Question about ViewSonic VE175b 17" LCD Monitor
Viewsonic VE175b The monitor will come on once the computer is powered on. Yet after a second it will go off. I finally got it to come on after several attempts. Then the next time the computer was turned back on. It would not come one again.
  • 555 Answers
That issue sounds familiar. Some DELL displays have exactly the same problem, and, for some reason, the model of your display reminders me the 172Fbp model that I'm talking about.
I believe the problem that you are having with your display is caused by a short circuit inside the display, as the power supply detects the short circuit, it stops working. You may need to get a technician to have your display repaired.
If you want to know more information about this issue, here is the link with a similar problem: http://josepino.com/?howto-repair-dell
Good luck !
Posted on Sep 06, 2009
Replacement of backlight
Backlights themselves are not serviceable. Better to just buy a new unit if the backlight is bad.
May 15, 2014 | ViewSonic VE175b 17" LCD Monitor
Windows 7 compatibility
This monitor should be compatible with Windows 7. Just plug the monitor to your computer and let Windows automaticaly install the driver for it. No need to install the driver from the cd that came with the monitor.
May 20, 2011 | ViewSonic VE175b 17" LCD Monitor
ViewSonic VE155b
this means that your computer is set to either a too high frequency or too high resolution. Try to lower the resolution setting of your desktop step by step, until the message disappears.
Jul 23, 2010 | ViewSonic VE175b 17" LCD Monitor
I have a Viewsonic VE175b that is having back-light problems. Sometimes it takes up to 30 minutes for the backlight to turn on. Sometimes playing with the On/Off switch fixes the problem. To me it sounds...
yes power supply failing. you need to open it and look for leaking capacitors or crwoned ones. desolder the bad ones and take to a parts shop to get new ones and replace.
Dec 24, 2009 | ViewSonic VE175b 17" LCD Monitor
Viewsonic VE175b Monitor Powers Up Doesn't Display Windows OS
Hi; I had the same problem. I know that sometimes devices require you to perform some type of '10-30 second' "hold" of one or some of its buttons in order to 'reset' the device, so to speak. So, having said that, try this:
1) Turn your monitor off (no green light) but leave it plugged in.
2) Leave it off for about 10 seconds.
3) Hold the [2] button on your monitor (the one to the immediate LEFT of your monitor's POWER button).
4) While holding the [2] button, now press and HOLD your POWER button.
5) Wait for your image to appear and STAY onscreen for about 5 seconds, then release both buttons.
6) Your monitor should retain its onscreen image.
Hope this helps! Good Day to all!
Kelvin W.
Dec 04, 2008 | ViewSonic VE175b 17" LCD Monitor
VE175b 17" LCD No power.
Do you live on the second storey or higher? Couldn't resist. =)
It will probably be the capacitors on the main powerboard inside the monitor. Its a common fault with these and is easy to get repaired.
Unless you have fairly good electronics knowledge though you are best to take it to your local TV repair shop. The voltage inside reaches points far higher then even what you have in the wall sockets of your home.
The repair should not be expensive in any case. Call around and get a few quotes, also check who will service an LCD in your area, some will some wont.
Hope that helps =)
Apr 16, 2008 | ViewSonic VE175b 17" LCD Monitor
Viewsonic VE175b image breaks up
a capacitor is busted have it repair
Mar 10, 2008 | ViewSonic VE175b 17" LCD Monitor
My monitor stopped working
You need to be more specific .Post make, model, how old it is and exact problem.Is the monitor completely dead No lights power etc??
Feb 16, 2008 | ViewSonic VE175b 17" LCD Monitor
Troubleshooting Viewsnic Monitor
My ViewSnic 175b monitor goes black after about 1/2 hour working. In addition the words/letters typed after the blackness do not appear in the text input box.
This started happening after my last ZoneAlarmSuite Update and virus scan last Friday. Prior to that no problems at all. Any help gratefully recieved.. ...
Jun 05, 2006 | ViewSonic VE175b 17" LCD Monitor
ViewSonic VE175b 17" LCD Monitor Logo
265 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
