Question about Garden
How to refill the twine spool - Garden
    President:
  • 1,776 Answers
Check out the video at the link I am providing and see if it helps with the restringing. Sure hope so and best wishes.
http://www.youtube.com/watch?v=SuGfDNH6fXk
Posted on Sep 06, 2009
  • gdodu1292 Sep 04, 2010
    Good presentation. Enough details to do it yourself anytime.
How do I get the spool off to replace the twine? I lined up the holes but it won't come off
Please state the make and model..! It may also help if you added a picture. More information is needed in order to help you.
Mar 30, 2016 | Garden
How toremove spool ?
Remove the snap-on cap (Orange cap) on the bottom of the unit. Under that is a REEL (no doubt empty) and slide it out. If you have twine, rewind your own; or get fully ready to go spools and insert in the area where you remove the original. You need to Feed the new line (end) through the small hole from inside the spool area to the outer exposed portion of the whipper.
May 10, 2014 | whipper snipper Garden
Welger ap 53 baler
My guess is that there is some kind of bind that the twine is in between the spool of twine and the knotter... resulting in the twine being continuously too tight for proper tying. Check for restrictions and then make double sure you've cleaned out ALL of the bunched up twine and twine ends... Are you using the correct twine??
Oct 30, 2013 | Garden
Just bought a TE475. can't figure out how to replace the line compared to the traditional one-line configuration I am used to
Here is the info from the manual, the replacement line is put in near the center of the spool on the top of it, you simply feed it in. I have included a link to the manual so you can see the pictures. Look at page 10 for these instructions.
http://www.weedeater.com/ddoc/WEEO/WEEO2009_USen/WEEO2009_USen_TE475-952711797_545186833.pdf
LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spoo
Aug 25, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I don't know how to restring the weed eater
LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spool
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Refill line on spool of toro electric model 910
Onve you remove the cover the spool should pull straight out. Be careful, there's a spring under the spool that can fly out and get lost. You need that spring to re-assemble.
Apr 11, 2010 | Toro& Electric String Trimmer
What diameter twine do I need and how do I load it in the spool ?
to many parameters and depends on what you have
the most popular is .065 .080 and .095
Look at the trimmer head to see if there are any numbers and usually some have directional arrows on the direction to wind the line
Nov 24, 2009 | Garden
I have a ryobi weed eater and the twine locks up and wont release
There is really no solution to this problem -- it is inherent in weed **** -- I have extensive experience with this phenomenon, spending many hours trying dozens of approaches. If you need a **** my suggestion would be buy a new one -- it'll get you through a season or two...
Apr 19, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do I rethread the cutting line on a black and decker strimmer reflex plus
take the spool out there shood be a I hole to push the twine throu tie a not that wont come out look for dirtion or arrow to wind it leave enough to sitck thru the side where the twine cuts push the spool up and lock it
Jul 27, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
