Question about General Electric PGS908SEMSS Gas Range
FC and door locked displays will not reset even with turning power off on GE gas range ,model # PGS908
  • 87 Answers
SOURCE: Ge oven problem
Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
Posted on Jun 08, 2007
SOURCE: Can't Get My GE Profile XL44 Self-Cleaning Gas Range to CLEAN ! ! ! ! !
I also have a XL44 (GE JGBP90) and I can't figure out how to latch the door. When I press Self Clean, the display asks me to latch the door, but I don't see a lever. I think it might involve lifting the range, but I don't want to force it. Any ideas?
Posted on Mar 10, 2008
SOURCE: kenmore elite 790.3670 oven door locked
I held down the clear button for three seconds, it unlocked but still showed the lock button lit. It began beeping over and over. I opened the door and pressed the clear button again for three seconds. It stopped and the oven works just fine now. In fact, I used it right after I got it cleared out.
Posted on Jun 27, 2008
SOURCE: GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Posted on Dec 28, 2008
  • 25 Answers
SOURCE: Jenn air range model SCE30600B error code FC
replace oven sensor.
Posted on Feb 12, 2009
GE RANGE DOOR LOCKED ON DISPLAY WITH FC ERROR
You might want to ask GE. They want customer satisfaction.
Nov 29, 2013 | Washing Machines
My GE PGS975 DEP1 (GAS RANGE) DIGITAL CONTROLS ARE NOT WORKING. I purchased this brand new gas range in the USA and had it shipped to Brazil. After i installed it and plugged it on every think worked...
Power supply in Brazil is not universal over the entire country. Your range was built for 120 volt, 60 Hertz power supply. If you are in some areas, you may not have the proper voltage available. 127 V found in states of Bahia, Paran? (including Curitiba), Rio de Janeiro, S?o Paulo and Minas Gerais (though 220 V may be found in some hotels). Other areas are 220 V only, with the exception of Fortaleza (240 V).
Brazil does use 60 Hetz, but if you are in an area which only supplies 220 or 240 volts, you would need some type of adapter to convert that to 120 volts for your gas range. If you connected to the higher voltage, you may have irreversably damaged the electronic control, requiring control replacement, before connecting to the proper (120 volt) supply. I would expect 127 volts to operate your range, but if the voltage varied up from that, it could damage the control. Even in the US, voltage variations of 108 to 125 are rather common.
May 22, 2011 | General Electric Profile PGS908 Range
My PGS908 or PGS975 GE oven won't bake anymore. It won't heat up/light, although the range works.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Feb 02, 2011 | General Electric Profile PGS908 Range
I have a ge profile oven that is blinking and beeping all of a sudden. it is blinking FC on and off. We have a double wall oven.
This is an indication that there is a sensor issue with the door lock mechanism. There is a reset procedure you can try to see if the doorlock mechanism is working. It is usually used for a different code "Lock Dor" but it should let you know if the circuit is working or not. It also resets the devices and maybe will clear your error code.
http://www.geappliances.com/search/fast/infobase/10009792.htm
Jul 18, 2010 | GE Profile 30" Self-Cleaning Freestanding...
Oven will not work.
This is what GE recommends for your oven:
“F—and a number or On models with a door latch, • The latch may have been moved, even if only slightly,
letter” flash in the display if a function error code appears from the locked position. Make sure the latch is moved
during the self-cleaning cycle, to the right as far as it will go.
check the oven door latch.
You have a function error code. • Touch the Clear/Off pad. Allow the oven to cool for
one hour. Put the oven back into operation.
If the function code repeats. • Disconnect all power to the range for 5 minutes
and then reconnect power. If the function error
code repeats, call for service.
May 18, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE PGS908 oven not heating could it be the ignition? oven is
I probably the ignitor, it should not cost you more than 60 for the part, maybe 150 with labor
Jul 03, 2009 | General Electric Profile PGS908 Range
GE XL44 gas range...door is registreing as locked when it si not
try cancel if that doesnt do it try unplugging it for three mins
Feb 13, 2008 | Kitchen Ranges
GE monogram ZET3038 locked on Sabbath mode
How to Exit the Sabbath Feature
If the oven is cooking, wait for a random
delay period of approximately 30
seconds to 1 minute, until only ⊃ is
in the display.
Press and hold both the Bake and Broil
Hi/Lo pads, at the same time, until the
display shows SF.
Tap the Delay Start pad until
12 shdn or no shdn appears in the
display. 12 shdn indicates that the oven
will automatically turn off after 12
hours. no shdn indicates that the oven
will not automatically turn off.
Touch the Start pad.
NOTE: If a power outage occurred while
the oven was in Sabbath, the oven will
automatically turn off and stay off even when
the power returns. The oven control must
be reset.
Dec 02, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
"FC" display
It has detected the door lock motor didn't respond. Check wiring to the motor. If wiring is ok then replace the door lock motor.
Nov 09, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
General Electric PGS908SEMSS Gas Range Logo
Top General Electric Kitchen Ranges Experts
reliableservice
ray gallant
EE Eddie
Are you a General Electric Kitchen Range Expert? Answer questions, earn points and help others
