Question about Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV
I have a big blue circle with black in the corners of my tv...is that ghosting or is a screen burn? How do I fix it?
  • 93 Answers
Sounds more like a fluid problem
Posted on Sep 07, 2009
There is a round black circle, bottom right corner of the screen when on
could be a burn from constant display of each channels ID
turn off from the wall
wait an hour
see if the screen settles
May 02, 2016 | Televison & Video
My LG TV has suddenly become darker all across the bottom of the screen (10cm strip) it still has colour but is darker. In left hand corner it is considerably darker and depending on what you are watching...
Hi; your TV has burn screen or traces.it comes from one image left on the screen for too long, it can get burned into the screen, making it visible at all times. You can actually eliminate most screen burns with the use of a PC computer and a black and white screen saver. This trick eliminates screen burn after a period of several minutes because the black and white screens flash quickly, removing all traces of color from the screen. This will eventually eliminate any burned images on the LCD screen. you can do it by creating a DVD picture slide with only black and white image. you can use a computer to make DVD picture slide first go to paint brush and draw only white then save as white.jpg. second burn it into nero or other dvd burner third play it to your DVD player connected to you LCD TV.it has to be played in full screen let the white image display on your HDTV for several hours or even overnight. It should remove any burned-in images or ghosts. hope this help...............
thanks....
Sep 13, 2011 | LG 32LD350 32 in. LCD TV
My picture has been getting a blue area in the lower right hand corner of the screen and it is getting bigger farther along the bottom and the right side, also noticed a ring or outline of a circle when...
It is light engine that is going bad and causing blue haze/ clouds etc.
It is an expensive part, and I would recommend a new TV instead of its repair.
Thanks.
Sep 08, 2009 | Hitachi 50VF820 Projection TV
My Hitachi LCD rear projection TV has blue color in left corner
It is most likely the tube going out. Find some one to replace the tube if the TV is fairly new other wise it is going to be a trend. One tube now and another.. and so on. Ride it out as long as you can then go for an upgrade
Sep 08, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Sony big screen tv 57 inch kp57wv600 ghost picture on corners, can that be adjusted ?
"ghost" are not television problem. This happens when a nearby structure "echoes" the signal from the station to your TV, there is nothing wrong with it.
Jul 01, 2009 | Sony Televison & Video
Hitachi tv, model 53udx10b
Sounds like you need to run Magic Focus.
Sep 22, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Big screen tv picture problem
You most likely have a problem with the Diversity circuit. This is an upright module on the mainboard.Just clock the invertersignal using your watch (it should change every second). If that is the case, you might need to set up the ghost-setting.look in the menu for the ghost-parameter (set to '28' by default)and change it either up or down. if its not responding then you might have a problem with the CMP-board and that is a little costly.
Sep 03, 2007 | Mitsubishi VS-55705 55" Rear Projection...
Blue/Yellow in upper left corner
I have the same problem and now there is convergence problem with the entire screen, double images and ghosting ...i was told that some IC's are burned our ...etc..i'm waiting to see if they sell the entire board since the TV's are 10 years old... will let U know what i get as a response.
Jun 05, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
Sony KP-43HT20 ghosting effect.
may have bad convergence amps stk392-560 board location Ic8001 Ic8002 or the dcu unit is bad or the alignment drifted off and it needs service adjustments made to it.
Dec 28, 2006 | Sony KP-43HT20 43" Rear Projection...
Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV Logo
131 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
