Question about Konica Minolta PagePro 1350W Laser Printer
Hi i have Konica Minolta PagePro 1350W Laser Printer but the error light keep flashing
Where can I download Konica Minolta Pagepro 1350W driver for Windows 7 64 bit?
Go to this website
http://download.cnet.com/KONICA-MINOLTA-PagePro-1350W/3000-2116_4-155429.html
Oct 04, 2010 | Konica Minolta PagePro 1350W Laser Printer
Pagepro 1350W will not print. Ready light on. error light blinking
You have to see how the led is blinking and to compare with the table that explains every blink what means. If you don't have this table, contact me and I'll send it to you.
Chip reset device for Konica Minolta Bizhub and CF imaging units
http://www.chipreset.eu
Aug 09, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta Pagepro 1350W error light flashes and will not pri
Jul 06, 2009 | Konica Minolta PagePro 1350W Laser Printer
Need drivers for vista on pagepro 1350w
I clicked on the 'Konica Minolta PagePro...' link next to this and Vista drivers were offered...
Jun 14, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Apr 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica minolta pagepro 1350w error light won't stop flashing
pleas install status monitor, it will tell you what is wrong
Jun 20, 2008 | Konica Minolta PagePro 1350W Laser Printer
Minolta PagePro 1350WN Laser Printer
The driver for the PagePro 1350W does not come with the initial installation of Windows Vista. However when you run Windows Update you will find a updated driver for this printer - just download it and let Windows install the driver. I had the same problem with this printer when I installed Vista - I'm now using Windows 7 and it automatically installed the proper driver for the Konica Minolta PagePro 1350W.
Just keep at it - it should work fine after you install the updated driver.
May 27, 2008 | Minolta PagePro 1350WN Laser Printer
Error light
You have installed a refilled cartridge without changing the chip on the bottom of the cartridge. Your error light will flash and also upon starting your computer, you will probably get an error screen saying the bi-directional connection is disabled. The printer should still work, but will be slow because it recycles between each page. My error light has been flashing for some time, but when I send a document to the printer, the error light stops flashing and the printer prints. After the print job is done, the error light resumes flashing. The only real solution is to replace the chip on the toner cartridge with a new one.
Dec 18, 2007 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W Laser Printer Logo
368 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
