 2007 | Sebo Automatic X1 Bagged Upright Vacuum
Why is the recovery tank on Hoover f6212-900 not filling up?
Hello! There are a few things that can cause the cleaner to lose suction. Please try these quick steps.
1. Remove the dirty water tank.
2. Clear the filter screen of any dirt or debris.
3. Turn the cleaner on, check your motor suction by the filter screen.
4.. Replace the dirty water tank making sure it is flush to the cleaner on all sides.
5. Lift up on top of nozzle and slide off cleaner.
6. Wipe debris off nozzle and front of cleaner with a damp cloth.
7. Replace dirty water tank.
If you felt suction by the filter screen your suction should now be restored. Hope this was helpful!
Jul 21, 2014 | Hoover F6212-900 / F6215-900 SteamVac...
How do I change filters and empty dustbuster?
The easiest way is to use another vacuum cleaner. Never buy a bagless vacuum cleaner as they are not healthy, too much hassle and repair and in a long run way more expensive than the bagged ones.
Apr 25, 2014 | Vacuums
Spare part for ariete vacuum cleaner ecopower 2799
Where can I buy replacement filters for the Ariete vacuum cleaner, made in Italy
Apr 14, 2013 | Vacuums
Since I replaced the bag in my Eureka Rally 2 (this was the first time) the suction has not been working well. Could you please tell me what I could have done incorrectly. Thankyou
The dust bag holder is an important part of this vacuum. Make sure the bag is installed into the holder sliding bag collar into slots to secure.
Make sure the bag is tucked into cleaner. or the bag cover will not latch securely.
Also, the motor and exhaust filters should be cleaned at each bag replacement.
REPLACING THE FILTERS
Filters should be cleaned or replaced when they become visibly soiled or suction power is reduced. Always operate the cleaner with the filters installed to avoid motor damage. The dust bag must be changed and the filters cleaned or replaced if the window of the Clean Filter Indicator changes into red when the cleaner is operating at maximum power and the nozzle is raised from the floor.
Mar 28, 2011 | Eureka Vacuums
Eureka Rally 2 had great suction the first two times I used it and now faint. No blockage and new bag and clean filter. What coud it be?
Dec 25, 2010 | Eureka Vacuums
Filter cleaning
The fact is that the "bagless bandwagon" is powered by some excellent marketing that conceals what is often poor technology. In your case, the filter blocks because it's doing the job that a bag would do in a bagged machine (catching the dust), and then the machine overheats because the flow of cooling air to the motor is restricted. The only solution (for this machine) is to keep buying new filters - the only permanent solution is to buy a different vacuum cleaner. And my advice is to buy one with a bag!
Nov 03, 2009 | Dirt Devil M0105 Bagless Vacuum
Vacuum cleaner filters
Sponge filters should be washable. I have found that "FLASH" lemon floor cleaner is by far the best, but washing up detergent will do (far too many bubbles to get rid of for my liking!). I find pouring the detergent onto the sponge and working it in before dunking it in very warm water works best. Despite not being very washable, most paper filters can be washed if you have no other choice and you take care. Just pour on cleaner and then dunk up and down in hot water. Then leave in the airing cupboard for a couple of days to dry. It should get you by until you can find somewhere to buy a new paper filter.
Jan 23, 2009 | Vacuums
filter should be replaced regularly. any Vacuum repair facility shoud hav filter or can order one with a model #.
jim
Aug 01, 2008 | Vacuums
Sanyo SC-WP110 Bagless Stick Cyclonic Vacuum Logo
44 people viewed this question
Top Sanyo Vacuums Experts
Gerry Harvey
Gerry Harvey
ray gallant
Roy May
Are you a Sanyo Vacuum Expert? Answer questions, earn points and help others
