Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Freezer working fine cooler freeze's when turned on any postion
Freezer was not working, i replaced evap fan, freezer know working but cooler also freeze's
  • 612 Answers
Check the control knobs, make sure they are not turned all the way on high. If not and you have ice building up on the panel below the one with the fan, you will need to go back inside where you replaced the fan and replace your defrost heaters also. It will be bast to replace the defrost thermostat while your in there. It only cost around $15.00 and will save you trouble later. You could see both of these parts behind the panel the fan is in. The heater in you model is a cal rod type, made of the same material that ele stove elements are made of. You can ohm it and if it has no resistance, it's bad. If it does then the defrost thermostat is the one bad.
Please rate solution
Posted on Sep 06, 2009
Zis480mnc ge monogram built in refer temp varies from 34 to 48 several times a day.
Try replacing that evap thermistor. The diagnostics on thermistors can be wrong. If it is rounded on the end, replace it. There is a damper between the freezer and refrigerator. There may be a refrigerator fan motor in the damper assembly, It could be bad. It could be a bad control board. When you run diagnostics there is one function that checks all the fans.
Sep 25, 2014 | Refrigerators
Not freezing enough
You might have ice building up on your evaporator coil. That ice serves as an insulator and prevents the internal freezer temps from going down to design parameters. The ice buildup is caused by the defrost mechanism not working - check the timer or the defrost heating element.
Jan 07, 2014 | Summit 12.6 Cu. Ft. Frost Free...
My true cooler freezer in side fans dont turn on i run it for 15 min. the make is gdm-72f
first place to look is in the evap where the defrost/ fan delay is located. It is usually attached to the "U" tube on the evap and senses the temp. It prevents circulating warm are after a defrost. It could be bad and keeping the fans from running. Start there and let me know if I can be of further help
Jan 27, 2011 | True 72 cu. ft. / 2039 liter Commercial...
Frigidaire Freezer, model # FFU20FC6AW3. Unit is not cooling and the fan motor inside behind the access panel is not running. My Temperature Alarm sounds and will not shut off, unless I switch it to the...
if the evap fan is not turning try to turn it by hand a few times then start you freezer if it does not turn it needs to be replaced.make sure there is no ice build up on the evap coils.alos check the continuity of the defrost heater below the evap coils.once you het teh fan replace your unit should cool down to the proper temps.
Nov 16, 2010 | Frigidaire Freezer Refrigeration White...
Ge profile side by side fridge - fridge not cooling/freezer fine
The problem you are having is what is called defrost. This unit is supposed to do a defrost every 8 hours. If it fails to do so the coils will get a heavy heavy frost on them and the evap fan cannot circulate the cold air thru the freezer and into the fridge. you will need to defrost the coils with a hair dryer. Will probably take about 45 min.'s to a hour. The most common cause for this is the defrost heater located at the bottom of the coils. Replace this and you will be fine to go. Part number is wr51x10101
Feb 24, 2010 | Refrigerators
HELP!!__CALLING ANY GE FACTORY TECHS
You say " all thermistors check fine " , how did you check them ? Did you check for the 5-8 DC volts at the main control board , for the thermistors ? Did you do the diagnostic check for the thermistors from the control panel ? I'm sure you know there are 5 thermistors , since the refrig has the dual evap . Possibly the # 5 is bad , since it is the freezer temp " controller " , yet if it tells the board it's not cold enough , it still sends refrigerant to the refrig evap . Since the refrig evap has 2 fan motors , can't remember if there is a damper there also . Maybe when the # 3 thermistor is satisfied , it only cuts the fans off , even though refrigerant is still going thru the refrig evap .
Oct 31, 2009 | GE Profile PSH23PGT Side by Side...
Refrigerator is not getting cold although the freezer appears to be working fine
can you hear the evaporator fan motor running in the freezer? this fan motor pushes the cold air from the freezer to the food section to keep it cold. you may have to replace the evap. fan motor. also, check for any kind of ice build up around the evap fan motor.
Oct 11, 2009 | Amana ABB1927DE Bottom Freezer...
It's a Kenmore alright
Do you have any frost buld up in freezer compartment?if so sounds like a freezing issue.If no frost build up is your fan running in freezer part if not you may need evap fan or a manual defrost.Your fan may have ice stoping it from turning.If your fan is running you may need to pull off your start switch located on your compressor.Shake it around if you here noise like burnt parts in it you will need a start switch.And remmember never turn your fridge up full blast normal is good or you will freeze it up. Good luck:)
May 28, 2008 | Kenmore 60721 Refrigerator
LG Fridge bottom freezer
Have you had the evap fan replaced, if not that sounds like your issue.
Nov 06, 2007 | LG LRFD22850 Bottom Freezer Refrigerator...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
98 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
