Question about Air Purifiers
How do i clean a lasko tower fan model 2551 as it is dusty inside
  • scsams Sep 09, 2009
    thank you. my vacuum did not do the trick but the compressed air did. cannot remove the grill/cover as per the instructions. thanks again!
  • 867 Answers
Best is if you have an air compressor and blow it out, if not, a paintbrush and vacuum will do. remove grill/cover if you have to. make sure unit is un plugged.
Posted on Sep 08, 2009
  • bozcro
    bozcro Sep 09, 2009
    you are welcome
  • onemoremitzv May 31, 2012
    How do you remove the grill from the model 1820?
Why will my fan not work the lights both come on.
It could be a bad connection or corrosion on the wiring connectors. I would suggest that you unplug the electrical cord to inspect the fan motor connectors, they should be tight and free of debris. If you had a meter you could check for voltage at fan motor but would have to plug in to power to do so so be very careful not to touch other contacts while performing the check. If you are not comfortable or experienced with electrical work I suggest that you take the unit in for repair or buy a new unit which may be best depending on the age of the unit. The fan motor is likely bad or it could be a switch./Difficult to say without properly diagnosing.
Oct 28, 2014 | Lasko Humidifier Model 1128 With 2 Filters
Lasko Tower Fan stopped working but Speed switch has power on all but one cable, How to find the issue?
you should only have power on the black wire into the switch. The white wire feeds straight through. the switch breaks the black and routes it to one of the three outputs for the motor.
Aug 07, 2014 | Lasko 2510 36" Tower Fan with Remote...
How do I Open the Vorando Tower Fan to clean
Use a flashlight to look through the vents on the front. You should see screws.
Mar 24, 2014 | Frontgate Vornado Tower Circulator Fan -...
Lasko blower fantype DTB E20739 PM7331
to clean your fan from dust
Jul 02, 2013 | Air Purifiers
I have a 42" wind
the first thing to check is that the remote control is working and the control panel of the fan itself are working probably and i think they did but you have to check first
this fan oscillating control button is not a mechanical connection like the regular fan so if you are not using it wrong(and i think you don`t ) an if all the buttons are working -except the oscillating function - (and i think they are ) turn that thing back and test it at the shop
May 22, 2011 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
My Lasko 42" Wind Curve fan when I plug it don't power up. Pluged at diferents outlets, same results Thank you
Check out the cord, (frayed or broken) usually right where it enters the unit, and the switch.... if these check out then the motor has gone bad...
heatman101
Aug 18, 2010 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
How do you clean the ionizer in a lasko wind curve
You have to take the fan apart. They didn't design it with the convenience of the customer who likes to keep things clean in mind, so you have to get out a bunch of screwdrivers and stuff and roll around on the ground and fight with it until you get it apart. I posted a lengthy post on how to get this model apart, as I just did mine yesterday. Just look for my name on the Lasko models like this one. But be careful and don't try it if you don't think you can pull it off without getting hurt.
Jun 11, 2010 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
How to clean my Lasko 42 Wind Curve Platinum?
Yep... ALL the screws in the back mus come out as well as the base. The only real problem I had was that 2 of the screws were randomly triangle drivers instead of phillips/straight combo. Ya know they do it just to tick you off...
Nov 02, 2009 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
Air Purifiers Logo
880 people viewed this question
Top Air Purifiers Experts
Are you an Air Purifier Expert? Answer questions, earn points and help others
