Question about Sharp Viewcam VL-AH60U Hi-8 Analog Camcorder
Problems When I record video lines come across the screen. And it records onto the tape
hardrocko
  • 1476 Answers
SOURCE: Constant Eject Tape iluminated on screen.
Are there any error codes listed? Usually when a camcorder constantly ejects the tape it is because of a fault being present, the most likely one is moisture. Leave unit in a dry environment for a day with the cassette door open then try it. If you are sure the unit does not have moisture in it you probably have a bad moisture sensor. They go bad frequently. It is the small square device usually located on the deck base near the video drum and sometimes on the base of the drum. I do not know if you are capable of replacing this unit. If not you will need to find a reputable repair facility to get an estimate. Keep in mind from the description you gave of the problem it could be about anything. This is just the most common problem for this symptom. Several websites which offer free estimates are: http://www.videotech.com or http://www.camcorderrepair.com or http://www.videoonerepair.com Good luck.
Posted on Jul 24, 2006
poolseman
  • 206 Answers
SOURCE: No image during recording -- sharp mini dv VL-NZ50
This problem can certainly be fixed and is not that expensive : the no image in capture mode when you can playback is caused by faulty CCD sensor and you might even have it done free of charge because it is often a faulty sensor that goes in your camera during manufacture. Sony in particular repairs these faults free of charge, but others do too.
Posted on Sep 04, 2007
SOURCE: I have the Sharp Viewcam Hi-Fi monaural 8 and was
Actually, they do still sell the tapes. I have seen Hi8 video tapes at Walgreens, and on ebay and I have a Sony VL-E600U.
Posted on Jun 28, 2010
mikeywaf
  • 346 Answers
SOURCE: recorded new tapes show lines or tracking problems
Hi - This is the most common problem with film camcorders. The heads are dirty. you need to get yourself a head cleaning cassette and carefully follow the directions. Since it sounds like you haven't cleaned it in a while or at all would give it a second pass with the cleaning cassette.
Analog camcorders in general specify that the heads should be cleaned every 10-15 hrs.of use. It's possible it's another problem but unlikely and this is a cheap way to find out.
Good Luck and thanks for visiting Fix Ya.
Mikeywaf
Posted on Mar 20, 2011
leethedeuce
  • 4472 Answers
SOURCE: My Sharp Viewcam (VL-NZ100) will
You would need to have the camera diagnosed/repaired by a professional or sharp themselves. Most independent places online will give you a free estimate. have you tried a cleaning tape? Given the age of this unit you may want to consider replacement.
thank you,
Lee
Posted on Jun 10, 2011
Pink lines when i play back my tapes on my canon zr500
Hopefull your not going through the tv and then to your dvd recorder
transfer should go straight from your camera to the dvd recorder.
you may also want to but a head cleaner for a mini dv camcorder,run it twice and try recoding again.If that doesnt work,you may have a problem with the heads inside of the camera.If thats the case,it would need to go to canon or an authorized service center.
Feb 01, 2010 | Canon ZR500 Mini DV Digital Camcorder
Panasonic DMR-EZ48VEB When i play a vhs tape the picture is fine ,but as soon as i try to record the picture onto a disc a black line about 1 1/2 inch appears across the bottom of the screen??? HELP
are you recording from a bought movie? some recorders have a feature that prevents copyright infringement. some will have the picture dim and red.
Dec 17, 2009 | Panasonic Televison & Video
When transferring (or watching) video from this Sony DCR-TRV530
Sounds video head is dirty / clogged.
Use good quality video-8 head cleaning tape for head cleaning in DCR-TRV530 and then record and playback it.
Aug 23, 2009 | Sony Handycam DCR-TRV530 Digital Camcorder
Lines across screen on playback.
A Q-tip should never be used to clean a video head.  Unfortunately they can pull the tiny head out of alignment.  I believe this is your problem and the repaid may be more costly than a new purchase.
Nov 25, 2008 | Panasonic Palmcorder PV-DV351 Mini DV...
Lines on my JVC mini dv recorder
Please use Mini DV Video head cleaning cassette as it seems video head is dirty / clogged in camera.
Oct 24, 2008 | JVC GR-D295U Mini DV Digital Camcorder
Wont record or playback tapes
There you go. Thats a good way to get the problem solved.
Aug 08, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Sony Hi8
If you see the line while in the camera mode (actually recording a scene), then the line will be on the recording most likely. Check your tape for damage by lifting open the front of the cassette (tab on left side of tape), pull tab back while opening cover and inspect for creases or damage. Either of these cases will be non-repairable (bad recording). If the tape path is out of line the then it may be possible to have a tech realign the tape path to correct problem.
Apr 23, 2008 | Sony Hi8 CCD-TRV138 Camcorder
Help With My Digital Video Camera!
You try it with proper connection using a new or working wire if you have used a vcr to play back.
Play the tape with any other camera.Bcoz your monitor may be fault.
Play the head cleaning tape in the camera, and try
May be the recording head of your camera is clogged
Mar 29, 2008 | Photography
Grey lines across the screen
Does this happen on all dvs tapes? If so then it is a problem with the head reader of the cam, but if only one tape, then that tape is either has quite an old recording on it or the tape is damaged.
Jan 12, 2008 | Canon ZR200 Mini DV Digital Camcorder
Canon ZR200
Hey,
I just started to have the same problem, 5 grey lines and intermittent audio. I the settings and i tried different tapes and No Joy. Then I tried to record onto an old tapes to see if the new recording would do it and the camera showed me a strange icon for exposure. I set the exposure back to 'Easy' and Viola, I recorded and the playback is now clean. Even old tapes play OK now...
The settings must have gotten wacked somehow. I glad it worked out, good luck.
Oct 06, 2007 | Canon ZR400 Mini DV Digital Camcorder
Sharp Viewcam VL-AH60U Hi-8 Analog Camcorder Logo
Top Sharp Video Cameras Experts
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
