Question about Boating
Boat horn not working; fuse is good - Boating
  • thomasnee May 11, 2010
    Give it some viagra:)
    Sniper:
  • 53 Answers
TOOL NEEDED (1) DC test light or probe. TROUBLESHOOTING (1) generally a horn just has two wires positive and negative. Test negative by connecting dc test light negative to the negative on the back of the horn. use positive side of dc test light and touch a known positive connection. dc test light should light if not. find clean know ground for horn. Test positive by connecting neg side of dc test light to a know negative connection. use positive side of the dc test light and touch positive side of horn. test light should light up when you touch the horn switch. if dc test light does not light take a jumper wire and connect one side of jump wire to a known positive connection. take other side of jumper wire and lightly touch positive side of horn connection. horn should beep. if horn does not beep replace horn. if horn does beep test and or replace horn switch.
Posted on Nov 03, 2009
2014 lowe pontoon boat horn switch not working suggestions???
checked and cleaned the fuses. Obviously the horns are working, just the flow of electrons is getting stopped somewhere along the line.
Also check the ground, make sure all connections are tight and clean. You had some oxidation on the fuse
May 14, 2017 | Boating
Were to find horn fuse
different cars different places. look on back of fuse cover it is either on inside fuse box, or under hood fuse box. if the fuse is ok! check the relay for the horn in under hood fuse box. if that is good.disconnect wire from horn, run a wire from battery positive to the horn it self, if it works now, it is the horn relay or button in car. Good-Day!
May 11, 2014 | Chevrolet Caprice Cars & Trucks
2002 Larsen, boat runs great but depth finder, ACC button and horn wont work. is it just the wiring? Fuses?
Bad connections,blown fuse,fuse contacts dirty or black death in wiring
Sep 03, 2013 | Boating
Horn Problem
it sounds like it does not have a good grond or it is wired up wroung
Jun 20, 2013 | Boating
Simple horn diagram for 19ft. ski boat
One lead is power when button is pushed the other ground.
Jul 26, 2012 | Boating
Install horn on boat
check the ground wire, make sure it is not just wired to a screw in fiberglass. also need to wire it from fuse panel.
Jan 25, 2012 | Volkswagen Cars & Trucks
Horn does not work, horn buttons are good, horn contact in steering cololm is good, battery level is good, can't find a fuse in fuse box for horn.
if you take a test light and test all the fuses in the fuse box and if they are good then when pushing on the horn button you can usually hear the horn relay working(click).if it does then you need to check the horn itself.take a wire and run it from the battery positive cable and connect it to were the horn wire connects to the horn,it should blow(make sure of a good connection),if it does then it could be a dirty connection at the horn.if it doesn`t blow then the horn needs replacing.you can also use the test light and test for power at the horn wire at the horn itself to see if the horn is being feed power from the horn button to the horn.
Jul 25, 2011 | Pontiac Firebird Cars & Trucks
I just bought a 2000 Saturn SL 4-dr sedan. It's in great shape, but the horn doesn't work and the dashboard light don't work. Is this a simple fix with replacing the fuses or dash light or is it a little...
Check fuse for horn and for dash lights. If the interior lights work then suspect dimmer switch for the dash lights. If you press the horn button do you hear a click under the hood or inside the car? If you do not then the fuse is blown and if the fuse is good then the relay may be suspected bad. If the fuse is good and the relay clicks then suspect the horn to be bad. If fuse is blown and you put a new one in and you push the horn and the fuse blows again, then disconnect the horn before replacing the fuse again. Then push the horn button and see if you hear the relay click if you hear a click the the horn is bad or wiring butmost likely the horn. If you have the horn unplugged and the fuse is good and you push thee horn button and no relay click suspect the horn button to be bad. Hope this helps.
Sep 06, 2010 | 2000 Saturn SL
I have a 89 golf, horn doesn't work but it makes a clicking noise when the horn button is pushed any ideas to get it to work?
Your horn buzzer is either broken, or it is not getting power. The click you hear is the horn relay. It is good that you can hear it.
To diagnose the problem, locate the horn module. It should be behind the grill in the front of the car. Remove the power wire. Get an assistant to press the horn button while you measure voltage in the connector. If you have voltage, replace the horn. If not, find out why there is no voltage. It could be a blown horn fuse or a broken wire. Good luck.
Feb 23, 2010 | Volkswagen Golf Cars & Trucks
Clarion Xmd3
Bottom line is that boats are a hrsh environment for electronics. Moisture, salt, and vibration all conspire to undo solder joints and electrical connections. 4 years is a pretty good life span on a boat. A solder connection within the unit could have let go. A good repair shop could probably fis the bad connection but you can probably replace the unit for less.
Jun 26, 2007 | Clarion XMD3
Boating Logo
609 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
