Question about Canon PowerShot SD880 IS Digital Camera
Today i went to a beach nad my camera fell in the sand. After taken it out when i switch on, the lens does not move at all. It is stucked because of sand and on the screen it says "lens error, restart the camera". So in order to get it fix, what should i do? for information, i bought it from best buy in houston last thanks giving.
  • 555 Answers
Sorry to hear that shivamfc. You are an unfortunate Canon user with the unlucky results of digital camera + sand = dead.
To make the camera to work again, you need to be sure to remove the sand that got inside the lens mechanism, unfortunately that is a serious repair and I don't think it can be done by the user.
Perhaps you can contact the manufacturer to see if they have a good solution for you or at least they are kind enough to provide you a rebate is you have to buy a new one.
Some people having trouble with lens mechanism (in cheaper cameras) are "fixing" this issue banging the camera (as this is already unusable) and a few of them are lucky enough to get it working again.
The first idea that comes to my mind is to use compressed air and try to remove any sand particles but I'm not sure that will fix it, also, the CCD can be damaged trying this.
The best recommendation that I can give to you is to contact the manufacturer for solutions.
Posted on Sep 06, 2009
Beach dust dropped in beach.
Cameras and beaches don\'t do well at all. The most important thing is to remove as much sand as possible without scratching any part of the camera. I\'d suggest to not wipe it at all, but take it home and try to vacuum the sand and dust off. It can get wedged in the drive mechanism for the lens focusing and will stop the camera from going through its normal initialization cycle. Check around the edges of where the lens moves in and out for sand, and try to suck it out.
Nov 17, 2013 | Canon PowerShot SD1100 IS Digital Camera
I went to the beach, and took puctures there. When i got home and tried to use my camera, the lens wouldnt fully expand and the camera says "lens error"
My guess is that the lens has some sand in it. You might just want to open the lens as much as possible and give it a good cleaning with rubbing alcohol on a cotton swab as well as blowing it out with canned air. I know it seams kinda nuts, but if cleaning it doesn't work try to manually push the lens in slightly to free up some stuck sand. Also, you could tap the camera on a hard surface with a small piece of fabric under it to try to knock out some more of the sand.
Hope that helps!
May 10, 2011 | Nikon Coolpix S4000 Digital Camera
Lens error.....restart camera. Tried over and over again. Nothing works. HELP!
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god....
thanks.
Apr 11, 2011 | Canon PowerShot SX10 IS Digital Camera
Automatic lens cover does not fully open
1. there's a problem inside of the camera especially the gear if the camera fell down or applying excessive force to the lens part. The gear was broken thats why it was not fully open and having weird noise inside.
2 if you went out to the beach or place a lot of dust.possible the sand or dust goes indide of the lens gear and cause of stuck up and not fully open the lens.sometimes becuase of this the gear was damage or broken and you need to bring to service center.
Jun 03, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
My baby nephew dropped my camera on the beach and now it has some sand stuck in it and has stopped working. can this be fixed? p.s it turns on but no longer lets me take pics.
Hi!
I believe there's sand inside the lens or stabilizer - the lens unit has to be taken apart and cleaned by a professional. It's a hardware fault, not software so I'm afraid you will have to give it to a local repair shop or Kodak service center and let them clean it.
I work in Kodak service center.
Tom
Oct 09, 2009 | Kodak Easyshare 1725043 M893Is Digital...
The lens seems to be stuck. I can't get it to retract. When I press the on/off you can hear ''gears'', but the lens doesn't move. My daughter had it on the beach and it's possible that sand got in the...
The lens have been moved a little to the left or right. This is a common problem on Kodaks. Try to put as hard as you can on the lens to get them unstuck. This worked for me.
Aug 27, 2009 | Kodak EasyShare One Digital Camera
Sand in my camera
Sand, water, salt water, dirt and dust can damage the lens to the point of no return, so to speak.
It may not have been dropped if you had used the wrist strap, how ever it is now in damaged condition.
The lens needs to be taken apart to completely clean out the sand. This is a very tedious and is a job for a professional with experience.
The parts are extremely small and have close tolerances, thus any dirt or sand can cause grinding or damage to the internal parts of the lens mechanism.
If you ever get a chance to see the gears and the gear teeth, you would understand why just a few grains of sand can jam these small parts. One grain of sand can stop a lens gear from working and possibly cause a broken gear. The parts are so small that in order to see the grains of sand which cause the problem, it may be necessary to use a magnifier lens.
To even make things worse, there is grease usually on the gears. The grease will hold any sand and cause it to stick in place. Cleaning these gears is not very easy.
I have done it, and returned the camera to working condition, but not an easy job.
Aug 30, 2008 | Nikon COOLPIX L3 Digital Camera
Lens cover is stuck half way open on Lumix DMC-TZ3
argh! me, too! i love this camera, but the lens cover is just plain stupid. we used the camera at the beach for a couple days, and i could tell a grain of sand got stuck behind the lens cover. now it is jammed and the camera is totally out of commission. why make a camera built for outdoor conditions, then put a lens cover like that on it!! i can't find a tech who can fix it, either. went to three shops in NYC and all said the cost to deal with it would pretty much buy me a new one... ! :(
Jul 29, 2008 | Cameras
Lens not moving
try switching on and gently pulling and twisting the lense you may hear iot click but dont force it, then turn off and on again this may solve you problem.
Jun 08, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
A430 camera
I went to the beach and when it came back, it was like ur's, so it might be some tiny piece of dirt and sand stuck in the lens somewhere.
Dec 13, 2007 | Canon PowerShot A430 Digital Camera
Canon PowerShot SD880 IS Digital Camera Logo
153 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
