Question about Maytag Washing Machines
Maytag top load washer model LAT9235AAe will only run when dial turned to final rinse position.
  • 6,784 Answers
HI. this is a fairly simply fix here. the timer mechanism is damaged. The timer motor is not providing proper rotation, that is required for forward advancement of the cycle selected. It should be replace asap, if possible.
Posted on Sep 06, 2009
Why does my top load whirpool washer restart on its own after it finishes the last rinse and spin cycle. It does this on all settings, delicate, normal or heavy.
  1. Turn the washer off.
  2. Set the mode selector dial to NORMAL.
  3. Turn the dial counter clockwise ONE click (LEFT), clockwise THREE clicks (RIGHT), counter clockwise ONE click (LEFT) then clockwise ONE click (RIGHT).
  4. Now press the start button.
  5. All the cycle indicating lights should be illuminated.
  6. Press the Start Stop button once.
  7. Rotate the dial until Rinse, Wash, and Stop light illuminate.
  8. Turn the washer off and unplug it for 10 seconds.
  9. Finally, turn on the washer and it should now be reset.
  10. Run a test load empty to be sure the reset worked. If not perform the reset procedure one more time.
Oct 07, 2016 | Whirlpool Whirpool 3.5cu ft Top Load...
Kenmore front loader stops/freezes in pump out mode just before final spin
For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Aug 01, 2008 | Frigidaire GLTF2940ES Front Load Washer
Fuse blown on Maytag washer
Could have been a surge dont think its anything to worry about ....run and keep an eye on it ....
Apr 12, 2010 | Maytag PAV2300 Top Load Washer
Waher fills and then quits, won't start the wash cycle
LAT7300AAW that is your model number AZ103872 FD that is your serial number
Jan 02, 2009 | Washing Machines
MAYTAG LAT9235AAE TOP LOAD WASHER WILL NOT WORK
Pt, Should be a yellow wire from the water level switch according to the diagram I have. See if it has 120V to motor when full. Just take it to ground. Same with the lid switch in closed position, it shows here as yellow, but could be grey, these diagrams are not always accurate. I think you have a level switch or lid switch problem. Check for voltage to the motor when it should be agitating. Catriver..post back.
Oct 01, 2006 | Maytag LAT3600A Top Load Washer
Washing Machines Logo
109 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
