Question about Brother MFC-5840CN All-In-One InkJet Printer
How do I connect printer to computer or is it wireless?
Sounds mad, but have second hand printer with no manual. Can't see any appropriate port on printer for connection to computer. Please help!
  • 227 Answers
I do not know how to connect your printer, but here is the link to the downloadable manual for you model:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_5440CN_5840CN_EN_108.PDF
Posted on Sep 06, 2009
Set up linksy 2.4 ghz
Instructions
    • 1Shut down any devices you wish to incorporate into your network, including computersicon1.png and cable or DSL modems.
    • 2Connect one end of an Ethernet cable to any of the numbered ports on the rear of the routericon1.png. Connect the remaining end to the Ethernet port on your computer. Connect a second Ethernet cable to the port on the router labeled "Internet." Connect the other end of the cable to your high-speed modem.
    • Sponsored Links
    • 3Power on your high-speed modem. Plug the router's power supply into any available electrical outlet and connect the power supply to the appropriate port on the rear of your router. Examine the LCD lights located on the front of your router. Wait for the LCD light labeled "Diag" to stop displaying a bright red light, and then turn on your computer.
    • 4Open the network management control panel for your operating system. In Windows, open the "Start" menu, select "Control Panel" and double-click on the "Network Connections" icon; in OS X, open the "Apple" menu, select "System Preference" and click on the icon labeled "Network."
    • 5Configure your network settings. In Windows, double-click on the icon labeled "Local Area Connection," click on the button labeled "Properties," click on the option labeled "Internet Protocol (TCP/IP)," select the option labeled "Obtain an IP address automatically" and click "OK" twice. In OS X, select "Using DHCP" from the pull-down menu labeled "Configure IPv4." Repeat this procedure with any other computers you wish to connect to the router.
    • 6Open your Web browser and enter "192.168.1.1" in the address field. When prompted, leave the "User Name" field blank and enter "admin" in the "Password" field. Locate the wireless mode menu and select the appropriate option, based on the types of devices you wish to connect to your network (if uncertain, select "Mixed"). Choose a unique SSID name and enter it in the appropriate field. Click "Apply."
    • 7Click on the button labeled "Enable" next to the option labeled "WEP." Click on the button labeled "Edit WEP Settings" and enter your desired security information. Make a note of these settings, then click "Apply."
    • 8Restart your computer. For those computers you wish to connect wirelessly, open their network configuration screens and enter the security information in the appropriate fields. Setup is now complete.
Read more: How to Set Up a Linksys WRT54G Wireless G Router ' eHow.com http://www.ehow.com/how_5133173_set-linksys-wrt54g-wireless-router.html#ixzz2CVg8SB27
Nov 17, 2012 | Linksys Wireless-G WRT54G Router
My mad catz controller will not configure to my ps3.How can i do it wireless?
sir good day there are two way on how to configure your wireless controller to your ps3 console.... the automatic pairing and a manual pairing
first way an automatic pairing
1.turn on your ps3..
2.Connect the smaller end of the included USB cable to the PS3 controller.
3.Connect the opposite end into either USB port on the front of the PS3.
The pair light on the PS3 will flash. When it stabilizes, you can disconnect the USB cable
and use the controller wirelessly.
second way a manual pairing
1.. turn your ps3..
3.Connect the opposite end into either USB port on the front of the PS3. Press the "PS" button on the center of the PS3 controller. The pair light on the controller will flash. When it stabilizes, you can disconnect the USB cable and use the controller wirelessly.
you can try that 2 way on how to configure your controller to your ps3 console if this help you please rate me thank you sir..
Jun 12, 2011 | Mad Catz Call of Duty Black Ops...
I need to lock my router from others using my wifi
    • 1 Disconnect the power cord from your high-speed modem. Locate the Ethernet port on the back of your modem. If an Ethernet cable is already plugged in, trace the cable to the second device and unplug the cable from it; otherwise, plug one end of an Ethernet cable to the open Ethernet port on your modem.
    • 2 Plug the unused end of the Ethernet cable to the port on the back of the router labeled "modem." Plug a second Ethernet cable into one of the open ports located above the "modem" port; connect this cable to the Ethernet port on your computer.
    • 3 Reconnect the power cord to your modem; wait for the lights on the front panel to turn green before proceeding. Plug one end of the router's power cord into the corresponding port on the back of the device; plug the remaining end into any available electrical outlet.
    • 4 Turn on your computer and log into your operating system as normal. Insert the installation CD into the computer; the installation application should load automatically (if it doesn't, you can find the application by manually browsing the CD's contents).
    • 5 Follow the onscreen instructions; after you have made the initial configurations, click on the option labeled "Security Assistant" on the left side of the installer window. Select the desired security type for your wireless network and click on the button labeled "Next."
    • 6 Choose a network key and enter it into the appropriate field; press "Next" and follow the onscreen instructions.
    • 7 Open your computer's wireless network settings and enter the wireless network name, security type and network key into the appropriate fields. Save your changes. Set-up is now complete.
Tips & Warnings
  • You can access additional settings via the modem's manual configuration interface. Open your web browser and navigate to 192.168.2.1; when prompted for a password, leave the field blank, and click on the button labeled "Submit."For optimal signal strength, choose a location for your router that will be near your computer, with as few walls and other obstacles as possible.
Read more: How to Set Up a Belkin N F5D8236-4 Wireless Router ' eHow.com http://www.ehow.com/how_5106168_set-belkin-fd-wireless-router.html#ixzz1ONVtjSQ1
Jun 05, 2011 | Belkin F5D8236-4 Router
Connected printer to my wireless router, but my pc cant find the printer...Turned off the firewall and even gone into settings and added printer id address, selected port 427 to stay open for...
I am not sure what you are doing, it sounds like you said you connected your printer to your wireless router? Is your printer a wireless printer?, Is it set on wireless setting, and is it connected to the right port? The port should state wireless printer port on your computer. The best way to set up anything wireless or Bluetooth is to use the computer to set it up. Don't plug anything in until you start setting up your item, make sure your printer is turned on and you should find prompts to complete set up. If you have a CD that came with printer you want to install software first or go to manufacturer website and download software for your printer.
Aug 14, 2017 | Office Equipment & Supplies
How to connect a router to router and what the setup
  • Shut down any devices you wish to incorporate into your network, including computers and cable or DSL modems.
  • 2
    Connect one end of an Ethernet cable to any of the numbered ports on the rear of the router. Connect the remaining end to the Ethernet port on your computer. Connect a second Ethernet cable to the port on the router labeled "Internet." Connect the other end of the cable to your high-speed modem.
  • 3
    Power on your high-speed modem. Plug the router's power supply into any available electrical outlet; connect the power supply to the appropriate port on the rear of your router. Examine the LCD lights located on the front of your router. Wait for the LCD light labeled "Diag" to stop displaying a bright red light, and then turn on your computer.
  • 4
    Open the network management control panel for your operating system (in Windows, open the "Start" menu, select "Control Panel" and double-click on the "Network Connections" icon; in OS X, open the "Apple" menu, select "System Preference" and click on the icon labeled "Network").
  • 5
  • 6
    Open your Web browser and enter "192.168.1.1" in the address field. When prompted, leave the "User Name" field blank and enter "admin" in the "Password" field. Locate the wireless mode menu and select the appropriate option, based on the types of devices you wish to connect to your network (if uncertain, select "Mixed"). Choose a unique SSID name and enter it in the appropriate field; click "Apply."
  • 7
    Click on the button labeled "Enable" next to the option labeled "WEP." Click on the button labeled "Edit WEP Settings" and enter your desired security information. Make a note of these settings; then click "Apply."
  • 8
    Restart your computer(s). For those computers you wish to connect wirelessly, open their network configuration screens and enter the security information in the appropriate fields. Setup is now complete
  • Sep 15, 2010 | Linksys Wireless-G WRT54G Router
    How do I connect the second computer to the internet ?
    If your connecting a second wired computer , all you need to do is plug an ethernet cable on ethernet port of your computer and the other end should go to any of the available ports in the back of your router.
    If you connecting a wireless computer. You just have to look for the wireless icon, its usually seen on the bottom right hand corner.
    Right click on the wireless icon and click view available network,
    Highlight your network name and connect.
    Cheers
    KJ
    Jun 20, 2010 | NetGear DG834G Router
    It wont print wireless
    We have to connect the printer to the network first, If it is not connected, please follow the below steps.
    1. Touch Setup (c01629002.gif ) on the touch screen.
    2. Scroll down in the Setup menu, and then touch Network .
    3. Scroll down in the Network menu, and then touch Wireless Setup Wizard . The Wireless Setup Wizard searches for networks, and then displays them in a list.
    4. Touch the name of your network.
    5. If the list does not contain your network name, follow these steps to enter it manually:
    6. Touch Enter New Network Name (SSID) .
    7. On the on-screen keyboard, touch the appropriate letters and numbers to enter the network name (SSID). NOTE: Make sure that you enter the uppercase (capital) and lowercase (small) letters exactly. Otherwise, the wireless connection fails.
    8. When you finish entering the new network name, touch Done , and then touch OK .
    9. Touch Infrastructure , and then touch WEP encryption or WPA encryption. If you do not want to use encryption (a security password), touch No, my network does not use encryption , and then go to step 6.
    10. If prompted, enter the WEP or WPA key:
      1. Touch the appropriate letters or numbers on the on-screen keyboard.
      NOTE: You must enter the exact uppercase and lowercase letters. Otherwise, the wireless connection fails.
    11. When you are finished entering the WEP key or WPA key, touch Done and then touch OK to confirm. The product attempts to connect to the network.
    Once it is connected to the network or if it is alreday connected, please follow the below steps on the printer.
    2. Touch Network , touch View Network Settings , and then touch Print Network Configuration Page .
    After that, please note the ip address of the printer from this printed page and follow the below steps.
    Please click on Start------Control Panel---Printers Folder.
    Right-click on the printer icon 8500 series---- click " Properties" , and then click the Ports tab
    Click Add Port .
    Click TCP/IP port and put (ip address of the printer)
    , and then click New Port . The Add Port wizard starts.
    Click Next ,
    Follow the on-screen instructions to finish adding the port.
    The issue will be fixed.
    Apr 19, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
    Wireless printer problem
    Brother has posted a Network Connection Repair Tool on their site under downloads. Worked great to put my MFC printer back on line with my network.
    Mar 28, 2010 | Brother MFC 7840W Printer
    Problem with hp officejet4315v all in one
    Hi there check that the data cable hasn't fallen out if not change data cable. If still not working check that you are using the correct port within the driver .
    • Goto Printers and faxes
    • Make sure that the printer states Ready not offline
    • If states offline Right Hand click and select use printer Online
    • If not above right click and select properties
    • Once in properties select Ports from the Tab at the top of the window
    • Make sure that you are using the correct Port i.e. LPT1 or USB that the printer is connected to.
    • If you aren't change the port by clicking the appropriate one or add new port.
    • If you are on the right port try reinstalling the print drivers
    I hope this helps you
    Thanks J
    Jan 13, 2008 | HP OfficeJet 4315 All-In-One InkJet...
    Brother MFC-5840CN All-In-One InkJet Printer Logo
    49 people viewed this question
    CheckitRight
    CheckitRight
    James Cagle
    James Cagle
    Samyfam
    Samyfam
