Question about Sanyo DS27820 27" TV
Hig Definition I would just like to know what I need to be able to watch High Def. on my Sanyo!! I know I won't get the High Def. sharpness, I just want to know if I am able to receive and watch High Def.?
    Genius:
  • 1,694 Answers
Sorry, no high-definition 1080 I........if you have RGB component
video input on your TV the best you can do is 480P or I from
component out on back of DVD..............T.
Posted on Dec 08, 2007
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
I have an Apex digital 32" LCD TV Model LD 3249 and Serial #36056009262 Is this a high definition TV
Yes. 720p High-Def capable.
Remember you have to have a High-Def signal source to actually view High-Definition video. This means local broadcast TV in HD or digital cable TV with HD service and a HD channel or satellite or a Bluray Disc.
Mar 15, 2011 | Televison & Video
I have hdmi cables connected and am trying to watch in High Def, but its only displaying in 720p what can I do to fix it
That is Hi-Definition - it's just not as hight as 1080p
Is your TV definitely capacble of 1080p?
If so, check the source output settings
Jan 23, 2011 | Sharp LC40D68UT 40 in. LCD TV
I had a new high def tv installed.the cable company hooked up there box .now i cant record anything on the vhs.
was the VHS recording before the new high definition TV was installed? Or are you trying to say that the cable company has tempered with the settings of the VHS?
Probably, the cable company, has removed the cable for the player. Check the back of the player and let me know if the cable between the player and the TV are intact.
The above needs to be verified for accurate solution.
I look forward to your reply.
Bye for now.
Jan 20, 2011 | Sanyo DVW-5000 DVD Player/VCR
Will set be campatable after June with the new high def?
Your set is HDTV-ready....
With an HDTV-ready set you’ll need an external digital tuner to watch HDTV programming.
However, if you have high-definition cable or satellite service you can watch those HDTV stations right now on your HDTV-ready set, no extra tuner needed.
which means you will still need a converter box if you use an antenna signal.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 26, 2009 | Televison & Video
Digital ready?
Deacon J,
You will need a digital converter box OR high definition tuner for the transition. What's the difference? A converter box will only output a standard definition signal, either on channel 3 or by composite or S video cables. A high definition tuner will allow you to watch the new digital broadcasts in hi-def, assuming they are transmitted in hi definition. The converter boxes are the cheaper option and you can get a coupon from the government for a $40 rebate on the box, but I would opt for the hi-def tuner fo the better picture quality.CNET has a good write up on the transition here:
http://www.cnet.com/1990-7874_1-5108580-3.html
I did some looking and about the cheapest hi-def tuner I could find was $150, which is 3 times what a converter box would cost. I would expect the cost to fall on the tuners over time. Perhaps a converter box may be a good solution until the prices fall, if they do. The problem is that not many companies are making the tuners, as most TV's already have a hi-def tuner built in, so there isn't a big market for the add-on tuners. I hope this answers your questions.
Dec 31, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
How to get a high definition Picture??
Okay - it is a high def 720p but you have to use the HDMI inputs for High Definition... also, using the LCD as a computer monitor the best setting is 1280 x 768 - standard p&p monitor driver for Win XP or Vista (or Win 7 Beta). The HDMI slots are on the left side and are small rectangular slots about 1" long.
Nov 28, 2008 | Sansui HDLCD3200 TV
Picture problems
The pixelation is probably caused by MPEG2 compression on the DVD and Virgin media video streams, the blur is probably caused becasue you are displaying a standard definition signal on a high definition TV.
However if a high-def source still has these problems then you may have a faulty TV, your best bet is too hook up a high-def source such as a HD/Blu-ray player or PS3/360 games console.
Should a high-def source look ok, then you may have some look changing the display settings on the TV to try and improve picture sharpness and color balance.
Thanks.
Nov 08, 2007 | Televison & Video
Hd ready?
On any High Def TV, the reciever you need for this set, which does not have a HD receiver in it, is half the equation. Most HD channels have some HD content mixed with SD content on the same channel. SD content on HD signal from cable or satellite tends to be slightly blocky due to the native signal resolution and the resolution of HD (1080i/p or 720i/p).
Apr 30, 2007 | Akai PTH5498 54" Rear Projection...
Sanyo DS27820 27" TV Logo
73 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
