Question about Olympus FE-340 Digital Camera
Ok so i am turning on my camera (an Fe-340) and the lens go in two or three times then when the screen finally does come on it is blurry and way out of focus, also when i attempt to adjust the zoom the camera turns itself off, if i attempt to turn the camera off using the power button it goes off but the lens does not retract.All other functions on the camera are operating correctly to my knowledge i can even take a blurry out of focus picture, view it in display mode or even transfer it to my computer, i can adjust the scene etc. I think that the problem is with my lens..am i right? and if so how can my problem be solved ?
    President:
  • 2,761 Answers
It may be something more serious, but the problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion buildups may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment, clean the contacts at both ends of the batteries, and reinstall them in the camera. Assuming that the batteries are fresh/fully charged, this takes care of about 90% of the startup problems. I hope it works for you.
Posted on Sep 07, 2009
Why are my pictures so blurry like someone swiped it
Your lens is dirty or when you take the picture the exposure setting is took long and then any movement will make the picture look blurry.
Have you tried putting the camera on a table and taking a picture?
Aug 27, 2014 | Olympus FE-340 Digital Camera
Help with the Olympus FE-280 8.0 megapixel, please!!
this is a tipically problem, of a pressure on the lens, if the lens go out. or if the camera are dopped. to resolve this problem alone you must have specifically knowledge.
the cost of the reparation is high. so if you want prove withe the exact model number, search on the ebay international seller the komlet lens with ccd for you camera. any american seller if you buy the lens, can give a guide to change the lens block. but this is not a symply job. if you make one error you loose the camera and the lens. the price of your lens block can go from 25 to 35 euro, if you can change it alone you have resolved with this money. ok.?? sorry for my bad english if you want help can you write me and i will help you
May 30, 2010 | Olympus FE-280 Digital Camera
My FE 340 Olympus Camera tries to turn on, but can't. Lens goes in and out several times then shuts off completely. Battery is fully charged.
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 19, 2010 | Olympus FE-340 Digital Camera
Olympus FE-340 camera i turn on the power the lens goes in and out 2 or 3 times and the view is blurry in the view finder. The zoom feature has no effect when pushed to the wide setting and will turn off...
your lens may be damaged...your zoom assignments may need to be realligned if there are no broken parts. If there are broken parts in your lens it may be better to get a new lens
Aug 10, 2009 | Olympus FE-340 Digital Camera
Olympia fe-340 won't fully turn on
You have a bad lens, you should take into a camera repair shop. The only other thing that can be possible is the cable from the lens to the camera man board may have not be making proper contact.
Jul 02, 2009 | Olympus FE-340 Digital Camera
Problem with my Olympus FE-230
When I turn my camera on, the lens goes in and out a few times. Once it's finally on and I look at the screen, everything is blurry. When I take the picture, it's blurry too. If I try to use the zoom to adjust, the lens starts going in and out all crazy and won't adjust right.
Jun 20, 2009 | Olympus FE-230 Digital Camera
Camera wont focus or stay on
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
May 25, 2009 | Olympus FE-340 Digital Camera
Blurry images on camera
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Also try to reset the camera back to factory settings as there may be a setting that is causing this issue to occur. To reset the camera - go to Menu - left arrow to reset - highlight Yes and press ok. This will reset the camera back to factory default settings. See if the blurriness still occurs. If it is still blurry you may want to send to Olympus for evaluation and repair service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Apr 22, 2009 | Olympus FE-340 Digital Camera
Fe-340 wont turn on
If the lens is stuck out, that either means impact or it got squished and messed up the lens mechanism. You can have that repaired.
Apr 20, 2009 | Olympus FE-340 Digital Camera
Olympus FE-340 Digital Camera Logo
209 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
