Question about Craftsman Garden
Have Craftsman gas weedwacker double line ran out.
How do you replace double medium line? need illustrations along wiyh instructions. Briggs and Stratton 4 cycle family line 1BSXS - 0404MA
    Problem Solver:
  • 5 Answers
Take off knob that holds on the spool on bottom of weedwacker, remove spool, there are notches around the outside splines on the bottom of the spool. (the bottom is the end that fits up into the spool housing. there are 2 little holes opposite one another on the spool - one on each section. Cut two lengths of line about 6 feet long. stick line into first hole (near bottom of unit) wrap line around spool. once wrapped line gets short - to the point where you cant wrap it anymore - stick the end into one of the notches - do the same with the other line - insert spool back into housing - make sure spring is attached to the spool and lines come out of the holes in the housing - reinsert knob and tighten - make sure as you are doing this you unseat the ends of the lines off of the notches on the spool and they are out through the housing - tighten knob and you should be good to go
Posted on Sep 07, 2009
Program instructions for the Briggs & Stratton model 310000
Request the instructions directly from Briggs & Stratton
Jan 31, 2018 | Briggs & Stratton Electrical Supplies
Need a throttle linkage diagram for a briggs & stratton engine model 9S502 type 0620-B1
David, This is what I found in google search for B&S carb. linkage diagram, you can also do a search because there are lots more.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Linkage Spring replacement on Briggs Stratton Quattro 4 HP Murray Lawn...
Repairing Lawnmowers For Profit Part 61 Governor Spring Help
briggs and stratton governor linkage diagrams Google Search
briggs and stratton carburetor linkage diagrams Google Search
Jun 10, 2016 | Briggs & Stratton Garden
Weedwacker has fire to the sparkplug and new gas to the primer bulb but will not start
sad these little gas engines always fail when we don't want them to . requires a lot of compression to run and if not properly oiled thru the gas will fail .
Aug 08, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
Craftsman weedwacker model 316711970
If you go to searsparts.com and put in your model number it will show you a drawing of your weed wacker. Not sure of what you are looking for. Hope this helps.
Jul 09, 2015 | Craftsman 29cc 4Cycle Straight Shaft...
My craftsman weedwacker 27cc curved shaft wont start and cant figure it out
I need to ask. Did you leave fuel mix in it for a long time? If so then the carburetor will need to be cleaned with a special cleaner. and not the spray can stuff.
Nov 24, 2014 | Craftsman 27cc 2Cycle Full Crank Curved...
Managemylife com
1.You have to remove the air filter *** cover.
2.Remove air filter.
3.Remove 2 screws, to remove the rest of air filter ***.
4.Remove the 2 fuel lines with a long nose plier.(Take a photo of
the position of fuel lines or mark fuel lines for reassembly)
5.Unhook the throttle cable.
Now to fix the Carburettor
1.Remove the 4 screws on primer bulp side of the carburettor.
2.Open the carburettor and clean with paint brush and clean fuel.
3.Replace diaframe kit(available from your nearest dealer) and reassemble the trimmer.
Dec 30, 2013 | Craftsman WeedWacker Gas Trimmer 29cc...
Craftsman 25 cc Weedwacker
Look for air leaks in the gas line and around the carb , a bad gas cap will not let any pressure build up. It could be that too. Check also the fuel line and filter inside the tank. replace if needed.
www.ereplacementparts.com has parts for craftsman or the online Sears Stores.
Nov 01, 2017 | Craftsman Garden
Garden Logo
359 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
