Question about Refrigerators
It keeps tripping a GFI outlet - Refrigerators
  • 220 Answers
GFI outlets tend to wear out very quickly with a refrigerator running on them,most Manufacturers do not recommend plugging any major appliance into a GFI outlet.If you plug it into a non GFI outlet and it works fine the problem is in the outlet.
Posted on Sep 06, 2009
Gfi outlet trips right before the final spin cycle. This is on a top load kenmore 80 series washer. I replaced the timer but the problem still exists. The timer seems to be in a pause mode. In other words,...
Motor driven appliances can trip GFI outlets when there is no problem at all with the appliance. When a large motor first starts, it draws more current for a short time and some GFI outlets will trip (others may not).
Are GFI outlets required by code in your state/county for washing machines? If not, replace the GFI with a standard outlet. If so, replace GFI with a higher quality GFI outlet.
Nov 30, 2012 | Washing Machines
How to stop my whirlpool washer from tripping gfi
If it is tripping the GFI I would say you have created a short somewhere. Check that wire has not been braised, check the plug for signs of burning, check outlet for signs of burning. Plug another device into the outlet to see if something else trips the GFI. If something else trips it then you could have a bad GFI outlet. These are the basics to try first but could be a number of things beyond this.
Aug 31, 2012 | Whirlpool Washing Machines
Seacoast magic plus keeps tripping gfi breaker
try in different GFI outlet, if it trips the new one, the coffee maker is dangerous and you should return/replace it, it has a short.
if it doesn't, replace the GFI outlet, it is old.
Apr 16, 2012 | Philips Coffee Makers & Espresso Machines
My refrigerator keeps tripping my gfi out let.
This is a problem I have encountered before. When compressors start they sometimes trip gfi. Plug unit in different outlet or replace GFI with regular outlet
Jun 22, 2011 | GE Refrigerators
My electric smoker keeps tripping breakers
My Brinkmann 810-7080-4 Gourmet Electric Smoker was tripping my GFI after it sat for the winter. Would heat for about 3 minutes then trip the GFI. would keep tripping GFI until it cooled down and once again would trip after about 3 minutes.
--SOLVED: took 00 steel wool and olive oil to the heating element and removed what looked like a green fungus. Element is working fine now, not tripping the GFI and will run a full four hours for smoking!
Hope this helps save someone some money in purchasing a new heating element ($40).
Nov 26, 2009 | Brinkmann Smoke' n Grill Electric Double...
GFI outlet is tripping because of refrigerator in the garage.
Hi: Yes, replace the GFI outlet. A refrigerator should not be plugged into one for what you are experiencing and food loss. This was an easy answer for me, but unfortunately not for you The owners manual covers this, but us men don't read them (Well I had to as I worked with them for 30 years). Good luck, Jeff
Jun 01, 2009 | Whirlpool ES5FHAXS Side by Side...
It keeps tripping the breakers or the GFI outlet.
try different outlets in another room to see if that dosent help you may have a shortin the cleaner but i think you may be overloading the breaker
Jan 17, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
My dishwasher keeps tripping the gfi outlet
DISHWASHER SHOULD NOT BE ON A GFI CERCIUT. THATS YOUR PROBLEM . SHOULD BE A DEDICATED CERCIUT BUT IF NOT JUST INSTALL A REG OUTLET DONT WORRY THE DISHWASHER WILL TRIP THE BREAKER IN YOUR PANEL IF THERE IS A SHORT WITH THE WATER.
Dec 30, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Gfi outlet keeps tripping
try running an extension cord to the old outlet and see if the fridge works then you'll know if it's the fridge or outlet. good luck
Dec 03, 2008 | Whirlpool ED2FHEXN Side by Side...
Keeps tripping GFI outlets
The key here is to identify the problem as being either the coffee maker or the GFI receptacle... a simple test can be done as follows...
Try plugging the Coffee Maker into another GFI receptacle .. you may have one in the bathroom? If it trips that too, then you have an internal wiring problem with your coffee maker.. if it doesn;t ..then your GFI receptacle may be bad or on the verge of going bad .. either way..this should narrow the problem down to one or the other.. hope this helps..
Aug 30, 2008 | Keurig B60 Coffee Maker
Refrigerators Logo
122 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
