Question about Samsung PPM42S3QX 42 in. HD-Ready LCD Television
LCD TV keeps turning on and off. Have to unplug
LCD TV keeps turning on and off. Have to unplug for extended time to get it to stay on, not always works.
  • 585 Answers
Hi my name is Eric,
I hope I can help you with your issue ,
The TV not starting properly you should hear the tone noise (bleep bleep) not a ticking noise or no sound .
These Samsung LCDs have problems with the power supply capacitors going bad, a servicer will charge between $200 and $450 to repair it replacing either the capacitors or the whole board.
here is a DIY (do it yourself) solution:
It could be just a few bad capacitors on the power supply, if you want to attempt the repair yourself you can do a visual of the power board caps will appear swollen on to.
We do not recommend do it yourself, but depending on your knowledge and technical ability you may be able to.
with the back removed you will usually see two circuit boards the upper one is the power supply, it has a few capacitors on it (cylindrical standing straight up soldered in mark on the sides with the positive/negative sides and MF and Volts values)
Samsung uses mostly 1000Mfd at 16Volts rating capacitors, they cost about $1 each (680mfd will also work fine)
usually I replace about four of them (or all the bulged on top ones) .
The power board and back unscrew with a medium philips screwdriver, if you do not know how to desolder and resolder then do not attempt this as you may damage the TV more than fix it.
Im am posting a photo of some swollen caps on a board so you know what they look like;
best of luck to you
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Posted on Sep 07, 2009
  • mparshley22 May 03, 2011
    Eric where can I find the picture you posted of the swollen caps? So far you have been a great help thx!
    -Melissa
5 Suggested Answers
  • 4 Answers
SOURCE: 42" Phillips Ambilight left side stays on all the time
DISCNECT IT
Posted on Jun 08, 2009
freetek
  • 5568 Answers
SOURCE: Samsung LCD 40 Sensor & picture problem.
Since this is affecting several functions, the problem is likely the main power supply. It may be that the supply itself is failing (switched mode power supplies like hari-kari) or an assembly (possibly the backlight invertor) is producing a fault condition which is causing the supply to drop out to protect itself.
Try the instructions below -
The supply is normally built on a separate board since these are often out-sourced by set manufacturers.
Unplug your set overnight to allow potentially hazardous voltages to discharge, remove the back panel of the set so you can see the guts.
Look for a smaller board with larger parts on it; some cylindrical (capacitors), others block-like and relatively large (chokes and transformers).
You should also see a relationship between the board and the incoming AC.
Check the board for a label or if not present, a stamped-on number.
Call the manufacturer's service center with your TV model number and the number found on that board and inquire about repair/replacement costs; if both are offered, they won't be that much different.
If you must buy a new board, don't dispose of the failed one as there are smaller companies that can repair it for less than the mfr. and then keep it as a spare as this problem will likely arise again.
Posted on Sep 10, 2009
SOURCE: My polaroid tla-01511c lcd TV has a problem. When
Buy cymbalta. Customer service worldwide, discount system, round-the-clock support from our staff. Regular online pharmacy at affordable prices. We are fully dedicated to your privacy and security. No delays in delivery. Any drugs without prescription.
*** Click Here To Buy Cymbalta Online ***
buy cymbalta
buy cymbalta cheap
buy cymbalta 60 mg
buy cymbalta medication
buy cymbalta generic
Posted on Oct 09, 2010
  • 10 Answers
SOURCE: TV will not turn on,
nedd to change capacitor for higher value,you will see on power board bulges from top,my suggestion change power board,it keep happening
Posted on Sep 19, 2011
TV KEEPS TURNING OFF AND WONT STAY ON
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 13, 2015 | Televison & Video
Tv stuck on standby
The internal power supply may have failed.
Nov 04, 2013 | Televison & Video
Works mostly, but sometimes just turns on and off
this trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
Oct 01, 2012 | Venturer PLV36220S1 22 in. LCD TV
I purchased a Panasonic TC-P50s30 50" Plasma TV
You did a good thing; really!! Keep that TV aside you always.
Jul 11, 2017 | Panasonic 50 in. Plasma TV
My lcd tv keep flashing the on botton when i turn it on and there is no image,i have to keep pushing the on botton until the on botton light stay on and the screen comes on,
The power supply needs repaired NOW. I suggest you do not play it---unplug it ---and take it in for service. If you continue to play it you will price yourself into a new tv.
Nov 25, 2010 | Toymax Magnavox 37MF231D 37 in. LCD TV
Philips LCD TV Matchline series keeps switching off!
heating up issue, try unplugging it and if you can clean the dust from within the unit. Try reversing the vacuum and blowing excess dust out.
Sep 09, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Aquos Turns off by itself
no. It goes black, then about 5-10 seconds, it turns itself back on.
Jan 01, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Olevia 26" flat screen
screen suddenly shut off. blue light in the right hand corner stays on but there is no picture
Dec 17, 2007 | Olevia LT26HVX 26 in. LCD Television
Samsung PPM42S3QX  42 in. HD-Ready LCD Television Logo
484 people viewed this question
Jerry Greenberg
Jerry Greenberg
